P3A-220805S
P3A-220805S
    NEWAGE
    UTILITY ADAPTER
P3A-220805S 数据手册
NOTES: R E V I S I O N UNLESS OTHERWISE SPECIFIED REV. DRAWN BY DATE APPROVE A M BOYER PRELIMINARY RELEASE 2013-Nov-08 D.C. 2. EXTERIOR SURFACE TEXTURE TO BE LIGHT EDM FINISH. EQUIVELANT TO MT-11020. B R CRUZ RENAME ENCLOSURE 2013-Nov-19 D.C. C R CRUZ UPDATE NOTES 2014-Jan-20 D.C. 3. INTERIOR SURFACE TEXTURE TO BE: NONE. D M BOYER REVISE STANDOFFS 2016-Feb-18 D.C. E M BOYER REVISE DRAWING 2016-Feb-18 D.C. F R CRUZ ADD USB CUTOUT DIMENSIONS 2016-Jul-26 D.C. G M BOYER UPDATE TEXTURE AND USB INFO 2016-Aug-02 D.C. 1.0 R CRUZ UPDATE TO AS BUILT AND RELEASE 2016-Aug-16 1. CORNERS DRAWN SHARP TO BE R.005 MAXIMUM. 4. ALL INSIDE RADII .010R. UNLESS OTHERWISE SPECIFIED. 5. ALL EXTERNAL DIMENSIONS AFFECTED BY THE DRAFT APPLY AT THE LARGE END OF THE FEATURE, AND ALL INTERNAL FEATURES AFFECTED BY THE DRAFT APPLY AT THE SMALL END OF THE FEATURE UNLESS OTHERWISE SPECIFIED. ECO No 0701 DESCRIPTION 6. 1 DEGREE DRAFT IN THE DIRECTION OF PULL IS PERMISSIBLE UNLESS OTHERWISED SPECIFIED. 7. MATERIAL / COLOR: ABS PLASTIC IS STANDARD IN BLACK OR WHITE. CUSTOM MATERIALS AND COLORS ARE AVAILABLE UPON REQUEST FOR QUOTE. 8. PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF IT'S FIT ARE THE SOLE RESPONSIBILITY OF EACH OWNER. 9. THIS ENCLOSURE IS A PRESS FIT ASSEMBLY. FOR PERMANENT CLOSURE: A DROP OF ADHESIVE OR ULTRASONIC WELDING IS REQUIRED. 10. THIS DRAWING IS BASED ON A SOLID MODEL, AND IS FURTHER DEFINED BY THE SOLID MODEL FILE. 11. ALLOWABLE FLASH: 0.010 MAX. 12. ALL EJECTOR PIN MARKS TO BE WITHIN 0.010" OF FLUSH, PROTRUDING OR BELOW FLUSH. 220805 220805 220805 220805 220805(x) CONFIGURATIONS -S COVER 1 COVER w/ USB OPENING BASE 1 BASE w/ USB OPENING 2 3 -U 1 1 1 SCALE 2.000 SCALE 1.000 THIRD ANGLE PROJECTION TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. DO NOT SCALE DRAWING NEW AGE ENCLOSURES X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° 3 220805_PCB 220805 PCB - REFERENCE .062" THICK CUSTOMER SUPPLIED 1 2 220805_COVER 220805U COVER - STANDARD ABS BLACK or WHITE 1 1 220805_BASE 220805U BASE - STANDARD ABS BLACK or WHITE 1 DESCRIPTION MATERIAL COLOR QTY. ITEM FILE NAME BILL OF MATERIALS NOTICE: THE INFORMATION AND DATA CONTAINED HEREIN IS CONSIDERED PROPRIETARY TO ALLTEC INTEGRATED MFG INC & SHALL REMAIN THE EXCLUSIVE PROPERTY OF ALLTEC INTEGRATED MFG INC THE HOLDER WILL ASSUME CUSTODY AND CONTROL THAT THIS DOCUMENT WILL NOT BE COPIED, REPRODUCED, OR DISCLOSED WITHOUT THE EXPRESS WRITTEN CONSENT OF ALLTEC INTEGRATED MFG INC POSSESSION OF THIS DOCUMENT DOES NOT CONSTITUTE A GRANT TO MANUFACTURE ANY ITEMS. © 2017 Customer's Part No: APPROVAL BY 220805X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 1 OF 6 REV.DOC 1.0 220805 ASSEMBLY 2.250 R.150 X X .850 R1.500 R7.500 SCALE 2.000 .235 P .475 SECTION P-P P .048 .235 CLEAR TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES SECTION X-X Customer's Part No: .062 APPROVAL BY 220805X