NOTES:
R E V I S I O N
UNLESS OTHERWISE SPECIFIED
REV.
DRAWN BY
DATE
APPROVE
A
M BOYER
PRELIMINARY RELEASE
2013-Nov-08
D.C.
2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH.
EQUIVELANT TO MT-11020.
B
R CRUZ
RENAME ENCLOSURE
2013-Nov-19
D.C.
C
R CRUZ
UPDATE NOTES
2014-Jan-20
D.C.
3. INTERIOR SURFACE TEXTURE TO BE: NONE.
D
M BOYER
REVISE STANDOFFS
2016-Feb-18
D.C.
E
M BOYER
REVISE DRAWING
2016-Feb-18
D.C.
F
R CRUZ
ADD USB CUTOUT DIMENSIONS
2016-Jul-26
D.C.
G
M BOYER
UPDATE TEXTURE AND USB INFO
2016-Aug-02
D.C.
1.0
R CRUZ
UPDATE TO AS BUILT AND RELEASE
2016-Aug-16
1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM.
4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED.
5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE
LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED
BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS
ECO No
0701
DESCRIPTION
6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS
OTHERWISED SPECIFIED.
7. MATERIAL / COLOR:
ABS PLASTIC IS STANDARD IN BLACK OR WHITE.
CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE.
8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION
OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER.
9. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT
CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED.
10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED
BY THE SOLID MODEL FILE.
11. ALLOWABLE FLASH: 0.010 MAX.
12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH,
PROTRUDING OR BELOW FLUSH.
220805
220805
220805
220805
220805(x) CONFIGURATIONS
-S
COVER
1
COVER w/ USB OPENING
BASE
1
BASE w/ USB OPENING
2
3
-U
1
1
1
SCALE 2.000
SCALE 1.000
THIRD ANGLE PROJECTION
TOLERANCES: UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN U.S. INCHES.
DO NOT SCALE DRAWING
NEW AGE ENCLOSURES
X.XX = .015 X.XXXX = .001
X.XXX = .010
X.X° = 1°
3
220805_PCB
220805 PCB - REFERENCE
.062" THICK
CUSTOMER SUPPLIED
1
2
220805_COVER
220805U COVER - STANDARD
ABS
BLACK or WHITE
1
1
220805_BASE
220805U BASE - STANDARD
ABS
BLACK or WHITE
1
DESCRIPTION
MATERIAL
COLOR
QTY.
ITEM
FILE
NAME
BILL OF MATERIALS
NOTICE: THE INFORMATION AND DATA
CONTAINED HEREIN IS CONSIDERED
PROPRIETARY TO ALLTEC INTEGRATED
MFG INC & SHALL REMAIN THE EXCLUSIVE
PROPERTY OF ALLTEC INTEGRATED MFG INC
THE HOLDER WILL ASSUME CUSTODY AND
CONTROL THAT THIS DOCUMENT WILL
NOT BE COPIED, REPRODUCED, OR
DISCLOSED WITHOUT THE EXPRESS WRITTEN
CONSENT OF ALLTEC INTEGRATED MFG INC
POSSESSION OF THIS DOCUMENT DOES
NOT CONSTITUTE A GRANT TO
MANUFACTURE ANY ITEMS.
