1276
    ADAFRUIT
    MICROSCOPE DGTL 5X-200X W/LIGHT
1276 数据手册
HoTech WIFI Wireless Digital Microscope S06-200X(WIFI) User Manual 文) CO NF ID EN (中 TI AL (English) Prepared by Coolingtech Digital Engineering Dept. 2012.10.25 1/21 HoTech WIFI Thank you for purchasing our S06-200X WIFI Wireless Digital Microscope; it can work on mobile device like tablet PC or mobile phone, which is WIFI capable and based on IOS or Android. This device is widely used in different fields including: 1. Textile industrial for textile inspection TI AL 2. Printing inspection 3. Industrial inspection: PCB, Precision machinery… 4. Educational purpose 6. Skin examination ID 7. Microbiological observation EN 5. Hair examination NF 8. Jewelry & coin (Collections) inspection 9. Visual Assistance CO 10. Others S06 Wireless Digital Microscope makes up the limitation of distance and can be used in a range within 10 to 30 meters. It is a perfect match with IOS mobile device (iPad, iPhone) and android mobile device (android tablet PC, android mobile phone). Please read below manual to get more detail about the microscope and follow the operation instructions. 2/21 HoTech WIFI CONTENTS Introduction ············································································2 Parts of Microscope ·······························································3 Specification ··········································································3 How to Use ············································································4 Notes before use ···································································5 TI AL Product Outlook & Standard parts ········································11 Parts of Microscope ID 3 NF 2 EN 1 CO 4 5 7 6 ① DC 5V socket ② Switch On/Off & light brightness adjust wheel ③ WIFI indicator light ④ Focus Roller ⑤ Ratio scale ⑥ Lens ⑦ LED Light source 3/21 HoTech WIFI Specification Image CMOS Sensor Controller: High Speed DSP (M-jpeg) Magnification Range 5X ~ 200X (Manually) Take Images: Snap shot in build-in application program TI AL Supplementary Light Source: Built-in 4~ 8 White-light LED and adjustable illumination ensure the magnified images are clear and bright Focus Range: 0mm ~ 40mm, other range can be customized WIFI Standard:IEEE 802.11 b/g/n standards compliant Video Capture Resolution: 0.3M. EN Still Image Capture Resolution: 640*480, can be magnified and minified ID Frame Rate: VGA 20 f/s Under 600 LUX Brightness NF Fixed Foundation: Tailor-made for the microscope Brightness Control: Manual adjustment CO Power Supply: Rechargeable 1000mA self-protection lithium battery Support O/S: WIFI capable, such as IOS and Android Language: English (other language can be customized) Application Software: HotViewer Illumination Scope: 0 ~ 30000LUX Product Dimension: 142 mm ( L ) X 37 mm ( R ) Product Net Weight: 100g Available Color: Deep blue 4/21 HoTech WIFI How to Use 1 Instruction for the Download the “NetcamViewer” from APP store Type “NetcamViewer” in APP store search tool bar and search NetcamViewer CO NF 2 ○ ID EN TI AL 1 ○ IOS platform (iPad for example) 5/21 HoTech EN TI AL WIFI CO NF ID 3 After installation, below icon appears in the application desk. ○ 6/21 HoTech 4 ○ WIFI Click “NetcamViewer”and do Parameter Setting NF ID EN TI AL HOT CO Username andHOT Password both are “HOT” HOT 7/21 HoTech WIFI .on right above, then all setting Once the setting is finished, click the Icon is completed. 2 Turn on the switch, and adjust to the max brightness Switch EN TI AL WIFI Indictor Wifi Indictor(Green LED)Light on 5 seconds later, it start flicker then wireless CO NF ID signal transmitting is working normally. (SSID is HOT) 3 wireless (WIFI) signal connecting: Turn on the receiving end on iPad and start setting, find the wireless signal “HOT” and click “connect”. 8/21 HoTech WIFI SSID:HOT TI AL SSID:HOT EN After 3~5sec, the connection is ok, and the wireless signal will appear CO NF ID icon, you will see the corresponding image. Then you can take 5 Click the picture or do other operations. 