DATE CHECK .065 .048 CLEAR ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 2 OF 6 REV.DOC 1.0 P .240 2X .320 .000 2X .320 .240 X 220805 COVER .850 .478 .135 P .130 2X .600 .040 2.250 1.828 2.186 -5° DRAFT/SIDE .000 R.068 2X .600 .015 SCALE 2.000 SECTION X-X X .065 SEE DETAIL A .315 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .786 -5° DRAFT/SIDE X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° .050 SECTION P-P +.001 -.001 PRESS FIT 4 PLACES .062 DETAIL A SCALE 6.000 NEW AGE ENCLOSURES 95.0° Customer's Part No: APPROVAL BY 220805X DATE CHECK ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 3 OF 6 REV.DOC 1.0 .425 .240 2X .320 .000 X 2X .320 .240 .425 220805 BASE .850 .085 1.125 2X .600 .065 .025 2.250 2.183 +5° DRAFT/SIDE .000 .005 P P 2X .600 X 1.125 SECTION X-X SCALE 2.000 95.0° .200 .125 .783 +5° DRAFT/SIDE .062 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .080 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° DETAIL B SCALE 6.000 NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 220805X DATE CHECK SECTION P-P +.001 -.001 PRESS FIT 4 PLACES SEE DETAIL B +.002 .040 -.002 ENG. SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 4 OF 6 REV.DOC 1.0 SUGGESTED TYPE A USB PLUG CONNECTOR ACON, ADVANCED CONNECTEK INC. 220805 PCB - CUSTOMER SUPPLIED PCB SIZES ARE RECOMMENDATIONS ONLY. FINAL SIZES AND VERIFICATION OF ITS FIT ARE THE SOLE RESPONSIBILITY OF THE OEM. PN. C-UAR70-00-00 www.acon.com/en-global/product/detail/378 .177 CHAMFER .075 x 45° 4 PLACES 1.021 KEEP OUT ZONES 4 PLACES .871 .118 .735 .585 4X R.065 .000 2.042 .015 2X R.063 .648 .510 .039 .615 .765 .075 1.021 SCALE 2.000 .698 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. .062 X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL BY 220805X DATE CHECK ENG. .045 MAX SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 5 OF 6 REV.DOC 1.0 220805 - 2nd OPERATIONS MOLDED USB OPENING MOLDED USB OPENING NEW AGE ENCLOSURES DELIVERS YOUR ENCLOSURE MARKET-READY WITH IN-HOUSE CNC MACHINING, PAD PRINTING, ASSEMBLY, AND FULFILLEMENT. ALL SURFACES AND AREAS ARE AVAILABLE FOR CNC ALTERATION BY NEW AGE ENCLOSURES CALL (805) 595-1310 FOR PRICING AND SCHEDULE. THE INSIDE RADIUS OF ANY MACHINED FEATURES SHOULD BE NO SMALLER THAN .031" 220805 BASE SCALE 1.500 220805 COVER SCALE 1.500 TOLERANCES: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN U.S. INCHES. X.XX = .015 X.XXXX = .001 X.XXX = .010 X.X° = 1° NEW AGE ENCLOSURES Customer's Part No: APPROVAL PXX-220805X-XXX COVER STEP NO DESCRIPTION CUTTER 1-C-C1 - T2 = .062" EM - FIXTURE - ABS, BLACK BY 220805X DATE CHECK ENG. ORIENTATION PROGRAM SINGLE - SCALE AS NOTED DRAWN BY M BOYER 2240 South Thornburg Street ph. (805) 595-1310 USB ADAPTER - STANDARD PXX-220805X-XXX SIZE 2013-Nov-08 Santa Maria, CA. 93455 fax (805) 595-1024 www.newageenclosures.com A DRAWING NAME 220805_R1_0 SHEET 6 OF 6 REV.DOC 1.0
P3A-220805S 价格&库存
很抱歉,暂时无法提供与“P3A-220805S”相匹配的价格&库存,您可以联系我们找货
