2118
    ADAFRUIT
    DRILL BIT CARBIDE 0.020"
2118 数据手册
    Carbide PCB Drill Bit ‐ 0.5mm  PRODUCT ID: 2118        Description  If you've started designing your own PCBs in Eagle or KiCad and want to make your PCB a  reality, you may start out with an etching system to pattern out traces. But that's only half the  job! You'll also need a way to drill some tiny and accurate holes.  That's why we've started selling  these PCB drill tips in a variety of sizes.  They're made from carbide (tungsten steel) and are suitable for circuit boards, electronics, SMT,  molding, metal processing, telecommunications, and other uses.  Each drill tip has a high  hardness, wear resistance and strength and they're also super sharp which helps when drilling  through PCBs.  The drill bits also don't easily bend or break and come in a nice plastic case to  store your tips when you're not using them.    This product comes with one 0.5mm Carbide PCB Drill Bit in a protective plastic case.  Technical Details   o o o Total length: 38mm  1/8" Shank  Diameter: 0.5mm        https://www.adafruit.com/product/2118 7‐25‐17
很抱歉,暂时无法提供与“2118”相匹配的价格&库存,您可以联系我们找货
