TM4SSSTSSTS031C-P
TM4SSSTSSTS031C-P
    TRI-STAR
    同轴电缆组件 SSMP 至 SSMP 0.047" 半刚性电缆 12.20"(310.00mm)
TM4SSSTSSTS031C-P 数据手册
4 3 2 D 4 REGION A 2 3 DESCRIPTION 1 PRELIMINARY RELEASE DATE 30.Jun.20 BY Falcon D 1 CABLE LENGTH " XXX" C PART NUMBER LENGTH ( CM) TM4SSSTSSTS0016-P ±5 20 TM4SSSTSSTS0031-P ±5 31 TM4SSSTSSTS0046-P ±5 46 TM4SSSTSSTS0061-P ±8 61 TM4SSSTSSTS0076-P ±8 76 TM4SSSTSSTS0091-P ±8 91 TM4SSSTSSTS00100-P ±8 100 TM4SSSTSSTS00122-P B TOLERANCE (mm) 16 TM4SSSTSSTS0020-P ± 12 122 ± 12 Max VSWR Up to 65Ghz C Max insertion loss(dB) Up to 65Ghz 1.35:1 1.03 1.35:1 1.27 1.35:1 1.74 1.35:1 2.45 1.35:1 3.16 1.35:1 3.87 1.35:1 4.58 1.35:1 4.98 1.35:1 5.99 B NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . 5, MATECHED CABLE @2.0pS AND PACKAGED OR SUPPLIED TOGETHER . 4 3 2 1 ITEM KEY DIMENSION NEED 100% INSPECTION A REV. RoHS Compliant 6~30 ±1 0.5~3 4 ±0.05 (XX) REF. DIMENSION ISO2768-V (mm) 30-120 120~400 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 1K~2K ISO2768-F (mm) 30~120 ±0.1 3 ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY DRAWN: CHECKED: M23053/5-105-0 M23053/4-101-0 TM4S-STS-00 INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF DRAWING INFORMATION IS STRICTLY PROHIBITTED. 2 LOW LOSS .047 COAXIAL CABLE SEE TABLE "XXX" + "XXX" DESCRIPTION QTY CONN, SSMP, FEMALE, STRAIGTH, TL PART NUMBER APPROVED: 1" ADHESIVE , 1/8 HST BLACK 16701047-PB Falcon SEMI-REGID , 3/16 HST BLACK INTERCONNECT TECHNOLOGIES MATERIAL: PART NUMBER: TM4SSSTSSTSXX-P SIZE A4 SCALE 2:1 2" 4 Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: ASSY, 047, SSMP ST(F)x2, XXcm, PAIR PART NAME: CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TM4SSSTSSTS031C-P 价格&库存
很抱歉,暂时无法提供与“TM4SSSTSSTS031C-P”相匹配的价格&库存,您可以联系我们找货
