PiJack Ethernet HAT for Pi Zero
PRODUCT ID: 3374
Description
PiJack is a HAT (yes, a proper HAT, not a pHAT!) add‐on board for the Raspberry Pi Zero mini
computer that makes connecting your Pi Zero to the Internet via Ethernet super simple. If
you're fed up with flaky WiFi and want your Pi Zero to be online all the time, then this HAT is
for you!
PiJack is a neat little board with an Ethernet controller and standard RJ45 connector so you can
hook your Pi up to your home or office network using standard Ethernet cables. PiJack is ready
to go – there's no special software or drivers to install. It works right out of the box with
Raspbian – simply attach PiJack to your Pi's GPIO header and plug it in!
Features:
o
o
o
o
10Mbps Ethernet connection
Two blinky LEDs for connection status
HAT‐standard‐compliant EEPROM makes setup automatic, works straight away with
Raspbian!
Uses the Pi Zero's GPIO pins, your USB connector is still free for something else!
Note: Pi Zero and Ethernet cable not included!
PiJack is well engineered and uses high quality components and connectors (that won't snap off
the first time you use it!). PiJack is built in the EU, and every board is tested to make sure it'll
work for you first time.
Technical Details
PiJack setup guide http://pijack.net/pijack‐installation
Product Dimensions: 65.5mm x 32.3mm x 23.0mm / 2.6" x 1.3" x 0.9"
Product Weight: 15.6g / 0.6oz
https://www.adafruit.com/product/3374 9‐28‐17
很抱歉,暂时无法提供与“3374”相匹配的价格&库存,您可以联系我们找货
