4167
    ADAFRUIT
    LED 照明 COB、引擎、模块 LED 模块 - 蓝色 圆头,即插即用
4167 数据手册
          Fiber Optic Light Source - 1 Watt - Blue PRODUCT ID: 4167 This is a pretty neat way to glow up. Light in the fiber optic cable zooms through the core by constantly bouncing off of the edge of the molded plastic, a principle called "total internal reflection" (which also kinda sounds like a very expensive meditation island retreat). When the light pipe doesn't have total reflection, you can get a nifty lighting effect from the light illuminating the plastic tubing. All you need is a way to get a ton of photons into your light pipe, and that's what this is! It's Fiber Optic Light Source in a cute blue color. It's a high powered LED cluster, you need to power it with 9-12V and 100mA of current, the metal body acts as a heat sink. Then, installation is a breeze. Just loosen the clear knob on the LED emitter and slide one of our fiber optic tubes. Note: This is just the fiber optic LED. You'll also want to grab a fiber optic tube.                                                   https://www.adafruit.com/product/4167/4‐26‐19
很抱歉,暂时无法提供与“4167”相匹配的价格&库存,您可以联系我们找货
