CLIFF
USB2.0 B-A FEEDTHROUGH CONNECTOR
Feedthrough Features
l Fits standard XLR Ø24mm cutout.
l No soldering or punch termination. Use standard cable for each connector style.
l Front or rear mounted.
l Low rear profile
General:
Please note: Functionality is affected by cable quality, length and
cable wiring configuration.
Material:
1.Insert: ABS
2. Plastic Frame: Polyamide UL94 V2
3. Metal Frame: Diecast, Black or Nickel plated
VARIANTS
4. Shell: Nickel plated steel
Part No.
5. Contacts: Gold Plated
CP30207N
USB2.0 B-A Black plastic frame, CSK holes
Notes:
CP30207NW USB2.0 B-A White plastic frame, CSK holes
1. Voltage rating: 30V AC
CP30207NM USB2.0 B-A Nickel plated metal frame, CSK holes 2. Current rating: 1.5 A max
CP30207NM3 USB2.0 B-A Nickel plated metal frame, M3 holes
3. Contact resistance: 50mΩ max
CP30207NMB USB2.0 B-A Black metal frame, CSK holes
4. Insulation resistance: 20MΩ min
CP30207NM3B USB2.0 B-A Black metal frame, M3 holes
5. Dielectric withstanding voltage: 500V AC
CP30207NX
USB2.0 B-A Black plastic frame, PLAIN holes
6. Operating Temperature: -20°C to 50°C
CP30207NXW USB2.0 B-A White plastic frame, PLAIN holes
© CLIFF 05/2020 ISS.1
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP30207NXW”相匹配的价格&库存,您可以联系我们找货
