ASX00011
ASX00011
    ARDUINO
    ARDUINO MKR ENVIRONMENTAL SHIELD
ASX00011 数据手册
ARDUINO MKR ENV SHIELD Code: ASX00011 Add environmental sensors to your MKR board at a glance. The MKR ENV Shield allows a MKR board to acquire environmental data collected by an array of sensors. These sensors are of the latest generation and measure:  Atmospheric pressure  Temperature and humidity  Ultraviolet UVA intensity Ultraviolet UVB intensity,  UV Index (calculated)  Light intensity (in LUX) To help you build projects and store the data collected locally, this shield has a slot for a microSD card (not provided). There is a ready to use library with examples and methods to read values from the different sensors, that provides an easy and smooth integration path. Sensors used :  ST LPS22HB : atmospheric pressure  ST HTS221 : temperature and humidity  VISHAY TEMT6000 : Lux of the ambient.  VISHAY VEML6075 : UltraViolet wavelengths A / B ICs LPS22HB TEMT6000 VEML6075 Input Voltage 3.3V Operating Voltage 3.3V Ranges Pressure: 260 to 1260 hPa rH sensitivity: 0.004% rH/LSB Humidity accuracy: ± 3.5% rH, 20 to +80% rH UVA, UVB and UVBI measurment Communication I2C/Analog Length 61 mm Width 25 mm Weight 32 gr. Schematics The Arduino MKR ENV Sheld is open-source hardware! You can build your own board using the following files: EAGLE FILES IN .ZIP SCHEMATICS IN .PDF Sensors used :     ST LPS22HB : atmospheric pressure ST HTS221 : temperature and humidity VISHAY TEMT6000 : Lux of the ambient. VISHAY VEML6075 : UltraViolet wavelengths A / B www.arduino.cc
ASX00011 价格&库存
很抱歉,暂时无法提供与“ASX00011”相匹配的价格&库存,您可以联系我们找货
