CLIFF
HOLES TO SUIT
SCREW USED
ISS.
AMEND
DATE
1
2
ISSUED
ADD WHITE VARIANTS
12/02/15
03/02/20
19.0
Ø24 +0.2
Material:
1.
Insert: ABS UL94 HB
2.
Frame: Polyamide UL94 V-2
3.
Inner Overmouldings: PE + PVC
4.
Shell: Nickel plated steel
5.
Contacts: Gold Plated
37
5
2.8
2.3
Notes:
1.
Voltage rating: 30V ac
2.
Current rating: 1.8 A max
3.
Contact resistance: 50mΩ max
4.
Insulation resistance: 20MΩ min
5.
Dielectric withstanding voltage: 500V AC
6.
Operating Temperature: -20°C to 50°C
n24
31
Ø2.50
24
'X' VERSION
Ø2.5 PLAIN HOLES
RoHS
ü
COMPLIANT
TOLERANCE
26
19
FIXING HOLE VARIANTS:
Ø3.5mm CSK 82° x Ø5.85
'X' VERSION HAS Ø2.5 PLAIN HOLES.
Cliff Electronic Components Ltd.
76 Holmethorpe Avenue, Holmethorpe Industrial Estate,
Redhill, Surrey, RH1 2PF, England, UK
Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk
THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED
TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK.
© 2015
NO DEC. PLACE ±
1 DEC. PLACE ±
2 DEC. PLACE ±
HOLE Ø ±
ANGLES ±
UNLESS
OTHERWISE STATED
DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK.
FINISH:
See Notes
See Notes
DRAWN:
D.P.J.
MATERIAL:
TITLE:
APPROVED: D.P.J.
3rd ANGLE PROJECTION:
DO NOT SCALE
FEED THROUGH USB 3.0 A to USB 3.0 A, Nickel Plated
DRWG. No.
CP30205N
FORM: A4DRWGH
很抱歉,暂时无法提供与“CP30205NXW”相匹配的价格&库存,您可以联系我们找货
