80
Hi-A Grade ≥ 1A
36 Series
2.5A . 1a
RoHS Compliance
Features
Application
● Contact Form
1a
● Modem
● Load Voltage
60V
● Telephone Equipment
● Operation LED Current
3.0mA
● Security Equipment
● Load Current
2.5A
● Sensing Equipment
● On-Resistance
0.07Ω
● Automatic Test Equipment
● Output Capacitance
470pF
● I/O Modules
● Low Off-State Leakage Current
1.0µA
● Electric Vehicle
3.4±0.2
8.8±0.3
DIP6
PART NO
6.4±0.3
TO
AA
36
TO
WA
R
D
6.4±0.3
AA WA
36 RD
F
8.8±0.3
3.4±0.2
S MD 6
PACKAGE
PACKING
AA36
DIP-6
Tube
50pcs
AA36F
SMD-6
Tube
50pcs
AA36F-R1
SMD-6
Reel 1000pcs
* Package & PCB Layout Design, See Page 134
Terminal Identification
AA36(F)
1:Anode
2:Cathode
3:NC
4,6:Drain
5:Source
(LED)
(LED)
(MOS FET)
(MOS FET)
為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。
In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range.
36 Series. REV.06/2017
81
Hi-A Grade ≥ 1A
Absolute Maximum Ratings 絕對最大定格 (Ambient Temperature 周圍溫度:25℃ )
Item
Input
輸入
Symbol
Value
Continuous LED Current 連續 LED 電流
IF
50mA
Peak LED Current LED 峰值電流 (f-100 Hz,Duty=1%)
IFP
500mA
LED Reverse Voltage 逆向 LED 電壓
VR
5V
Input Power Dissipation 輸入損耗
PIN
75mW
Load Voltage 負荷電壓
VL
60V (AC peak or DC)
A
B
C
2.5A(AC or DC)
3.5A(DC)
5.0A(DC)
Load Current 負荷電流
(A)
IL
Peak Load Current 峰值負荷電流 (1ms,1 shot)
(A)
IPEAK
6.0
(mW)
POUT
500
(mW)
PT
550
I/O Breakdown Voltage 入 / 出力間絕緣電壓
(Vrms)
VI/O
3750
I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Suffix-H)
(Vrms)
VI/O
5000
Operating Temperature 使用時溫度
TOPR
-40℃ ~ +85℃
Storage Temperature 保存溫度
TSTG
-40℃ ~ +100℃
output
輸出
Output Power Dissipation 輸出損耗
Total Power Dissipation 全損耗
Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ )
Item
LED Forward Voltage
LED 順向電壓
Input
輸入
Output
輸出
VF
LED 動作電流
IF ON
Recovery LED Voltage
LED 復位電壓
VF OFF
1.0
0.5
1.37
1.5
V
1.5
3.0
mA
1.0
RON
開路狀態漏電流
ILEAK
Output Capacitance
輸出端容量
COUT
470
TON
0.6
3.0
ms
TOFF
0.04
0.5
ms
復位時間
0.07
Conditions
IF=10mA
V
On-Resistance 導通電阻
Drain to Drain
Turn-On Time
Transmission 動作時間
傳達
Turn-Off Time
Coupled
結合
Symbol MIN. TYP. MAX. Units
IF=10mA,IL=Rating
Time to flow is within
1sec.
0.1
Ω
1.0
µA
IF=0mA,VL=60V
pF
VL=0V,f=1MHz
IF=10mA,IL=Rating
I/O Insulation Resistance
輸入 / 出間絕緣阻抗
RI/O
I/O Capacitance
輸入 / 力端靜電容量
CI/O
5 x 109
Ω
1
pF
f=1MHz
BRIGHT TOWARD INDUSTRIAL CO.,LTD.
82
Hi-A Grade ≥ 1A
Load current Vs.
Ambient temperature
On resistance Vs.
Ambient temperature
Turn on time Vs.
Ambient temperature
Turn off time Vs.
Ambient temperature
LED operate current Vs.
Ambient temperature
LED Turn off current Vs.
Ambient temperature
LED forward voltage Vs.
Ambient temperature
Voltage Vs. current characteristics
of output at MOS portion
Off state leakage current Vs.
Load voltage characteristics
LED forward current Vs.
turn on time characteristics
turn off time characteristics
Applied voltage Vs.
output capacitance characteristics
134
Package & PC Board Pattern
Package 包裝
Dimensions 外型尺寸圖
PC Board pattern PC 板加工圖
0.3
7.87
9.54 max.
ARD
TOW
DIP4
(Bottom View)
15 max.
0.3
SMD4
1.3
+0.2
0.1 -0.05
0.3
8.7
1.3
ARD
TOW
(Top View)
7.87
9.54 max.
TO
WA
RD
0.3
DIP6
(Bottom View)
15 max.
SMD6
1.3
0.1
+0.2
-0.05
0.3
8.7
TO
WA
R
D
1.3
0.3
(Top View)
7.87
9.54 max.
TO
WA
R
D
0.3
DIP8
(Bottom View)
15 max.
1.3
+0.2
0.1 -0.05
0.3
TO
WA
R
D
1.3
0.3
(Top View)
TO
WA
RD
6.3
SMD8
(Top View)
0.06
6.3
TO
WA
R
D
SOP4
1.27
SOP8
0.06
Package & PC Board Pattern. REV.06/2017
0.76
(Top View)
135
Packing Specifications
Package Type
包裝類型
Reel shape & dimensions
圈帶形狀和尺寸
Quantity
數量
100
330
12
4.6
Tape shape & dimensions
形狀和尺寸
4 Pin SOP
2.0
100
330
16
10.4
13
1000 pcs
8 Pin SOP
2.0
80
380
1000 pcs
80
380
4 Pin SMD
1000 pcs
80
380
5.3
17
1000 pcs
1000 pcs
9.15
17
6 Pin SMD
9.9
17
8 Pin SMD
17
Packing Speci ications. REV.06/2017
136
Load Connecting Method
Type
類型
Load
負荷
4 pin
AC or DC
Feature
特長
Control bi-directional signal
可控制雙向信號
AC or DC
可控制雙向信號
B
DC
On-Resistance is 1/2 of
A-connection
導通電阻值是 A 接法的 1/2
2-Make-contacts
(Source Common)
C
DC
B-connection
導通電阻值是 B 接法的 1/2
A
6 pin
Connection
接續方法
2 input and 2 output
2 入力和 2 出力回路
8 pin
AC or DC
1 input and 2 output
1 入力和 2 出力回路
Load Connecting Method. REV.06/2017
很抱歉,暂时无法提供与“AA36F”相匹配的价格&库存,您可以联系我们找货
