CLIFF
ISS.
AMEND
DATE
1
ISSUED
16/09/20
17.15
(0.675")
HOLES TO SUIT
SCREW USED
22.86
(0.900")
29.00
40.0
PLAIN HOLE VARIANTS
'X' VERSION Ø2.5
'X1' VERSION Ø3.2
39.7
19.0
2.3
29.00
16.7
35.5
22.5
RoHS
ü
COMPLIANT
3x HOLE VARIANTS
∅3.2mm CSK 90° x Ø5.85
'X' PLAIN Ø2.5 HOLES
'X1' PLAIN Ø3.2 HOLES
Cliff Electronic Components Ltd.
76 Holmethorpe Avenue, Holmethorpe Industrial Estate,
Redhill, Surrey, RH1 2PF, England, UK
Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk
THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED
TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK.
© 2020
Specification:
1.
Voltage rating: 30V AC
2.
Current rating: 1.8A max
3.
Contact resistance: 50mΩ max
4.
Insulation resistance: 20MΩ min
5.
Dielectric withstanding voltage: 500V AC
6.
Operating Temperature: -20°C to 50°C
Material:
1.
Insert: ABS UL94 HB
2.
Frame: Polyamide UL94 V-2
3.
Inner Overmouldings: PE + PVC
4.
Shell: Nickel plated steel
5.
Contacts: Gold Plated
DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK.
FINISH:
See Notes
See Notes
DRAWN:
T.J.O.
MATERIAL:
TITLE:
APPROVED: D.P.J.
3rd ANGLE PROJECTION:
TOLERANCE
NO DEC. PLACE ±
1 DEC. PLACE ±
2 DEC. PLACE ±
HOLE Ø ±
ANGLES ±
UNLESS
OTHERWISE STATED
DO NOT SCALE
FRONT MOUNT SLIM FT USB3 B-A
DRWG. No.
CP30606N
FORM: A4DRWGH
很抱歉,暂时无法提供与“CP30606N”相匹配的价格&库存,您可以联系我们找货
