LZE-19-013-A-00-10-S 数据手册
For use in:
Packaging Equipment
Automation Systems
Assembly Machinery
Hydraulic Cylinders
LZ-19 Series
LVIT Linear Position Sensor
Through-bore LVIT Linear Position Sensor for applications needing superior stroke-to-body-length
The LZ-19 Series of LVIT (Linear Variable Inductance Transducer) position sensors are contactless
devices designed for use in factory automation or assembly machinery applications where space is
a premium, as well as for external mounting on hydraulic cylinders to sense rod position. The LVIT is
offered in nominal full scale ranges from 2.5 to 750 mm (0.100 to 30 inches) with an excellent stroketo-length ratio. The sensor has a 19.0 mm (3/4 inch) outside diameter aluminum or optional stainless
steel body with a 1m axial cable for I/O connections. The 7.5 mm (0.295 inch) diameter through-bore
of an LZ-19 provides clearance for its 6.00 mm (0.236 inch) diameter moving rod, which is made of the
same material as its housing. This through-bore feature also means that the sensor is not subject to
damage from typical mechanical overstroking.
Technical datasheets and additional information can be found at www.alliancesensors.com
Features:
• Contactless operation prevents internal wearout from dithering or rapid cycling
• LVIT Technology™ (Linear Variable Inductance Transducer)
• Through-bore design eliminates mechanical over stroking
• Full Scale ranges from 2.5 to 750 mm (0.100 to 30 inches)
• Proprietary SenSet™ field adjustable range scaling
• DC in / DC out operation with built-in electronics
• Excellent stroke-to-body-length ratio
Specifications:
Analog I/Os
Measuring Ranges
Linearity Error
Resolution
Update Rate
Terminations
0 – 5 V or 0.5 – 4.5 V DC output; 8 – 30 V input, 35 mA max,
0 – 10 V DC output; 12 – 30 V input, 35 mA max
4 – 20 mA (3-wire) output; 18 – 30 V input, 60 mA max. (75 C max)
12.5 to 900 mm (1/2 to 36 inches) full scale
≤±0.15% of Full Scale Output (FSO) typical, ±0.25% max
0.025% of FS
300 Hz nominal
IEC IP-67
All specifications are subject to change without notice.
© Alliance Sensors Group, 2018
Rev. 07272018
LZ-19 Series
Specifications Con’t:
Operating Temperature
Temperature Coefficient
Humidity
Shock
Vibration
LZ-19 Range
Table
Nominal Range
Length “A”
Inches
Inches (mm)
mm
0.10
2.5
1.38 (35.0)
0.20
5.0
1.38 (35.0)
0.30
7.5
1.38 (35.0)
0.40
10
1.38 (35.0)
0.50
12.5
1.38 (35.0)
0.60
15
1.38 (35.0)
0.80
1.00
25
1.38 (35.0)
1.20
30
1.63 (41.3)
2.00
50
2.38 (60.5)
3.00
75
3.38 (85.9)
4.00
100
4.38 (111.1)
6.00
150
6.50 (165.1)
8.00
200
8.50 (215.9)
10.00
250
10.50 (266.7)
12.00
300
12.50 (317.5)
15.00
375
15.75 (400.0)
18.00
450
18.75 (476.2)
24.00
600
25.00 (635.0)
30.00
750
31.00 (787.4)
-20 to 85 C (-40 to 105 C Extended Range)
≤±0.015% of FS/C
95% RH, non-condensing
1000 gs, 11 msec.
5-20 Hz 0.5 inch p-p; 20-2000 Hz 4.2 g p-p
ASSEMBLY
LZ-19 Connection Table
I/O Function
Color
+Power Input
Red
Ground
Black
Analog output
Green
SenSet ™
White
Shield/ drain*
Shield
CORE
*Shield unconnected internally
Ordering Information:
Housing
Diameter
Electrical Termination
Range
(mm)
Series
Output
LZ
X-
XX-
XXX-
X-
XX-
E- Voltage
19 - 19 mm
2.5 - 15mm
A - Axial
00 - 1 m cable 05 - 0.5 to 4.5 V
I - Current
(2.5mm increments)
Axial
Termination
Housing/Rod
Material
Output
XX-
06 - 4.5 to 0.5 V
X-
A - Aluminium
S - 300 Series SS
10 - 0 to 10.0 V
15 – 30mm
11 - 10.0 to 0 V
(5mm increments)
20 - 4 to 20 mA
21 - 20 to 4 mA
050 - 300
50 - 0 to 5 V
(50mm increments)
51 - 5 to 0 V
300 - 450
(75mm increments)
450 - 750
(150mm increments)
Rev. 07272018
LZE-19-013-A-00-10-S 价格&库存
很抱歉,暂时无法提供与“LZE-19-013-A-00-10-S”相匹配的价格&库存,您可以联系我们找货
