Adafruit USB C Breakout Board Downstream Connection
PRODUCT ID: 4090
Throw out all those Mini and Micro B USB cables you have in a plastic bin - the
next generation of USB connectors is here with USB C! You will start to see these
connectors pop up on all sorts of devices, as the industry moves from micro B or
lightening to the new standard. Well, at least until the next standard comes out
USB C features a symmetric/reversible connector, more data pins and higher
current output capability. But, for most developers, the pin usage you know and
love from older USB will work just fine. This breakout gives you all the basics
you need and a resistor configuration that mimics classic USB 2.0 for
a downstream connection
The two 5.1K resistors on the CC1 pins indicate to the upstream port to provide
5V and up to 1.5A (whether the upstream can supply that much current depends
on what you're connecting to.
For most usages, you can just connect VBUS to your 5V input, GND to ground,
and D+ and D-as you expect. You can monitor the CC and SBU pins to
determine cable polarity, or send side-band data. Or leave them disconnected
For more details, we like this Introduction to USB C app
notehttp://ww1.microchip.com/downloads/en/appnotes/00001953a.pdf
Product Dimensions: 20.4mm x 14.2mm x 5.0mm / 0.8" x 0.6" x 0.2"
Product Weight: 1.3g / 0.0oz
https://www.adafruit.com/product/4090/3‐14‐19
很抱歉,暂时无法提供与“4090”相匹配的价格&库存,您可以联系我们找货
