GPS&GLONASS External Antenna
Specification
Antenna
Frequency Range
V.S.W.R
Band Width
1575.42MHz±5 MHz
1610MHZ±10MHZ
1.5:1
+/-5MHz-GPS
+/-10MHz-GLONASS
Impendence
50 ohm
Gain
5dBic Based on 7×7cm ground plane
Polarization
RHCP
LNA
Frequency Range
1595MHz±25 MHz
DC Voltage
2.7V/3.0V/3.3V/5.0V/3.0V to 5.0V/other
Gain(
(Typical)
30dB (Without cable +25℃±10℃)
Noise Figure(
(Typical)
1.5DB
DC current
11mA MAX
Material
Antenna
Dielectric Ceramics
PCB
FR4
Shielding
Tinplate
RG174
RF Cable
L=2000/3000/5000 or other
RF Connector
SMA/MCX/FAKRA or other
Testing Conditions
Working Temp
-40℃~+80℃
Storage Temp
-45℃~+85℃
Sine sweep 1g(0-p)
Vibration
10~55~10Hz each axis
Size drawing
LNA Test Plans
Noise Figur Test Plans
Application
GLONASS is the abbreviation of Global Navigation Satellite System, it is the similar to the
satellite positioning system with the US GPS system, the GLONASS construction from the early
1980s by the former Soviet Union .This antenna combine GPS and GLONASS satellite signal
receiving function, with high gain, low noise figure, and cause of the small size is very easy to
install. The GLONASS system is used to the Navigation also can be widely used in various grades
and types of measurement applications, GIS applications and time-frequency applications.
很抱歉,暂时无法提供与“MIKROE-3374”相匹配的价格&库存,您可以联系我们找货
