TM7SSSTSSTS016C-P
TM7SSSTSSTS016C-P
    TRI-STAR
    同轴电缆组件 SSMP 至 SSMP 0.078" OD 外径同轴缆线 6.299"(160.00mm)
TM7SSSTSSTS016C-P 数据手册
4 3 2 D 4 REGION A 2 3 DESCRIPTION 1 PRELIMINARY RELEASE DATE 30.Jun.20 BY Falcon D 1 CABLE LENGTH "XXX" C PART NUMBER LENGTH ( CM) TM7SSSTSSTS0016-P ±5 20 TM7SSSTSSTS0031-P ±5 31 TM7SSSTSSTS0046-P ±5 46 TM7SSSTSSTS0061-P ±8 61 TM7SSSTSSTS0076-P ±8 76 TM7SSSTSSTS0091-P ±8 91 TM7SSSTSSTS00100-P ±8 100 TM7SSSTSSTS00122-P B TOLERANCE (mm) 16 TM7SSSTSSTS0020-P ± 12 122 ± 12 Max VSWR Up to 65Ghz C Max insertion loss(dB) Up to 65Ghz 1.35:1 1.08 1.35:1 1.32 1.35:1 1.79 1.35:1 2.50 1.35:1 3.21 1.35:1 3.92 1.35:1 4.63 1.35:1 5.03 1.35:1 6.04 B NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . 5, MATECHED CABLE @2.0pS AND PACKAGED OR SUPPLIED TOGETHER . RoHS Compliant 6~30 ±1 0.5~3 4 ±0.05 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 ±0.1 3 SEMI-REGID , 1/4 HST BLACK 2 16701078-01 LOW LOSS .078 COAXIAL CABLE 1 (XX) REF. DIMENSION 1K~2K ISO2768-F (mm) 30~120 M23053/5-106-0 ITEM ISO2768-V (mm) 30-120 120~400 4 3 KEY DIMENSION NEED 100% INSPECTION A REV. ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY DRAWN: CHECKED: M23053/4-101-0 TM7S-STS-00 Falcon INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF 2 CONN, SSMP, FEMALE, STRAIGTH, TL PART NUMBER APPROVED: DRAWING INFORMATION IS STRICTLY PROHIBITTED. ADHESIVE , 1/8 HST BLACK DESCRIPTION INTERCONNECT TECHNOLOGIES MATERIAL: PART NUMBER: TM7SSSTSSTSXX-P SIZE A4 SCALE 2:1 1" 2" SEE TABLE "XXX" + "XXX" 4 QTY Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: PART NAME: ASSY, 078, SSMP ST(F)x2, XXcm, PAIR CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TM7SSSTSSTS016C-P 价格&库存
很抱歉,暂时无法提供与“TM7SSSTSSTS016C-P”相匹配的价格&库存,您可以联系我们找货
