137
S.S.R.
TC Series
Photo Tria c
Features
Applications
●Compact DIP8 Pin Package
●Power TRIAC driver
●High Isolation Voltage 5000VAC between input
and output
●Household appliance
W
81
R0
TC
RD
A
TOW
TC AR
20 D
9-7
TO
●Be suitable for 110/220VAC power voltage
9R
●Soild State Relay
●600VDC peak blocking Voltage
●Random-on & Zero-on types are available
Order Code:
TC 2 09 R - 7
a
b c d
a
b
c
d
e
e
Model : TC=DIP
Output Voltage
Output Current
Turn on Type :
Option : Nil =
8 Pin Package Type
: 2 = 240VAC
: 09 = 0.9Amp ; 12 = 1.2Amp
Nil = Zero-on ; R = Random - on
DIP Type ; 7 = SMD Type
Absolate Maximum Rating:
Symbol
Rating
TC209(R) TC212(R )
Unit
IF
50
mA
Peak Forward Current
IFP
1
A
Reverse Voltage
VR
6
V
Item
Forward Current
Input
Output
Off-state Output Voltage
V DRM
On-state Output Current
IT(RMS)
0.9
1.2
A
ITSM
9
12
A
Non-repeatitive Sutge Current
600
VDC
I/O Isolation Voltage
V iso
5000
VAC
Operating Temperature
T opr
-30~+85
Storage Temperature
T stg
-40~+125
Electrical Characteristics:
Item
Input
Output
Forward Voltage
Symbol MIN.
Rating
MAX.
TC209(R) TC212(R)
VF
1.18
Unit
Conditions
1.4
V
IF =10mA
IR
10
µ A
V R =6V
Peak Leakage Current
IDRM
100
µ A
V DRM =600V
On-state Voltage
V TM
2.3
V
IT =Rated IT
Reverse Current
Hold Current
Rise rate of off-state
1.3
IH
dv/dt
1.1
25
mA
V D =6V
200
1000
V/µ S
V DRM =600V/ √ 2
V D =6V
Minimum trigger current
IFT
2
10
mA
Recovery Input Voltage
VF OFF
0.5
V
I/O Isolation Resistance
R iso
50G
Turn-on Time (Random-on)
T ON
8
100
µ S
Turn-on Time (Zero-on)
T ON
10
mS
Turn-off Time
T OFF
10
mS
為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。
DC=500V
IF =20mA
Note:Recommended trigger current is between 10mA and 20mA
BRIGHT TOWARD INDUSTRIAL CO.,LTD.
TC Series.REV.11/2018
138
S.S.R.
Dimensions : (Unit : mm)
(Random-on)
(Zero-on)
7.87
9.54 max.
0.3
15 max.
1.3
0.3
1.3
+0. 2
0.1-0.05
0.3
1. Cathode
2. Anode
3. Cathode
4. Cathode
5. Gate
6. T1
8. T2
Wiring Diagram
1
E1
8
2
IF
Load
IL
3
6
4
5
VL(AC)
IL
VL(AC)
Load
REFERENCE DATA :
VF VS. Ta
IGT VS. Ta
In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range.
TC Series. REV.11/2018
139
S.S.R.
IF VS. Ta
V TM VS. Ta
I T VS. VTM
IF VS. Ta
IF VS. TF
TON VS. IF
很抱歉,暂时无法提供与“TC209R”相匹配的价格&库存,您可以联系我们找货
