NOTES: UNLESS OTHERWISE SPECIFIED
REV. DRAWN BY
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
A
M BOYER
B
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
4. ALL INSIDE RADII .010R. ALL OUTSIDE RADII .020R MAX,
UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT
THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES
AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11010.
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE
UNLESS OTHERWISED SPECIFIED.
R E V I S I O N
DESCRIPTION
ECO No
DATE
APPROVED
PRELIMINARY RELEASE
26-Feb-10
D.C.
M BOYER
DESIGN ROUND PCB STANDOFFS ON BASE
25-Oct-10
D.C.
C
M BOYER
MODIFY PCB RIBS
28-Sep-10
D.C.
D
M BOYER
UPDATE FORMAT
29-Sep-10
D.C.
E
M BOYER
UPDATE PCB STANDOFF
13-Dec-10
D.C.
F
M BOYER
ADD DIMENSIONS
09-Apr-11
D.C.
UPDATE TO AS-BUILT, RELEASED TO PRODUCTION
14-Jun-11
D.C.
ADD STANDARD CONFIG DETAILS
30-Jun-11
1.0
M BOYER
1.1
M BOYER
DR XXX
2411
7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT
CLOSURE: A DROP ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND
VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF OEM.
P140703(x) CONFIGURATIONS
-S
P140703 COVER
1
P140703 COVER w/ TYPE A USB
P140703 BASE
1
P140703 BASE w/ TYPE A USB
2
-U
1
3
1
1
SCALE
2.000
140703U w/ TYPE A USB
OPENING SHOWN
SCALE 2.000
140703S w/ CUTOUT FOR MALE
MICRO USB SHOWN (EXAMPLE)
SCALE 2.000
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
DO NOT SCALE DRAWING
3
140703 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
140703U COVER - STANDARD
ABS
BLACK or WHITE
1
1
140703U BASE - STANDARD
ABS
BLACK or WHITE
1
ITEM
DESCRIPTION
MATERIAL
COLOR
QTY.
BILL OF MATERIALS
NEW AGE ENCLOSURES
Customer's Part No:
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE APPROVAL
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND CHECK
CONTROL THAT THIS DOCUMENT WILL
ENG.
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC SCALE
POSSESSION OF THIS DOCUMENT DOES
DRAWN BY
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2011
M BOYER
BY
4330 Santa Fe Road
ph. (805) 595-1310
STANDARD - MICRO USB
PXX-140703 ASSEMBLY
DATE
AS NOTED
SIZE
26-Feb-10
San Luis Obispo, CA. 93401
fax (805) 595-1024
www.newageenclosures.com
140703
DRAWING NAME
A 140703_R1_1
SHEET
1 OF 6
REV.DOC
1.1
140703 ASSEMBLY
.480
(.505)
.337
.183
1.420
TYPE A
USB OPENING
Y
.078
.277
Y
J
SCALE
SCALE 2.000
.700
J
2.000
R.015
.141
.016
TWO POSTS PROTRUDE FROM THE BASE
TO CAPTURE THE PCB. THE STANDARD
PCB THICKNESS IS 0.062" BUT THESE
POSTS CAN BE MOLDED AT VARIOUS
LENGTHS TO ACCOMODATE VARIOUS PCB
THICKNESSES. PLEASE ASK YOUR
SALES REPRESENTIVE FOR A QUOTE.
140703-S
STANDARD ENCLOSURE WITH
CUSTOM OPENING FOR
MALE MICRO USB
.031
SECTION
J-J
SECTION
Y-Y
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
PXX-140703 ASSEMBLY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
26-Feb-10
fax (805) 595-1024
140703
DRAWING NAME
A 140703_R1_1
SHEET
2 OF 6
REV.DOC
1.1
140703 COVER
SCALE
2.000
.058
3.0°
5.0°
TYPE A USB OPENING IS
OPTIONAL. STANDARD VERSION
(S) IS MOLDED WITH NO OPENING
.048
SECTION
Y-Y
.478
R.095
P
.160
.200
P
.041
SECTION
.020
P-P
.062 ±.0005
4 PLACES
NO DRAFT
.710
.375
.000
.375
.710
.123
.350
.250
.120
.000
Y
Y
.250
.350
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
PXX-140703 ASSEMBLY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
26-Feb-10
fax (805) 595-1024
140703
DRAWING NAME
A 140703_R1_1
SHEET
3 OF 6
REV.DOC
1.1
140703 BASE
SCALE
2.000
3.0°
OPENING FOR
TYPE A USB
SHOWN
SECTION
.063 PCB STANDOFF
.058
.006 CHAMFER
4 PLACES
5.0°
.021
Y-Y
.625
K
.081
.159
SECTION
.125
.710
.598 2x
.375 2x
.000
.375 2x
.710
.480
.515 2x
K
K-K
.062 ±.0005
4 PLACES
NO DRAFT
.350
.250 2x
.225 2x
.000
Y
Y
.225 2x
.250 2x
.350
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
PXX-140703 ASSEMBLY
DATE
CHECK
.062 2x
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
26-Feb-10
fax (805) 595-1024
140703
DRAWING NAME
A 140703_R1_1
SHEET
4 OF 6
REV.DOC
1.1
140703 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
.080
1.215
.625
.375
.000
+.001
KEEP OUT
-.001
.375
.625
.595
.135 KEEP OUT
.263
.250
.225
.000
.075
.225
SCALE
(.477)
.250
.263
2.000
(.050)
SUGGESTED TYPE-A USB CONNECTOR
ACON ADVANCED CONNECTEK INC.
PN. C-UAR70-OO-OO
.030 x45° TYP.
.030 MAX
.740
(.178)
.063
.513
.005
(.590)
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
4330 Santa Fe Road
ph. (805) 595-1310
PXX-140703 ASSEMBLY
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
26-Feb-10
fax (805) 595-1024
140703
DRAWING NAME
A 140703_R1_1
SHEET
5 OF 6
REV.DOC
1.1
2nd OPERATION DETAILS
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
140703 COVER
SCALE 2.000
140703 BASE
SCALE 2.000
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
STEP NO
1-C-C1
PXX-140703-XXX COVER
DESCRIPTION
CUTTER
T2 = .062" EM
ABS, BLACK
FIXTURE
278
ORIENTATION
BY
4330 Santa Fe Road
ph. (805) 595-1310
PXX-140703 ASSEMBLY
DATE
CHECK
ENG.
PROGRAM
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
26-Feb-10
fax (805) 595-1024
140703
DRAWING NAME
A 140703_R1_1
SHEET
6 OF 6
REV.DOC
1.1
很抱歉,暂时无法提供与“P3A-140703U”相匹配的价格&库存,您可以联系我们找货
