P3A-20100562U
P3A-20100562U
    NEWAGE
    USB DEVICE
P3A-20100562U 数据手册
From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution. Let us quote modifiying our Stock Enclosures to meet your end-use. visit newageenclosures.com/services or call 855-4NA-ENCL today. NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED REV. DRAWN BY DATE APPROVED 1 M BOYER PRELIMINARY RELEASE 21-May-07 D.C. 2 M BOYER ADD WIDE PCB CONFIGURATION 06-Jun-07 D.C. 3 M BOYER MOVE PCB POSTS OUTWARD .03 PER SIDE 30-Jul-07 D.C. 4 M BOYER UPDATE TO AS BUILT 12-Oct-07 D.C. 5 M BOYER 0208 UPDATE FORMAT AND RELEASE 04-Apr-08 D.C. 5.1 M BOYER 0710 UPDATE FORMAT 30-Mar-10 D.C. 5.2 M BOYER 0810 ADD NOTE 10 08-Apr-10 D.C. 6.0 M BOYER 2910 UPDATE BOARD THICKNESS INFORMATION 16-Aug-10 D.C. 6.1 M BOYER 3010 DOCUMENT CHANGE 24-Aug-10 D.C. 6.2 M BOYER 2711 CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT" 21-Oct-11 D.C. 7.0 M BOYER 1913 INCLUDE .062" PCB OPTION 09-Apr-13 D.C. 7.1 R CRUZ 8713 REMOVE .062" COVER OPTION 18-Dec-13 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010. 3. INTERIOR SURFACE TEXTURE: NONE 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. 6. 1 DEGREES DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. ECO No DESCRIPTION 8. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 10. THE GATE REMNANT FOR THIS ENCLOSURE IS LOCATED IN THIS POSITION TO MINIMIZE ANY COSMETIC IMPACT. IT IS HOWEVER VISIBLE AND VARIES IN SIZE / SHAPE. IT IS EASILY REMOVED WITH CLIPPERS. IF YOU WOULD LIKE NEW AGE TO CLIP THIS FOR YOU, PLEASE ASK YOUR SALES REPRESENTIVE FOR A FREE QUOTE. NOTE 10 OPTIONAL USB OPENING 2 3 SCALE 1.500 P201005(x) CONFIGURATIONS -S -U -62S -62U 201005 201005 201005 201005 201005 201005 COVER COVER w/ USB OPENING BASE BASE (.062" PCB) BASE w/ USB OPENING BASE (.062" PCB) w/ USB OPENING 1 1 1 1 1 1 1 NOTE 10 1 201005_PCB 201005 PCB - REFERENCE .031" THICK CUSTOMER SUPPLIED 1 201005_COVER 201005U COVER - STANDARD ABS BLACK or WHITE 1 1 201005_BASE 201005U BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. NAME BILL OF MATERIALS TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 2 FILE THIRD ANGLE PROJECTION 1 3 ITEM EXPLODED VIEW SCALE 1.500 NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 1 OF 6 REV.DOC 7.1 201005 X ASSEMBLY .025 .500 .015 .178 Y .477 5.0° .060 (.218) .031 (.131) 2.000 .060 SHOWN WITH .031" PCB ORDER "-62" VERSION FOR OPTIONAL PCB THICKNESS R.125 SECTION Y-Y SCALE 1.500 Y TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 2 OF 6 REV.DOC 7.1 201005U COVER .160 R.015 .081 .020 .081 .015 .026 OPTIONAL R.124 .825 .240 Y .480 .060 .800 .700 .825 SCALE 1.500 R.125 Y SECTION Y-Y .038 (.218) .035 "PRESS FIT" .650 .240 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 3 OF 6 REV.DOC 7.1 NO DRAFT (.081) 20100562U BASE .121 R.015 (.700) .280 .480 .040 .998 "PRESS FIT" S .061 .260 .800 (1.375) 1.998 .700 .826 .825 SCALE 1.500 S .035 .089 STANDARD or .120 FOR "-62" CONFIGIGURATION R.125 .560 SECTION S-S TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 4 OF 6 REV.DOC 7.1 201005 PCB - CUSTOMER SUPPLIED .350 .425 .000 .425 .350 PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. 1.465 SUGGESTED TYPE A USB PLUG CONNECTOR ACON ADVANCED CONNECTEK INC. PN. C-GAR71-OO-OO www.acon.com .875 .725 .675 EXTENDED SIDES ARE OPTIONAL .030 FOR .062" PCB THICKNESS ORDER "-62" CONFIGURATION .000 .027 to .031 .675 .875 .032 TO CENTER OF CONNECTOR SCALE 1.500 SCALE 1.500 KEEP OUT ZONES .090 x .050 2 PLACES TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ** = RECOMMENDED BOARD THICKNESS IS .031" or .062" THICK, OPTIONS ARE AVAILABLE TO ALLOW OTHER THICKNESSES. ASK YOUR SALES REP FOR A QUOTE. ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 5 OF 6 REV.DOC 7.1 2nd OPERATION DETAILS New Age Enclosures DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY New Age Enclosures CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" MOLDED USB OPENING 201005U COVER SCALE 1.000 MOLDED USB OPENING 201005U BASE SCALE 1.000 PXX-201005U-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 2-C-C2 - T2 = .062" EM T2 = .062" EM PXX-201005U-XXX - ABS, BLACK ORIENTATION PROGRAM 268 268 - o1000 o1001 FIXTURE BASE STEP NO DESCRIPTION CUTTER 3-B-C1 4-B-C2 - T2 = .062" EM T2 = .062" EM - ABS, BLACK TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL FIXTURE ORIENTATION PROGRAM 268 268 - o1002 o1003 BY 201005X 2240 South Thornburg Street ph. (805) 595-1310 STANDARD - USB DEVICE PXX-201005X-XXX DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER SIZE 2007-May-21 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 201005_R7_1 SHEET 6 OF 6 REV.DOC 7.1
P3A-20100562U 价格&库存
很抱歉,暂时无法提供与“P3A-20100562U”相匹配的价格&库存,您可以联系我们找货
