From Off-The-Shelf to Market-Ready© New Age Enclosures is your Single Source Solution.
Let us quote modifiying our Stock Enclosures to meet your end-use.
visit newageenclosures.com/services or call 855-4NA-ENCL today.
NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
REV.
DRAWN BY
DATE
APPROVED
1
M BOYER
PRELIMINARY RELEASE
21-May-07
D.C.
2
M BOYER
ADD WIDE PCB CONFIGURATION
06-Jun-07
D.C.
3
M BOYER
MOVE PCB POSTS OUTWARD .03 PER SIDE
30-Jul-07
D.C.
4
M BOYER
UPDATE TO AS BUILT
12-Oct-07
D.C.
5
M BOYER
0208
UPDATE FORMAT AND RELEASE
04-Apr-08
D.C.
5.1
M BOYER
0710
UPDATE FORMAT
30-Mar-10
D.C.
5.2
M BOYER
0810
ADD NOTE 10
08-Apr-10
D.C.
6.0
M BOYER
2910
UPDATE BOARD THICKNESS INFORMATION
16-Aug-10
D.C.
6.1
M BOYER
3010
DOCUMENT CHANGE
24-Aug-10
D.C.
6.2
M BOYER
2711
CHANGE ASSEMBLY DIMENSIONS TO "PRESS FIT"
21-Oct-11
D.C.
7.0
M BOYER
1913
INCLUDE .062" PCB OPTION
09-Apr-13
D.C.
7.1
R CRUZ
8713
REMOVE .062" COVER OPTION
18-Dec-13
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11010.
3. INTERIOR SURFACE TEXTURE: NONE
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF
THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT
THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED.
6. 1 DEGREES DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP
ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
ECO No
DESCRIPTION
8. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
9. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER.
10. THE GATE REMNANT FOR THIS ENCLOSURE IS LOCATED IN THIS POSITION
TO MINIMIZE ANY COSMETIC IMPACT. IT IS HOWEVER VISIBLE AND VARIES
IN SIZE / SHAPE. IT IS EASILY REMOVED WITH CLIPPERS. IF YOU
WOULD LIKE NEW AGE TO CLIP THIS FOR YOU, PLEASE ASK YOUR SALES
REPRESENTIVE FOR A FREE QUOTE.
NOTE 10
OPTIONAL USB
OPENING
2
3
SCALE 1.500
P201005(x) CONFIGURATIONS
-S -U -62S -62U
201005
201005
201005
201005
201005
201005
COVER
COVER w/ USB OPENING
BASE
BASE (.062" PCB)
BASE w/ USB OPENING
BASE (.062" PCB) w/ USB OPENING
1
1
1
1
1
1
1
NOTE 10
1
201005_PCB
201005 PCB - REFERENCE
.031" THICK
CUSTOMER SUPPLIED
1
201005_COVER
201005U COVER - STANDARD
ABS
BLACK or WHITE
1
1
201005_BASE
201005U BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
NAME
BILL OF MATERIALS
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
2
FILE
THIRD ANGLE PROJECTION
1
3
ITEM
EXPLODED VIEW
SCALE 1.500
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
201005X
2240 South Thornburg Street
ph. (805) 595-1310
STANDARD - USB DEVICE
PXX-201005X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
201005_R7_1
SHEET
1 OF 6
REV.DOC
7.1
201005 X ASSEMBLY
.025
.500
.015
.178
Y
.477
5.0°
.060
(.218)
.031
(.131)
2.000
.060
SHOWN WITH .031" PCB
ORDER "-62" VERSION
FOR OPTIONAL PCB
THICKNESS
R.125
SECTION Y-Y
SCALE 1.500
Y
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
201005X
ph. (805) 595-1310
PXX-201005X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
fax (805) 595-1024
A
DRAWING NAME
201005_R7_1
SHEET
2 OF 6
REV.DOC
7.1
201005U COVER
.160
R.015
.081
.020
.081
.015
.026
OPTIONAL
R.124
.825
.240
Y
.480
.060
.800
.700
.825
SCALE 1.500
R.125
Y
SECTION Y-Y
.038
(.218)
.035
"PRESS FIT"
.650
.240
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
201005X
ph. (805) 595-1310
PXX-201005X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
fax (805) 595-1024
A
DRAWING NAME
201005_R7_1
SHEET
3 OF 6
REV.DOC
7.1
NO DRAFT
(.081)
20100562U BASE
.121
R.015
(.700)
.280
.480
.040
.998
"PRESS FIT"
S
.061
.260
.800
(1.375)
1.998
.700
.826
.825
SCALE 1.500 S
.035
.089 STANDARD or
.120 FOR "-62" CONFIGIGURATION
R.125
.560
SECTION S-S
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
201005X
ph. (805) 595-1310
PXX-201005X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
fax (805) 595-1024
A
DRAWING NAME
201005_R7_1
SHEET
4 OF 6
REV.DOC
7.1
201005 PCB - CUSTOMER SUPPLIED
.350
.425
.000
.425
.350
SIZES AND VERIFICATION OF IT'S FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
1.465
SUGGESTED TYPE A USB PLUG CONNECTOR
ACON ADVANCED CONNECTEK INC.
PN. C-GAR71-OO-OO
www.acon.com
.875
.725
.675
EXTENDED SIDES
ARE OPTIONAL
.030
FOR .062" PCB THICKNESS
ORDER "-62" CONFIGURATION
.000
.027 to .031
.675
.875
.032 TO CENTER
OF CONNECTOR
SCALE 1.500
SCALE 1.500
KEEP OUT ZONES
.090 x .050
2 PLACES
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
201005X
ph. (805) 595-1310
PXX-201005X-XXX
DATE
CHECK
** = RECOMMENDED BOARD THICKNESS IS .031" or .062" THICK, OPTIONS
ARE AVAILABLE TO ALLOW OTHER THICKNESSES. ASK YOUR SALES REP FOR A QUOTE.
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
fax (805) 595-1024
A
DRAWING NAME
201005_R7_1
SHEET
5 OF 6
REV.DOC
7.1
2nd OPERATION DETAILS
New Age Enclosures DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY New Age Enclosures
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
MOLDED USB
OPENING
201005U COVER
SCALE 1.000
MOLDED USB
OPENING
201005U BASE
SCALE 1.000
PXX-201005U-XXX
COVER
STEP NO
DESCRIPTION
CUTTER
1-C-C1
2-C-C2
T2 = .062" EM
T2 = .062" EM
PXX-201005U-XXX
ABS, BLACK
ORIENTATION
PROGRAM
268
268
o1000
o1001
FIXTURE
BASE
STEP NO
DESCRIPTION
CUTTER
3-B-C1
4-B-C2
T2 = .062" EM
T2 = .062" EM
ABS, BLACK
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
FIXTURE
ORIENTATION
PROGRAM
268
268
o1002
o1003
BY
201005X
ph. (805) 595-1310
PXX-201005X-XXX
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
SIZE
2007-May-21
fax (805) 595-1024
A
DRAWING NAME
201005_R7_1
SHEET
6 OF 6
REV.DOC
7.1
很抱歉,暂时无法提供与“P1A-20100562U”相匹配的价格&库存,您可以联系我们找货
