VBL Series
Ø 0.118″ (3mm) PCB Mounted
Light Pipe for Surface Mount LED
VBL Series features vertical press-fit board mount LED light pipes
available in a range of different lengths with either a flat or a domed top.
Applications
• Audio/Video
• Industrial Robots
• Darkroom Equipment
• Agriculture
• Entertainment
• Medical
• IoT
• Data Center Solutions
• Transportation Power Systems
Key Features
Rigid board mount light pipe for surface mount LEDs
3mm round lens with either a domed or flat face
The VBL light pipes are mounted onto the PCB using push-fit lugs in close proximity to the LED
Features a press-fit installation into the PCB board which simplifies installation and enables faster assembly
Protects LED from ESD
Optical grade PMMA for maximum light transmission
Frosted surface diffuses light and provides uniform brightness and a soft glow
Operating temp: Max 194F(90˚C)
Standard lengths from 0.20″ to 1.000″
For custom length contact VCC
RoHS and REACH Compliant
vcclite.com | 1.800.522.5546
VBL Series | 09/22 Rev 3 | Page 1 of 4
Ordering Data
Series
Diameter
Shape
Overall Length
Color
VBL
3
D
0200
C
3
3mm
D
Dome
0200
.2″ (5.1mm)
F
Flat
0250
.25″ (6.4mm)
0300
.3″ (7.6mm)
0350
.35″ (8.9mm)
0400
.4″ (10.2mm)
0450
.45″ (11.4mm)
0500
.5″ (12.7mm)
0550
.55″ (13.9mm)
0600
.6″ (15.2mm)
0700
.7″ (17.8mm)
0800
.8″ (20.3mm)
0900
.9″ (22.8mm)
1000
1.0″ (25.4mm)
C
Clear
*Custom lengths available upon request
Example:
VBL3D0900C
VBL Series, PCB mount, .9″ (22.8mm) Overall Length, Dome Shape, Clear
VBL Series | 09/22 Rev 3 | Page 2 of 4
Product Dimensions
VBL Series
RED LINES ARE REPRESENTED
FLAT SERIES
Overall Length (OL)
.2″ (5.1mm)
.25″ (6.4mm)
.3″ (7.6mm)
.35″ (8.9mm)
.4″ (10.2mm)
.45″ (11.4mm)
.5″ (12.7mm)
.55″ (13.9mm)
.6″ (15.2mm)
.7″ (17.8mm)
.8″ (20.3mm)
.9″ (22.8mm)
1.0″ (25.4mm)
Mounting Hole Pattern
Notes:
1. All dimensions are in inches [millimeters]
2. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice.
VBL Series | 09/22 Rev 3 | Page 3 of 4
Product Specifications
Materials
PMMA, Optically clear
Body
Temperature Specifications
Operating Temperature
Max 194F(90˚C)
Installation Specifications
Diameter
Ø 0.117″ ± 0.002
Standard Lengths
.2″ to 1.0″ (5.1mm to 25.4mm)
Compliances and Approvals
VBL Series | 09/22 Rev 3 | Page 4 of 4
很抱歉,暂时无法提供与“VBL3F0400C”相匹配的价格&库存,您可以联系我们找货