© 2017
Customer's Part No:
APPROVAL
BY
220805X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
2240 South Thornburg Street
ph. (805) 595-1310
USB ADAPTER - STANDARD
PXX-220805X-XXX
SIZE
2013-Nov-08
Santa Maria, CA. 93455
fax (805) 595-1024
www.newageenclosures.com
A
DRAWING NAME
220805_R1_0
SHEET
1 OF 6
REV.DOC
1.0
220805 ASSEMBLY
2.250
R.150
X
X
.850
R1.500
R7.500
SCALE 2.000
.235
P
.475
SECTION P-P
P
.048
.235 CLEAR
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
SECTION X-X
Customer's Part No:
.062
APPROVAL
BY
220805X
DATE
CHECK
.065
.048 CLEAR
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-220805X-XXX
SIZE
2013-Nov-08
fax (805) 595-1024
A
DRAWING NAME
220805_R1_0
SHEET
2 OF 6
REV.DOC
1.0
P
.240
2X .320
.000
2X .320
.240
X
220805 COVER
.850
.478
.135
P
.130
2X .600
.040
2.250
1.828
2.186 -5°
DRAFT/SIDE
.000
R.068
2X .600
.015
SCALE 2.000
SECTION X-X
X
.065
SEE DETAIL A
.315
.786 -5°
DRAFT/SIDE
X.XXX = .010
X.X° = 1°
.050
SECTION P-P
+.001
-.001
PRESS FIT
4 PLACES
.062
DETAIL A
SCALE 6.000
NEW AGE ENCLOSURES
95.0°
Customer's Part No:
APPROVAL
BY
220805X
DATE
CHECK
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-220805X-XXX
SIZE
2013-Nov-08
fax (805) 595-1024
A
DRAWING NAME
220805_R1_0
SHEET
3 OF 6
REV.DOC
1.0
.425
.240
2X .320
.000
X
2X .320
.240
.425
220805 BASE
.850
.085
1.125
2X .600
.065
.025
2.250
2.183 +5°
DRAFT/SIDE
.000
.005
P
P
2X .600
X
1.125
SECTION X-X
SCALE 2.000
95.0°
.200
.125
.783 +5°
DRAFT/SIDE
.062
.080
X.XXX = .010
X.X° = 1°
DETAIL B
SCALE 6.000
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
220805X
DATE
CHECK
SECTION P-P
+.001
-.001
PRESS FIT
4 PLACES
SEE DETAIL B
+.002
.040
-.002
ENG.
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-220805X-XXX
SIZE
2013-Nov-08
fax (805) 595-1024
A
DRAWING NAME
220805_R1_0
SHEET
4 OF 6
REV.DOC
1.0
SUGGESTED TYPE A USB PLUG CONNECTOR
ACON, ADVANCED CONNECTEK INC.
220805 PCB - CUSTOMER SUPPLIED
SIZES AND VERIFICATION OF ITS FIT ARE THE
SOLE RESPONSIBILITY OF THE OEM.
PN. C-UAR70-00-00
www.acon.com/en-global/product/detail/378
.177
CHAMFER .075 x 45°
4 PLACES
1.021
KEEP OUT ZONES
4 PLACES
.871
.118
.735
.585
4X R.065
.000
2.042
.015
2X R.063
.648
.510
.039
.615
.765
.075
1.021
SCALE 2.000
.698
.062
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
BY
220805X
DATE
CHECK
ENG.
.045 MAX
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-220805X-XXX
SIZE
2013-Nov-08
fax (805) 595-1024
A
DRAWING NAME
220805_R1_0
SHEET
5 OF 6
REV.DOC
1.0
220805 - 2nd OPERATIONS
MOLDED USB
OPENING
MOLDED USB
OPENING
NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE
CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT.
ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES
CALL (805) 595-1310 FOR PRICING AND SCHEDULE.
THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031"
220805 BASE
SCALE 1.500
220805 COVER
SCALE 1.500
X.XXX = .010
X.X° = 1°
NEW AGE ENCLOSURES
Customer's Part No:
APPROVAL
PXX-220805X-XXX
COVER
STEP NO
DESCRIPTION
CUTTER
1-C-C1
T2 = .062" EM
FIXTURE
ABS, BLACK
BY
220805X
DATE
CHECK
ENG.
ORIENTATION
PROGRAM
SINGLE
SCALE
AS NOTED
DRAWN BY
M BOYER
ph. (805) 595-1310
PXX-220805X-XXX
SIZE
2013-Nov-08
fax (805) 595-1024
A
DRAWING NAME
220805_R1_0
SHEET
6 OF 6
REV.DOC
1.0
很抱歉,暂时无法提供与“P3A-220805U”相匹配的价格&库存,您可以联系我们找货
