40-pin ZIF socket
PRODUCT ID: 383
A ZIF (Zero Insertion Force Socket) allows you to insert and remove chips easily
from an existing circuits. These are often used for chip programmers or when
you need to test a chip without damaging it. Move the lever up and chips drop
right in. Move the lever down to 'latch' the chip in place.
This socket is designed for DIP chips of up to 40 pins and up to 0.6" wide. So
really, its good for any size chip you'll find. What's nice about it is it can snap
into an existing circuit board or socket that is designed for a 40-pin 0.6" chip
so you may not have to redesign the board! This socket is gold plated so it will
last a long time.
TECHNICAL DETAILS
Fits up to 40-pin DIP chips, in 0.3"-0.6" width
Overall body size: 0.9" x 2.6" x 0.46" (23mm x 66mm x 12mm) - not including
lever or pins
Pins are 0.6" apart (fit into a 0.6" socket) and 2.8mm (0.11") long
Fits and works in a breadboard!
We have a tutorial on using ZIF sockets to make a mass-programmer
https://www.adafruit.com/product/383 4-30-18
很抱歉,暂时无法提供与“383”相匹配的价格&库存,您可以联系我们找货
