P1A-140703S
P1A-140703S
    NEWAGE
    MICRO UTILITY
P1A-140703S 数据手册
NOTES: UNLESS OTHERWISE SPECIFIED REV. DRAWN BY 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. A M BOYER B 3. INTERIOR SURFACE TEXTURE TO BE: NONE. 4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX, UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. R E V I S I O N DESCRIPTION ECO No DATE APPROVED PRELIMINARY RELEASE 26-Feb-10 D.C. M BOYER DESIGN ROUND PCB STANDOFFS ON BASE 25-Oct-10 D.C. C M BOYER MODIFY PCB RIBS 28-Sep-10 D.C. D M BOYER UPDATE FORMAT 29-Sep-10 D.C. E M BOYER UPDATE PCB STANDOFF 13-Dec-10 D.C. F M BOYER ADD DIMENSIONS 09-Apr-11 D.C. UPDATE TO AS-BUILT, RELEASED TO PRODUCTION 14-Jun-11 D.C. ADD STANDARD CONFIG DETAILS 30-Jun-11 1.0 M BOYER 1.1 M BOYER DR XXX 2411 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM. P140703(x) CONFIGURATIONS -S P140703 COVER 1 P140703 COVER w/ TYPE A USB P140703 BASE 1 P140703 BASE w/ TYPE A USB 2 -U 1 3 1 1 SCALE 2.000 140703U w/ TYPE A USB OPENING SHOWN SCALE 2.000 140703S w/ CUTOUT FOR MALE MICRO USB SHOWN (EXAMPLE) SCALE 2.000 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DO NOT SCALE DRAWING 3 140703 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 140703U COVER - STANDARD ABS BLACK or WHITE 1 1 140703U BASE - STANDARD ABS BLACK or WHITE 1 ITEM DESCRIPTION MATERIAL COLOR QTY. BILL OF MATERIALS NEW AGE ENCLOSURES Customer's Part No: NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE APPROVAL PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CHECK CONTROL THAT THIS DOCUMENT WILL ENG. NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC SCALE POSSESSION OF THIS DOCUMENT DOES DRAWN BY NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2011 M BOYER BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE AS NOTED SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 1 OF 6 REV.DOC 1.1 140703 ASSEMBLY .480 (.505) .337 .183 1.420 TYPE A USB OPENING Y .078 .277 Y J SCALE SCALE 2.000 .700 J 2.000 R.015 .141 .016 TWO POSTS PROTRUDE FROM THE BASE TO CAPTURE THE PCB. THE STANDARD PCB THICKNESS IS 0.062" BUT THESE POSTS CAN BE MOLDED AT VARIOUS LENGTHS TO ACCOMODATE VARIOUS PCB THICKNESSES. PLEASE ASK YOUR SALES REPRESENTIVE FOR A QUOTE. 140703-S STANDARD ENCLOSURE WITH CUSTOM OPENING FOR MALE MICRO USB .031 SECTION J-J SECTION Y-Y TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 2 OF 6 REV.DOC 1.1 140703 COVER SCALE 2.000 .058 3.0° 5.0° TYPE A USB OPENING IS OPTIONAL. STANDARD VERSION (S) IS MOLDED WITH NO OPENING .048 SECTION Y-Y .478 R.095 P .160 .200 P .041 SECTION .020 P-P .062 ±.0005 4 PLACES NO DRAFT .710 .375 .000 .375 .710 .123 .350 .250 .120 .000 Y TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. Y .250 .350 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 3 OF 6 REV.DOC 1.1 140703 BASE SCALE TYPE A USB OPENING IS OPTIONAL. STANDARD VERSION (S) IS MOLDED WITH NO OPENING 2.000 3.0° OPENING FOR TYPE A USB SHOWN SECTION .063 PCB STANDOFF .058 .006 CHAMFER 4 PLACES 5.0° .021 Y-Y .625 K .081 .159 SECTION .125 .710 .598 2x .375 2x .000 .375 2x .710 .480 .515 2x K K-K .062 ±.0005 4 PLACES NO DRAFT .350 .250 2x .225 2x .000 Y Y .225 2x .250 2x .350 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE CHECK .062 2x ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 4 OF 6 REV.DOC 1.1 140703 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. .080 1.215 .625 .375 .000 +.001 KEEP OUT -.001 .375 .625 .595 .135 KEEP OUT .263 .250 .225 .000 .075 .225 SCALE (.477) .250 .263 2.000 (.050) SUGGESTED TYPE-A USB CONNECTOR ACON ADVANCED CONNECTEK INC. PN. C-UAR70-OO-OO .030 x45° TYP. .030 MAX .740 (.178) .063 .513 .005 (.590) TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 5 OF 6 REV.DOC 1.1 2nd OPERATION DETAILS NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 140703 COVER SCALE 2.000 140703 BASE SCALE 2.000 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL STEP NO 1-C-C1 PXX-140703-XXX COVER DESCRIPTION - CUTTER T2 = .062" EM - ABS, BLACK FIXTURE 278 ORIENTATION - BY 4330 Santa Fe Road ph. (805) 595-1310 STANDARD - MICRO USB PXX-140703 ASSEMBLY DATE CHECK ENG. PROGRAM - SCALE AS NOTED DRAWN BY M BOYER SIZE 26-Feb-10 San Luis Obispo, CA. 93401 fax (805) 595-1024 www.newageenclosures.com 140703 DRAWING NAME A 140703_R1_1 SHEET 6 OF 6 REV.DOC 1.1
P1A-140703S 价格&库存
很抱歉,暂时无法提供与“P1A-140703S”相匹配的价格&库存,您可以联系我们找货
