CP30606NX1
CP30606NX1
    CLIFF
    适配器连接器 USB-B(USB TYPE-B),插座 至 USB-A(USB TYPE-A),插座 面板安装,法兰
CP30606NX1 数据手册
CLIFF ISS. AMEND DATE 1 ISSUED 16/09/20 17.15 (0.675") HOLES TO SUIT SCREW USED 22.86 (0.900") 29.00 40.0 PLAIN HOLE VARIANTS 'X' VERSION Ø2.5 'X1' VERSION Ø3.2 39.7 19.0 2.3 29.00 16.7 35.5 22.5 RoHS ü COMPLIANT 3x HOLE VARIANTS ∅3.2mm CSK 90° x Ø5.85 'X' PLAIN Ø2.5 HOLES 'X1' PLAIN Ø3.2 HOLES Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2020 Specification: 1. Voltage rating: 30V AC 2. Current rating: 1.8A max 3. Contact resistance: 50mΩ max 4. Insulation resistance: 20MΩ min 5. Dielectric withstanding voltage: 500V AC 6. Operating Temperature: -20°C to 50°C Material: 1. Insert: ABS UL94 HB 2. Frame: Polyamide UL94 V-2 3. Inner Overmouldings: PE + PVC 4. Shell: Nickel plated steel 5. Contacts: Gold Plated DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: TOLERANCE NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± UNLESS OTHERWISE STATED DO NOT SCALE FRONT MOUNT SLIM FT USB3 B-A DRWG. No. CP30606N FORM: A4DRWGH
CP30606NX1 价格&库存
很抱歉,暂时无法提供与“CP30606NX1”相匹配的价格&库存,您可以联系我们找货
