Heavy Stainless Steel PCB Holder
PRODUCT ID: 3718
Are you still looking for that perfect PCB holder? The hefty yet
portable Heavy Stainless Steel PCB Holder will rock out when you rework
out. These were initially marketed for people doing cell phone repair and
rework and we've found this to be an excellent vise for SMT work in
particular (this holder is way nicer for thru-hole since you can flip the PCB
around) Can fit PCBs up to about 3.5" x 4" (90mm x 100mm)
This flat and dense vise is great because your hands can rest directly on
the work table, allowing you to steady yourself with minimal effort for
precise soldering and probing. The thick metal plate weighs 430 grams
(almost a pound!) and keeps it from moving around so you don't have to
worry about the PCB shifting while you're trying to heat up a stubborn
component.
Set the length of the three-piece bayonet slightly smaller than the size of
your PCB, compress the spring, slide the work-piece into place, and
release the springs. Easy, fast, and repeatable.
Features:
Hold your PCB flat – give your arms a rest! This vise holds your circuit
board flat so you can solder more easily at table/desk level.
Solid stainless steel body with grippy rubber feet
Could be used for self-defense if zombies start attacking you in the lab
Need to rework bigger, longer circuit boards? Take a gander at the Fully
Adjustable PCB Clamp Holder!
TECHNICAL DETAILS
Material: Stainless Steel sheet
Product Dimensions: 130.0mm x 90.0mm x 26.0mm / 5.1" x 3.5" x 1.0"
Product Weight: 431.0g / 15.2oz
https://www.adafruit.com/product/3718 5‐11‐18
很抱歉,暂时无法提供与“3718”相匹配的价格&库存,您可以联系我们找货
