Small -15 to +15V DC Analog Panel
Meter
PRODUCT ID: 4403
Analog panel meters are arguably not as blingy or flashy as LEDs, but their
simplicity adds a touch of elegance and makes them easier to read quickly.
This Small -15V to +15V Panel Meter is about handheld-size, with three screws
to open up the panel and replace the backing paper, if you like. It's great for
analog projects that have a split power supply or large voltage swings.
The back is constructed with two bolts the left coil is marked below with
Negative to distinguish the positive from the negative. You can wrap a wire
around the bolt and use the nuts to keep them in place, or use alligator clips.
TECHNICAL DETAILS
Panel Dimensions: ~60mm x 55mm x 10m
https://www.adafruit.com/product/4403/1‐13‐20
很抱歉,暂时无法提供与“4403”相匹配的价格&库存,您可以联系我们找货
