GB-144
Glove Box Dispenser - Single - Cabinet Mount
Product Description:
• Glove Box Dispenser - Single - Cabinet Mount
• Holds one box of gloves
• Flexible spring on back pushes box forward to cabinet opening
• Front screw holes for mounting inside a cabinet
• White Powder-Coated Steel
Primary Area for Product Usage:
• All primary care areas: clinic/exam rooms, radiology, labs,
physical therapy, O.R. areas, employee health
• Kitchens, laundry facilities, environmental services, sterile
processing
Rear View
Dispenses:
• Most brand name standard glove boxes
• Boxes no larger than 5.50″W x 10.00″H x 3.69″D
(14.0 cm x 25.4 cm x 9.4 cm)
Package Specifications:
• Package Quantity: 12 per case
• 18″L x 16″W x 10″H (45.7 cm x 40.6 cm x 25.4 cm)
• 20.0 lbs (9.1 kg) - approximated
Product Specifications (overall external dimensions):
• 5.60″W x 10.00″H x 3.80″D (14.2 cm x 25.4 cm x 9.7 cm)
Alternate Products (each sold separately):
• Glove Box Dispenser - Single with Flexible Spring, GL100-1214
• Glove Box Dispenser - Single with Flexible Spring, GL100-0212
• 1.4 lbs (0.6 kg) - approximated
Mounting Specifications:
4.30"
3.10"
0.65" (TYP)
4.50"
• Glove Box Dispenser - Triple with Dividers, GL300-0212
0.50"
• Glove Box Dispenser - Triple with Dividers, GL300-1214
Ø0.19" (4x)
GL300-1214
Mounted inside a precut
cabinet, shown from front
Product Videos:
BowmanDispensers.com/Product-Videos
GL300-1214
cabinet, shown from rear
BOWMAN Dispensers
20325 71 st Ave NE, Suite D, Arlington, WA 98223
800.962.4660 • www.BowmanDispensers.com
GB-144
Installation Instructions/Characteristics & Care
Installation
Always mount dispensers securely prior to loading with product.
• Pre-cut dispensing holes in a cabinet door, up to 3.10″W x 10.00″H.
Powder-Coated Steel
Material Characteristics
Designed for Long-Term Use
Our steel dispensers and stands
are coated with polyester powders
which makes them highly resistant to
corrosion.
Available cut area
for dispensing
Powder-coated steel is ideal for
dispensers used in a healthcare or
an industrial setting because it is
impact resistant and is not effected by
extremes in temperature.
Dispensers and stands made
of powder-coated steel are both
attractive and functional, providing
years of service.
1
• Attach dispenser to inside of cabinet door, using screws recommended and
provided by building maintenance.
Care and Cleaning
For best results, clean by washing the
surface with a diluted solution of a
mild, non-abrasive detergent in cold or
warm water and a non-abrasive cloth.
Standard hospital cleaning supplies
can be used.
2
Dry with a soft cloth. Do not use any
solvent-based materials, abrasives
(e.g. Scotch-brite, steel wool), or apply
excessive force during cleaning.
Parts included:
• Dispenser
Tools Required:
• No tools required to assemble dispenser
GB-144 - Installation/Characteristics & Care
Information subject to change without notice. Dimensions are approximate. (Not to scale)
BOWMAN Dispensers
20325 71st Ave NE, Suite D, Arlington, WA 98223
©2020 BOWMAN® Dispensers, LLC. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. GB144TDSc
很抱歉,暂时无法提供与“GB-144”相匹配的价格&库存,您可以联系我们找货
