MM-300-UC25-H
MM-300-UC25-H
    AEARO
    圆形支座 有螺纹 1/4"-20 合成橡胶 0.625"(15.88mm)5/8" 黑色
MM-300-UC25-H 数据手册
Male-Male Sandwich Mounts P L Male-Female Sandwich Mounts P P Female-Blank Sandwich Mounts L L P D D G Male-Blank Sandwich Mounts L D G G G TD Family Product D Load (lbs) TD Dimensions Metal Insert D L P G TD Maximum Compressive Maximum Shear Diam. (in) Length (in) Type Overall Height Grip (in) Depth (in) MM-100-UC04-H MM-100-UC04-SL20100 MM-100-UC04-SL25200 MM-200-UC06-H MM-200-UC06-SL20100 MM-200-UC06-SL25200 MM-200-UC08-H MM-200-UC08-SL20100 MM-200-UC08-SL25200 MM-300-UC25-H MM-400-UC31-H 4.0 0.5 0.5 8.0 1.0 1.0 8.0 1.0 1.0 20.0 50.0 1.5 0.2 0.2 3.0 0.4 0.4 3.0 0.4 0.4 5.0 13.0 .275 .280 .280 .400 .405 .405 .400 .405 .405 .615 1.00 .320 .320 .320 .500 .500 .500 .500 .500 .500 .625 .750 #4-40 #4-40 #4-40 #6-32 #6-32 #6-32 #8-32 #8-32 #8-32 1/4-20 5/16-18 .200 .200 .200 .375 .375 .375 .375 .375 .375 .500 .625 .060 .060 .060 .060 .060 .060 .060 .060 .060 .100 .100 n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a MB-100-UC04-H MB-100-UC04-SL20100 MB-100-UC04-SL25200 MB-200-UC06-H MB-200-UC06-SL20100 MB-200-UC06-SL25200 MB-200-UC08-H MB-200-UC08-SL20100 MB-200-UC08-SL25200 MB-300-UC25-H MB-400-UC31-H 4.0 0.5 0.5 8.0 1.0 1.0 8.0 1.0 1.0 20.0 50.0 .275 .280 .280 .400 .405 .405 .400 .405 .405 .615 1.00 .320 .320 .320 .500 .500 .500 .500 .500 .500 .625 .750 #4-40 #4-40 #4-40 #6-32 #6-32 #6-32 #8-32 #8-32 #8-32 1/4-20 5/16-18 .200 .200 .200 .375 .375 .375 .375 .375 .375 .500 .625 .060 .060 .060 .060 .060 .060 .060 .060 .060 .100 .100 n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a Male-Female MF-100-UC04-H MF-100-UC04-SL20100 MF-100-UC04-SL25200 MF-200-UC06-H MF-200-UC06-SL20100 MF-200-UC06-SL25200 MF-200-UC08-H MF-200-UC08-SL20100 MF-200-UC08-SL20100 MF-300-UC25-H MF-400-UC31-H 2.0 0.3 0.3 4.0 0.6 0.6 4.0 0.6 0.6 12.0 45.0 .275 .280 .280 .400 .405 .405 .400 .405 .405 .615 1.00 .320 .320 .320 .500 .500 .500 .500 .500 .500 .625 .750 #4-40 #4-40 #4-40 #6-32 #6-32 #6-32 #8-32 #8-32 #8-32 1/4-20 5/16-18 .200 .200 .200 .375 .375 .375 .375 .375 .375 .500 .625 .060 .060 .060 .060 .060 .060 .060 .060 .060 .100 .100 .110 .110 .110 .160 .160 .160 .160 .160 .160 .260 .290 Female-Blank FB-100-UC04-H FB-100-UC04-SL20100 FB-100-UC04-SL25200 FB-200-UC06-H FB-200-UC06-SL20100 FB-200-UC06-SL25200 FB-200-UC08-H FB-200-UC08-SL20100 FB-200-UC08-SL25200 FB-300-UC25-H FB-400-UC31-H 2.0 0.3 0.3 4.0 0.6 0.6 4.0 0.6 0.6 12.0 45.0 .275 .280 .280 .400 .405 .405 .400 .405 .405 .615 1.00 .320 .320 .320 .500 .500 .500 .500 .500 .500 .625 .750 #4-40 #4-40 #4-40 #6-32 #6-32 #6-32 #8-32 #8-32 #8-32 1/4-20 5/16-18 n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a .110 .110 .110 .160 .160 .160 .160 .160 .160 .260 .290 ISOLOSS SPR-00009 HD/SL SANDWICH MOUNTS Male-Male Male-Blank 材質 ISOLOSS HD 數量100, 200 n/a n/a n/a n/a n/a n/a 0.8 0.1 0.1 2.0 0.3 0.3 2.0 0.3 0.3 3.5 10.0 n/a n/a n/a n/a n/a n/a “H” after part number indicates ISOLOSS HD material; “SL-XXXXX” after part number indicates ISOLOSS SL material. Dimensions given here are nominal. Exact specification print available on request. 13 Website: www.earsc.com E-mail: solutions@earsc.com 7911 Zionsville Road Indianapolis, IN 46268 Phone (317) 692-1111 Fax (317) 692-3111 650 Dawson Drive Newark, DE 19713 Phone (302) 738-6800 Fax (302) 738-6811 M o l d i n g M a t e r i a l s / C u s t o m Fo r c u s t o m - engineered parts to control noise, vibration or shock, E-A-R offers numerous moldable thermoplastic and thermoset materials to choose from. VersaDamp 2000 Series TPEs are olefinic dynamic vulcanizates. They are usually selected to optimize damping performance or durometer or both. The materials eliminate the need to make tradeoffs in damping and operating temperature