9/21 HoTech EN TI AL WIFI 6 If you don’t want to download and install the“NetcamViewer” application, you can ID open the safari and Input the web address “10.10.1.1:8196” into the address Column and you can get into the website ,then you can browse the pictures directly Username and password : HOT NF 7 For the Android platform, when use for the first time, you need install the application to your mobile device, the application contains in CO “HotViewer” the CD. Turn on the receiving end mobile and start setting, find the wireless signal “Hot” and click “connect”. then Click the icon , then you can start the use. Notes before use 1. Don’t dissemble the digital Microscope or change the interior parts, it can cause damage. 2. Don’t clean the Microscope with alcohol organic solvents 3. Don’t touch the lens with your fingers. 10/21 HoTech WIFI 4. Avoid outdoor use if possible. 5. Storage temperature, 0°C ~ 40°C, Humidity: 45%RH ~ 85RH%. 6. In case the product gets wet, leave PC connection immediately. And do not dissemble or dry by hair dryer. Send to repair center if the digit microscope was affected by liquid or other elements. 7. Wireless signal range within 30 m Standard parts and accessories TI AL 1. Digital Microscope (1pc) 2. Charger (1pc) include power line 3. Special base (1pc) EN 4. CD ROM (application “HotViewer)” for android and installation user manual ID 5. Warranty card (1pc), quick guide (1pc) CO NF Any questions, please E-mail: yiwen@hot183.com 11/21 HoTech WIFI 非常感谢贵司( 您)购买了S06-200X无线(WIFI)数 码显微镜,WIFI无线数码显微镜主要针对便携式移动设备带 WIFI信号的平板电脑和手机。非常便利。无线数码显微镜应 用范围非常广泛,主要有以下方面. 1工业方面: TI AL a 工业检视,例如电路板、精密机械等 b 印刷检视,SMT焊接检查 c 纺织检视 d IC表面检查 …… 3生物应用 CO 4其它 NF a微生物观察 b动物切片观察 …… ID a皮肤检视 b发根检视 C红外理疗(特定产品) …… EN 2美容方面 a扩视器,协助视障人士阅读 b宝石鉴定 …… S06无线数码显微镜弥补了有线数码显微镜的距离限制,能够在空间 10~30m的环境内,在IOS系统的平板和手机(如Ipad 和 Iphone),andriod 系统的平板和手机上使用,非常的方便。为了更详细的介绍本产品,敬请耐 心的阅读产的产品介绍,使用方法,注意事项。 12/21 HoTech WIFI 目 录 首页·························································································· 12 前言·························································································· 12 目录·························································································· 13 各部位介绍 ·············································································· 13 TI AL 产品规格··················································································· 14 使用说明····················································································15 安全警告及注意事项 ································································ 21 ·················································································21 EN 配件说明 各部位说明 NF ID 1 3 CO 2 4 5 7 6 ① DC5V插座 ② 开关和调光旋钮 ⑤ ⑥ 镜头 倍率刻度 ③充电和WIFI信号指示灯 ④ 调焦滚轮 ⑦ 辅助光源灯罩 13/21 HoTech WIFI 规格: 传 感 器 : 高性能外国进口感光芯片 主控芯片 : 专用主控DSP 放大倍率 : 5X ~ 200X 拍照/录像: 应用程序内置 辅助光源 : 4 ~ 8颗白光LED灯 成像距离 : TI AL 静态分辨率: 640*480,可根据自己的要求做放大和缩小处理 手动调节0~40mm,其他距离可定制 影像分辨率 :640*480,可根据自己的要求做放大和缩小处理 特制底座 光 含应用软件及说明书 支持系统 : 电 源 : 内置1000mA自保护锂电池 hotviewer NF 应用程序 : 基于IOS系统和andriod系统的平板电脑和手机 ID 盘 : EN 固定底座 : CO 动态帧数 : 照度范围 : QVGA 30f/s Under 600 LUX Brightness VGA 20 f/s Under 600 LUX Brightness 0 ~ 30000LUX线控可调 硬件需求 : 主频700M Hz以上,1G硬盘 CD ROM 光驱; 64MB 内存 支持语言:英文(其它语言需要定制) 产品颜色:深蓝色 主体尺寸:142mm (L)* 37mm ( R) 单机净重: 100g 14/21 HoTech WIFI 使用说明: 1 打开电源开关,将光线调整到最亮 开关和调光旋钮 EN TI AL WIFI 指示灯 图1 图2 NetcamViewer 软件下载 CO NF 1 ○ ID 2 LED绿色指示灯开始亮起,3~5S 后,LED灯开始闪烁,代表WIFI信号 发射正常 3 针对IOS系统(IPAD)为列,做如下说明: 15/21 HoTech 在 APP store 中 ,搜索栏中输入 NetcamViewer CO NF ID EN TI AL 2 ○ WIFI 16/21 HoTech WIFI 点击NetcamViewer,进行一些参数设置 NF ID 4 ○ EN TI AL 3 安装后,应用程序面会出现如下图标 ○ CO HOT 17/21 HoTech WIFI HOT CO NF ID EN 用户名同密码一致,都是HOT TI AL HOT 击右上方按钮 就完成设置了 18/21 HoTech WIFI EN TI AL 4 进行WIFI信号连接,点击Settings ID 3~5S后在Network中选中SSID为HOT SSID:HOT CO NF SSID:HOT 5 WIFI 信号连接后,点击应用图面上的 ,就可以正常使用了 如下图 19/21 HoTech CO NF ID EN TI AL WIFI 6 WIFI信号连接后,如果不想下载AP软件NetcamView,可直接在Safari中, IP地址栏中直接输入10.10.1.1:8196,就可以再网页中直接浏览图像。 如果需要输入用户名和密码的,直接输入HOT 20/21 HoTech WIFI 7 针对android系统的平台,将光盘中的AP软件HotViewer,直接安装到相应 的平板电脑或手机中应用程序免会出现相应的图标。使用方式同之前一致. 打开显微镜开光---将光线亮度调到最大----左侧LED灯开始闪烁,标示信 号正常了.设置--Wifi--SSID为HOT,连接。然后直接点击应用程序的图 标 就可以正常使用了 安全警告及注意事项 1. 勿拆解本产品,以避免静电击穿精密芯片。 2. 勿用酒精等有机溶剂清洁产品。 TI AL 3. 勿用手指触摸镜头,以免表面造成刮痕和脏污 4. 户外使用时应避免高温和高湿环境中,防电子器件短路。 本产品不具有防水功能,请应避免淋雨和进水。 EN 5. 本产品的使用和存储温适度范围:0°C ~ 40°C,相对湿度:45%RH ~ 85%RH ID 6. 若不慎使异物或水分/液体 进入数产品内部,立即断开电源并送至维 修中心检修,切勿自行处理。 7 设备测量精度仅供参照,由测量误差引起的纠纷与本产品无关。 NF 8 本产品有效距离在10~30m之内。 配件说明 CO 1. 无线(WIFI)数码显微镜(1台) 2. 专用底座一台 3. 充电器一台 4 光盘(安装说明书) 5. 保修卡一份,快速使用指南一份 如有其它问题,请E-mail:yiwen@hot183.com, 我们会第一时间详细的解释说明。 21/21
很抱歉,暂时无法提供与“1276”相匹配的价格&库存,您可以联系我们找货
