TM4SMSTSSTS031C
TM4SMSTSSTS031C
    TRI-STAR
    同轴电缆组件 SSMP 至 SSMP 0.047" 半刚性电缆 12.20"(310.00mm)
TM4SMSTSSTS031C 数据手册
4 D 3 1 3 2 REV. A REGION DESCRIPTION 1 PRELIMINARY RELEASE DATE 30.Jun.20 BY Falcon D 2 CABLE LENGTH "XXX" C PART NUMBER LENGTH ( CM) TOLERANCE (mm) Max VSWR Up to 65Ghz Max insertion loss(dB) Up to 65Ghz TM4SM8STST0016 16 ±5 1.35:1 1.03 TM4SM8STST0046 46 ±8 1.35:1 2.45 TM4SM8STST0020 20 TM4SM8STST0031 ±5 31 TM4SM8STST0061 ±5 61 TM4SM8STST0076 ±8 76 TM4SM8STST0091 ±8 91 TM4SM8STST00100 ±8 100 TM4SM8STST00122 ± 12 122 ± 12 1.35:1 C 1.27 1.35:1 1.74 1.35:1 3.16 1.35:1 3.87 1.35:1 4.58 1.35:1 4.98 1.35:1 5.99 B B NOTE(S): 1, SOLDER PER IPC J-STD-001, USING LEAD FREE SOLDER. 2, NOMINAL TOLERANCE REFR TO ISO2768-F. 3, CABLE LENGTH TOLERANCE REFER TO ISO2768-V, AND TOLERANCE VALUE MULTIPIED BY 2. 4, WORK ORDER LABEL NOT SHOWN WILL BE ATTACHED TO CABLE . 3 M23053/4-101-0 1 PART NUMBER 2 ITEM KEY DIMENSION NEED 100% INSPECTION A RoHS Compliant 6~30 ±1 0.5~3 4 ±0.05 (XX) REF. DIMENSION ISO2768-V (mm) 30-120 120~400 ±1.5 3~6 ±0.05 ±2.5 6~30 ±0.1 400~1K ±4 1K~2K ISO2768-F (mm) 30~120 ±0.1 3 ±6 120~400 ±0.2 >2K ±8 400~1000 ±0.3 FOR REF. ONLY DRAWN: CHECKED: 16701047-PB TM4S-STS-00 Falcon APPROVED: INFORMATION CONTAINED ON THIS DRAWING IS CONFIDENTIAL AND MAY ALSO CONTAIN PROPRIETARY CARLISLE/CUSTOMER INFORMATION. DRAWING CONTENT IS ONLY INTENDED FOR USE OF THE ABOVE CUSTOMER IF YOU ARE NOT THE INTENDED RECIPIENT OR AUTHORIZED EMPLOYEE OF ABOVE COMPANY NAME, YOU ARE HEREBY NOTIFIED ANY USE, DUPLICATION, RECONSTRUCTION, OR DISTRIBUTION OF DRAWING INFORMATION IS STRICTLY PROHIBITTED. 2 ADHESIVE , 1/8 HST BLACK N/A CONN, SSMP, FEMALE, STRAIGTH, TL N/A SEE TABLE MATERIAL QTY LOW LOSS .047 COAXIAL CABLE DESCRIPTION INTERCONNECT TECHNOLOGIES MATERIAL: PART NUMBER: TM4SM8STST00XX SIZE A4 SCALE 2:1 .5"+.5" N/A 2 Dongguan City,Guangdong P.R. China 523533 PROJECT NAME: PART NAME: ASSY, 047, SSMP ST(F) - SSMP ST(F), XXcm, 2ps CABLE ASSEMBLY DO NOT SCALE DRAWING 1 REVISION: DATA: A 30.Jun.20 SHEET 1 OF 1 A
TM4SMSTSSTS031C 价格&库存
很抱歉,暂时无法提供与“TM4SMSTSSTS031C”相匹配的价格&库存,您可以联系我们找货
