TM7SSSTS5FS031C
TM7SSSTS5FS031C
    TRI-STAR
    同轴电缆组件 SMA 至 SSMP 0.078" OD 外径同轴缆线 12.20"(310.00mm)
TM7SSSTS5FS031C 数据手册
4 3 2 D 5 2 6 7 REV. A REGION DESCRIPTION 1 PRELIMINARY RELEASE 3 4 DATE 30.Jun.20 BY Falcon 1 D CABLE LENGTH "XXX" C PART NUMBER LENGTH ( CM) TOLERANCE (mm) Max VSWR Up to 26Ghz Max insertion loss(dB) Up to 26Ghz TM7SMSTS5FS0016 16 ±5 1.35:1 1.08 TM7SMSTS5FS0046 46 ±8 1.35:1 2.50 TM7SMSTS5FS0020 20 TM7SMSTS5FS0031 ±5 31 TM7SMSTS5FS0061 ±5 61 TM7SMSTS5FS0076 ±8 76 TM7SMSTS5FS0091 ±8 91 TM7SMSTS5FS00100 ±8 100 TM7SMSTS5FS00122 ± 12 122 ± 12 1.35:1 1.32 1.35:1 1.79 1.35:1 3.21 1.35:1 3.92 1.35:1 4.63 1.35:1 5.03 1.35:1 B 6.04 7 M23053/5-304-0 5 M23053/5-305-0 3 16701078-01 6 NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . 4 2 1 ITEM KEY DIMENSION NEED 100% INSPECTION A RoHS Compliant 6~30 ±1 0.5~3 4 ±0.05 (XX) REF. DIMENSION ISO2768-V (mm) 30-120 120~400 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 1K~2K ISO2768-F (mm) 30~120 ±0.1 3 ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY C DRAWN: CHECKED: ATUM-8/2-0 1.2" RC-TUBG,HTSK,3/16,BLK N/A 0.4" N/A SEE TABLE N/A QTY N/A ADHESIVE , 1/8 HST BLACK N/A TM7S-5FS-00 SMA FEMALE CONNECTOR FOR 078 CABLE N/A PART NUMBER DESCRIPTION TM7S-STS-00 Falcon INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF 2 N/A TUBG,HTSK,ID=0.315”,ADHSV,BLK, M23053/4-101-0 APPROVED: DRAWING INFORMATION IS STRICTLY PROHIBITTED. C-TUBG,HTSK,GPO,1/8,BL LOW LOSS .078 COAXIAL CABLE CONN, SSMP, FEMALE, STRAIGTH, TL INTERCONNECT TECHNOLOGIES MATERIAL: PART NUMBER: TM7SMSTS5FS00XX SIZE A4 SCALE 2:1 0.7" .5" 1 1 MATERIAL Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: PART NAME: B ASSY, 078, SSMP ST(F) - SMA(F), XXcm, 2ps CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TM7SSSTS5FS031C 价格&库存
很抱歉,暂时无法提供与“TM7SSSTS5FS031C”相匹配的价格&库存,您可以联系我们找货
