3.5mm (1/8") 4-Pole (TRRS) Audio Jack
Terminal Block
PRODUCT ID: 2915
Description
One truth about working with audio is you always need the cable or adapter you don't have in
your toolbox. That's why we love these terminal‐block audio connectors so much. No soldering
required! Use stranded or solid core wire and a small screw driver to create custom wiring jigs.
This is the 3.5mm (1/8") 4‐Pole (TRRS) Audio Jack Terminal Block. TRRS stands for Tip, Ring,
Ring, Sleeve. It has four total pins ‐ three signal and a ground as opposed to a more common
stereo jack's three. This type of connector is most often used in smartphones & cellphones to
provide stereo audio and one mic channel.
Note that the green block labels it as GND‐blank‐Right‐Left which is the most commonly used
order. However, it would be more technically correct to just label it Sleeve‐Ring‐Ring‐Tip: goes
in the same order as the four contacts on the plug.
We also have a (matching) 4‐Pole Audio Plug Terminal Block.
Technical Details
Note: As of Tuesday, April 12th 2016, this product is now gold plated instead of nickel plated.
o
o
Length (end to end): 35.6mm / 1.4"
Weight: 6.5g
https://www.adafruit.com/product/2915 7‐25‐17
很抱歉,暂时无法提供与“2915”相匹配的价格&库存,您可以联系我们找货