range. They feature durometers ranging from 40 Shore Ato 74 Shore A, and they have widely varying energy control capabilities. Thermoplastics: ISODAMP C-1000 Series Thermoplastics are highly damped vinyl materials that exhibit extremely low amplification at resonance and quick return to system equilibrium after shock input. C-1000 Series materials are soft and pliable, yet physically strong and wear-resistant. The three formulations are engineered to perform in discrete temperature ranges: ISODAMP C-1002 from 13C to 41C (55F to 105F); C-1105 from 27C to 54C (80F to 130F); and C-1100 from 35C to 63C (95F to 145F). Description Typical Process Method Peak Transmissibility at Resonance (dB) Hardness Nominal ASTM D2240 15 sec impact at 23C (73F) Shore A Durometer Bashore Resilience 1st Rebound (%) Tensile Strength (psi) Elongation (%) Post Compression Recovery (%) at 20C (68F) Resistance to: Ozone Water UV Kerosene Thermosets: ISOLOSS HD Elastomers exhibit excellent load bearing strength, compression-set resistance and stiffness stability over a broad temperature range. With a recommended maximum continuous operating temperature of 90C (195F), the materials can withstand intermittent exposure as high as 107C (225F). Designed specifically for use in metal-bonded elastomeric mounts, these elastomers exhibit excellent environmental-resistance properties. ISODAMP C-8000 Series Thermoplastics are highly damped elastomers that provide the same benefits of the C-1000 series materials in a halogen-free formulation. They are also formulated to be environmentally clean; providing excellent flammability performance (UL 94 V-0) without halogens, silicones or metal oxides. This unique family of elastomers will meet most of the emerging environmentally “green” initiatives and specifications. ISODAMP C-8000 materials have a peak performance temperature range of 17C to 41C (62F to 105F). Typical Properties Property P a r t s ISOLOSS SL Thermoset Materials combine good damping performance with stable material properties over a broad temperature range. The molding stability of ISOLOSS SL materials allows it to be used in isolator and snubber designs with very thin sections. ISODAMP ISODAMP ISODAMP ISODAMP VersaDamp VersaDamp VersaDamp C-1002 C-1105 C-1100 C-8002 V-2325 V-2590 V-2725 ISOLOSS HD Vinyl Solid Injection Mold Vinyl Solid Injection Mold Vinyl Solid Injection Mold TPE Solid Injection Mold TPE Solid Injection Mold TPE Solid Injection Mold TPE Solid Injection Mold 3 3 3 3 13 7 11 4 56 63 70 57 40 57 74 58 4.8 1574 459 5.4 1807 417 5.7 2058 317 4.0 1150 750 40 380 278 12.0 653 344 35 976 381 86 77 76 82 90 85 Good Good Good Fair Good Good Good Fair Good Good Good Fair Good Good Fair Poor Good Good Good Poor Good Good Good Poor ISOLOSS SL-20100 ISOLOSS SL-25200 Urethane Synthetic Synthetic Solid Rubber Rubber Transfer/ Transfer/ Transfer/ Compression Compression Compression Mold Mold Mold 7 7 21 27 4.5 1300 424 12 530 625 12 636 600 80 96 97 97 Good Good Good Poor Good Good Good Fair Good Good Good Poor Good Good Good Poor See material summary sheets for more data and testing method information. The data listed in this guide are typical or average values based on tests conducted by independent laboratories or by the manufacturer. They are indicative only of the results obtained in such tests and should not be considered as guaranteed maximums or minimums. Materials must be tested under actual service to determine their suitability for a particular purpose. Website: www.earsc.com E-mail: solutions@earsc.com 7911 Zionsville Road Indianapolis, IN 46268 Phone (317) 692-1111 Fax (317) 692-3111 650 Dawson Drive Newark, DE 19713 Phone (302) 738-6800 Fax (302) 738-6811 14
MM-300-UC25-H 价格&库存
很抱歉,暂时无法提供与“MM-300-UC25-H”相匹配的价格&库存,您可以联系我们找货
