Medium Vibration Sensor Switch
PRODUCT ID: 2384
Description
The "poor man's" accelerometer/motion sensor! These spring-vibration switches are medium sensitivity
non-directional vibration induced trigger switches. Inside is a medium hardness spring coiled around a long
metal pin. When the switch is moved, the spring touches the center pole to make contact. So, when there's
motion, the two pins will act like a closed switch. When everything is still, the switch is open. Great for
basic projects and wearables!
We also have a version with a stiffer spring, which is harder to trigger, and a version with a very soft
spring, which is easier to trigger!
Technical Details
o
o
Maximum Operating Temperature: 260°C ± 10°C
Contact Time: 2 - 2.5ms
Dimensions:
o
o
o
o
Diameter: 5mm / 0.2"
Height (w/ pins): 23mm / 0.9"
Height (w/o pins): 11mm / 0.4"
Weight: 0.2g
Engineered in NYC Adafruit ® https://www.adafruit.com/product/2384 5‐5‐17
很抱歉,暂时无法提供与“2384”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9.952961+1.20641
- 国内价格 香港价格
- 7+9.933677+1.20407
