VBL1603
VBL1603
    VBSEMI(微碧)
    TO263-3
    类型:N沟道;漏源电压(Vdss):60V;连续漏极电流(Id):210A;功率(Pd):375W;导通电阻(RDS(on)@Vgs,Id):12mΩ@4.5V,20A;阈值电压(Vgs(th)@Id...
VBL1603 数据手册
VBL1603 www.VBsemi.com N-Channel 60 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) • Halogen-free According to IEC 61249-2-21 Definition 60 RDS(on) () at VGS = 10 V 0.0028 RDS(on) () at VGS = 4.5 V 0.0120 ID (A) • TrenchFET® Power MOSFET • Package with Low Thermal Resistance • 100 % Rg and UIS Tested 210 Configuration Single • Compliant to RoHS Directive 2002/95/EC D D2PAK (TO-263) G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) SYMBOL LIMIT Drain-Source Voltage PARAMETER VDS 60 Gate-Source Voltage VGS ± 20 Continuous Drain Current TC = 25 °C TC = 125 °C Continuous Source Current (Diode Conduction)a Pulsed Drain Currentb Single Pulse Avalanche Current Single Pulse Avalanche Energy Maximum Power Dissipationb L = 0.1 mH TC = 25 °C TC = 125 °C Operating Junction and Storage Temperature Range ID V 210 120 IS 120 IDM 480 IAS 75 EAS 281 PD UNIT a a 375 125 A mJ W TJ, Tstg - 55 to + 175 °C SYMBOL LIMIT UNIT THERMAL RESISTANCE RATINGS PARAMETER Junction-to-Ambient Junction-to-Case (Drain) PCB Mountc RthJA 40 RthJC 0.4 °C/W Notes a. Package limited. b. Pulse test; pulse width  300 μs, duty cycle  2 %. c. When mounted on 1" square PCB (FR-4 material). d. Parametric verification ongoing. 服务热线:400-655-8788 1 VBL1603 www.VBsemi.com SPECIFICATIONS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. - MAX. UNIT Static Drain-Source Breakdown Voltage Gate-Source Threshold Voltage Gate-Source Leakage VDS VGS = 0, ID = 250 μA 60 VGS(th) VDS = VGS, ID = 250 μA 2.0 VDS = 0 V, VGS = ± 20 V IGSS 4.0 - - ± 100 VGS = 0 V VDS = 60 V - - 1.0 - - 50 Zero Gate Voltage Drain Current IDSS VGS = 0 V VDS = 60 V, TJ = 125 °C VGS = 0 V VDS = 60 V, TJ = 175 °C - - 350 On-State Drain Currenta ID(on) VGS = 10 V VDS5 V 120 - - VGS = 10 V ID = 30 A - 0.0028 - VGS = 10 V ID = 30 A, TJ = 125 °C - 0.0060 - VGS = 10 V ID = 30 A, TJ = 175 °C - 0.0080 - VGS = 4.5 V ID = 20 A - 0.012 - - 109 - - 7300 9125 - 935 1170 Drain-Source On-State Resistancea Forward Transconductanceb RDS(on) gfs VDS = 15 V, ID = 30 A V nA μA A  S Dynamicb Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss - 647 810 Total Gate Chargec Qg - 184 276 - 24.7 - - 50.4 - f = 1 MHz 0.5 1.1 1.6 - 19 29 VDD = 30 V, RL = 0.27  ID  110 A, VGEN = 10 V, Rg = 2.5  - 23 35 - 83 125 - 35 53 - - 480 A - 0.9 1.5 V Gate-Source Chargec Qgs Gate-Drain Chargec Qgd Gate Resistance Rg Turn-On Delay Timec Rise Timec Turn-Off Delay Timec Fall Timec VGS = 0 V VGS = 10 V VDS = 25 V, f = 1 MHz VDS = 30 V, ID = 110 A td(on) tr td(off) tf pF nC  ns Source-Drain Diode Ratings and Characteristicsb Pulsed Currenta ISM Forward Voltage VSD IF = 100 A, VGS = 0 Notes a. Pulse test; pulse width  300 μs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 VBL1603 www.VBsemi.com TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 180 225 200 150 V GS = 1 0 V t h r u 8 V ID - Drain Current (A) ID - Drain Current (A) 175 150 125 V GS = 5 V 100 75 120 90 60 T C = 25 °C 50 30 T C = 125 °C 25 V GS = 3 V T C = - 55 °C 0 0 0 8 4 12 16 0 20 1 VDS - Drain-to-Source Voltage (V) 2 3 4 VGS - Gate-to-Source Voltage (V) 5 Transfer Characteristics Output Characteristics 0.015 250 200 RDS(on) - On-Resistance (Ω) g fs - Transconductance (S) V GS = 4.5 V T C = - 55 °C 150 T C = 25 °C 100 T C = 125 °C 50 0.0012 0.009 0.006 V GS = 10 V 0.003 0 0 0 32 16 48 64 0 80 20 ID - Drain Current (A) Transconductance 100 120 On-Resistance vs. Drain Current 10 VGS - Gate-to-Source Voltage (V) 12 000 10 000 C - Capacitance (pF) 40 60 80 ID - Drain Current (A) Ciss 8000 6000 4000 2000 Coss ID = 110 A 8 V DS = 30 V 6 4 2 Crss 0 0 0 10 20 30 40 50 60 0 20 40 60 80 100 120 140 160 180 200 VDS - Drain-to-Source Voltage (V) Qg - Total Gate Charge (nC) Capacitance Gate Charge 服务热线:400-655-8788 3 VBL1603 www.VBsemi.com TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 100 2.1 ID = 30 A IS - Source Current (A) V GS = 10 V (Normalized) RDS(on) - On-Resistance T J = 25 °C 10 1.8 1.5 V GS = 4.5 V 1.2 T J = 150 °C 1 0.1 T J = - 50 °C 0.9 0.01 0.6 - 50 0.001 - 25 0 25 50 75 100 125 150 175 0 0.2 TJ - Junction Temperature (°C) 0.6 0.8 1.0 1.2 VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source Drain Diode Forward Voltage 0.8 0.05 0.4 0.04 VGS(th) Variance (V) RDS(on) - On-Resistance (Ω) 0.4 0.03 0.02 0 - 0.4 ID = 5 mA - 0.8 T J = 150 °C ID = 250 μA 0.01 - 1.2 T J = 25 °C 0 0 2 4 6 8 - 1.6 - 50 10 - 25 0 25 50 75 100 125 150 175 TJ - Temperature (°C) VGS - Gate-to-Source Voltage (V) On-Resistance vs. Gate-to-Source Voltage Threshold Voltage 80 VDS - Drain-to-Source Voltage (V) ID = 10 mA 77 74 71 68 65 - 50 - 25 0 25 50 75 100 125 150 175 TJ - Junction Temperature (°C) Drain Source Breakdown vs. Junction Temperature 服务热线:400-655-8788 4 VBL1603 www.VBsemi.com THERMAL RATINGS (TA = 25 °C, unless otherwise noted) 1000 IDM Limited I D - Drain Current (A) 100 Limited by RDS(on)* 100 µs ID Limited 1 ms 10 10 ms 100 ms, 1 s, 10 s, DC 1 TC = 25 °C Single Pulse 0.1 BVDSS Limited 0.01 0.01 * VGS 100 0.1 1 10 VDS - Drain-to-Source Voltage (V) minimum VGS at which R DS(on) is specified Safe Operating Area Normalized Effective Transient Thermal Impedance 1 0.1 0.01 0.001 0.0001 10-4 10-3 10-2 10-1 1 Square Wave Pulse Duration (s) 10 100 1000 Normalized Thermal Transient Impedance, Junction-to-Ambient 服务热线:400-655-8788 5 VBL1603 www.VBsemi.com THERMAL RATINGS (TA = 25 °C, unless otherwise noted) 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-4 10-3 10-2 10-1 1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case Note • The characteristics shown in the two graphs - Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C) - Normalized Transient Thermal Impedance Junction-to-Case (25 °C) are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities can widely vary depending on actual application parameters and operating conditions. 服务热线:400-655-8788 6 VBL1603 www.VBsemi.com TO-263AB A (Datum A) 3 A 4 4 L1 B A E c2 H Gauge plane 4 0° to 8° 5 D B Detail A Seating plane H 1 2 C 3 C L L3 B A1 L4 Detail “A” Rotated 90° CW scale 8:1 L2 B A 2 x b2 c 2xb E 0.010 M A M B ± 0.004 M B 2xe Plating 5 b1, b3 Base metal c1 (c) D1 4 5 (b, b2) Lead tip MILLIMETERS 4 E1 Section B - B and C - C Scale: none View A - A INCHES MILLIMETERS INCHES DIM. MIN. MAX. MIN. MAX. DIM. MIN. MAX. MIN. MAX. A 4.06 4.83 0.160 0.190 D1 6.86 - 0.270 - A1 0.00 0.25 0.000 0.010 E 9.65 10.67 0.380 0.420 b 0.51 0.99 0.020 0.039 E1 6.22 - 0.245 - b1 0.51 0.89 0.020 0.035 e b2 1.14 1.78 0.045 0.070 H 14.61 2.54 BSC 15.88 0.575 0.625 b3 1.14 1.73 0.045 0.068 L 1.78 2.79 0.070 0.110 c 0.38 0.74 0.015 0.029 L1 - 1.65 - 0.066 c1 0.38 0.58 0.015 0.023 L2 - 1.78 - 0.070 c2 1.14 1.65 0.045 0.065 L3 D 8.38 9.65 0.330 0.380 L4 0.25 BSC 4.78 5.28 0.100 BSC 0.010 BSC 0.188 0.208 ECN: S-82110-Rev. A, 15-Sep-08 DWG: 5970 Notes 1. Dimensioning and tolerancing per ASME Y14.5M-1994. 2. Dimensions are shown in millimeters (inches). 3. Dimension D and E do not include mold flash. Mold flash shall not exceed 0.127 mm (0.005") per side. These dimensions are measured at the outmost extremes of the plastic body at datum A. 4. Thermal PAD contour optional within dimension E, L1, D1 and E1. 5. Dimension b1 and c1 apply to base metal only. 6. Datum A and B to be determined at datum plane H. 7. Outline conforms to JEDEC outline to TO-263AB. 服务热线:400-655-8788 7 VBL1603 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR D2PAK: 3-Lead 0.420 0.355 0.635 (16.129) (9.017) (10.668) 0.145 (3.683) 0.135 (3.429) 0.200 0.050 (5.080) (1.257) Recommended Minimum Pads Dimensions in Inches/(mm) 8 服务热线:400-655-8788 VBL1603 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VBL1603 价格&库存
很抱歉,暂时无法提供与“VBL1603”相匹配的价格&库存,您可以联系我们找货
VBL1603
  • 50+5.54265
  • 300+5.40971
  • 1000+5.25804
