BD170240N50100AHF
BD170240N50100AHF
    TTM(迅达)
    BALUN 17.7-23.6GHZ 50/100 0404
BD170240N50100AHF 数据手册
Model BD170240N50100AHF Preliminary PRELIMINARY Ultra Low Profile 0404 Balun 50Ω to 100Ω Balanced Description The BD170240N50100AHF is a low cost, low profile sub-miniature unbalanced to balanced transformer designed for differential inputs and output locations on modern chipsets in an easy to use surface mount package for applications including point-to-point radio and wideband GaN. The BD170240N50100AHF is ideal for high volume manufacturing and delivers higher performance than traditional ceramic baluns. The BD170240N50100AHF has an unbalanced port impedance of 50 and a 100 balanced port impedance. This transformation enables single ended signals to be applied to differential ports on modern integrated chipsets. The output ports have equal amplitude (-3dB) with 180 degree phase differential. The BD170240N50100AHF is available on tape and reel for pick and place high volume manufacturing. Detailed Electrical Specifications: Specifications subject to change without notice. Features:         ROOM (25C) Typ. Max 23.6 50 100 12 TBD TBD 1.5 TBD TBD TBD TBD 15 TBD -55 +85 Parameter Frequency Unbalanced Port Impedance Balanced Port Impedance Return Loss Insertion Loss* Amplitude Balance Phase Balance CMRR Power Handling @85C Operating Temperature 17.7 – 23.6 GHz Thin Height Profile Ultra Low Insertion Loss Surface Mountable Tape & Reel RoHS Compliant Halogen Free -55°C to 85°C Min. 17.7 Unit GHz Ω Ω dB dB dB Degrees dB Watts ºC * Insertion Loss stated at room temperature (Insertion Loss is approximately 0.1 dB higher at +85 ºC) Outline Drawing Top View (Near-side) Side View Bottom View (Far-side) .24 ±.06 TBD .56 1.04±.10 3x .27 1 2 .24 3x .27 .30 .30 1.04±.10 .50 3x .25 3 4 3x .25 Pin Designation GND / DC Feed 1 + RF GND Dimensions are in Millimeters Mechanical Outline 2 Unbalanced Port 3 Balanced Port 4 Balanced Port Visit us at www.anaren.com .50 Tolerances are Non-Cumulative USA/Canada: Toll Free: Europe: Asia: (315) 432-8909 (800) 411-6596 +44 2392-232392 +86 512-62749282 Model BD170240N50100AHF Preliminary Mounting Configuration: In order for Xinger surface mount components to work optimally, the proper impedance transmission lines must be used to connect to the RF ports. If this condition is not satisfied, insertion loss, Isolation and VSWR may not meet published specifications. All of the Xinger components are constructed from organic PTFE based composites which possess excellent electrical and mechanical stability. Xinger components are compliant to a variety of ROHS and Green standards and ready for Pb-free soldering processes. Pads are Gold plated with a Nickel barrier. An example of the PCB footprint used in the testing of these parts is shown below. In specific designs, the transmission line widths need to be adjusted to the unique dielectric coefficients and thicknesses as well as varying pick and place equipment tolerances. With No DC Bias 3x Transmission Line 3x .29 With DC Bias Plated thru hole to ground Plated thru hole to ground .33 3x Transmission Line 3x .29 .33 3x .29 .33 3x .29 .22 .50 .22 .50 .22 .22 .50 .50 Circuit Pattern Circuit Pattern Footprint Pad (s) Footprint Pad (s) Solder Resist Dimensions are in Millimeters Mounting Footprint Visit us at www.anaren.com Solder Resist Dimensions are in Millimeters Mounting Footprint USA/Canada: Toll Free: Europe: Asia: (315) 432-8909 (800) 411-6596 +44 2392-232392 +86 512-62749282 Model BD170240N50100AHF Preliminary PRELIMINARY Packaging and Ordering Information Parts are available in reel and are packaged per EIA 481-D. Parts are oriented in tape and reel as shown below. Minimum order quantities are 4000 per reel. Visit us at www.anaren.com USA/Canada: Toll Free: Europe: Asia: (315) 432-8909 (800) 411-6596 +44 2392-232392 +86 512-62749282
BD170240N50100AHF 价格&库存
很抱歉,暂时无法提供与“BD170240N50100AHF”相匹配的价格&库存,您可以联系我们找货
