TMB-V5F2-3LC
TMB-V5F2-3LC
    TRI-STAR
    3.5mm 连接器 插孔,母形插口 50 欧姆 表面贴装型 压缩
TMB-V5F2-3LC 数据手册
4 3 2 D 4 REGION A 2 DESCRIPTION 1 PRELIMINARY RELEASE 3 DATE 30.Jun.20 BY Falcon D 1 CABLE LENGTH "XXX" C PART NUMBER LENGTH ( CM) TM28THSSTSSTS16-P ±5 20 TM28THSSTSSTS31-P ±5 31 TM28THSSTSSTS46-P ±5 46 TM28THSSTSSTS61-P ±8 61 TM28THSSTSSTS76-P ±8 76 TM28THSSTSSTS91-P ±8 91 TM28THSSTSSTS100-P ±8 100 TM28THSSTSSTS122-P B TOLERANCE (mm) 16 TM28THSSTSSTS20-P ± 12 122 ± 12 Max VSWR Up to 65Ghz C Max insertion loss(dB) Up to 65Ghz 1.40:1 1.76 1.40:1 2.20 1.40:1 3.41 1.40:1 5.06 1.40:1 6.71 1.40:1 8.36 1.40:1 10.01 1.40:1 11.00 1.40:1 12.20 B NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . 5, MATECHED CABLE @2.0pS AND PACKAGED OR SUPPLIED TOGETHER . 4 3 2 1 ITEM KEY DIMENSION NEED 100% INSPECTION A REV. RoHS Compliant 6~30 ±1 0.5~3 4 ±0.05 (XX) REF. DIMENSION ISO2768-V (mm) 30-120 120~400 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 1K~2K ISO2768-F (mm) 30~120 ±0.1 3 ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY DRAWN: CHECKED: M23053/5-106-0 M23053/4-101-0 TM7S-STS-00 INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF DRAWING INFORMATION IS STRICTLY PROHIBITTED. 2 28 AWG , SILICON JACKET CABLE SEE TABLE "XXX" + "XXX" DESCRIPTION QTY CONN, SSMP, FEMALE, STRAIGTH, TL PART NUMBER APPROVED: 1" ADHESIVE , 1/8 HST BLACK 16707052-02 Falcon SEMI-REGID , 1/4 HST BLACK INTERCONNECT TECHNOLOGIES MATERIAL: PART NUMBER: SIZE A4 TM28THSSTSSTSXX-P SCALE 2:1 2" 4 Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: PART NAME: ASSY, 052 SIL, SSMP ST(F)x2, XXcm, PAIR CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TMB-V5F2-3LC 价格&库存
很抱歉,暂时无法提供与“TMB-V5F2-3LC”相匹配的价格&库存,您可以联系我们找货
