CLIFF
ISS.
AMEND
DATE
1
ISSUED
07/01/21
DUAL MOUNT
CAN BE FRONT OR REAR MOUNTED
17.15
(0.675")
HOLES TO SUIT
SCREW USED
22.86
(0.900")
29.00
42.0
Ø3.20 PLAIN HOLE
CP30705NMX1
41.7
19.0
2.3
16.7
2.80
29.00
35.5
22.5
RoHS
ü
COMPLIANT
4x HOLE VARIANTS
Ø3.2mm CSK 90° x Ø5.85
M3 x 0.5 THREAD
#4-40 UNC THREAD
PLAIN Ø3.2 HOLES
Cliff Electronic Components Ltd.
76 Holmethorpe Avenue, Holmethorpe Industrial Estate,
Redhill, Surrey, RH1 2PF, England, UK
Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk
THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED
TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK.
© 2021
Specification:
1.
Voltage rating: 30V AC
2.
Current rating: 1.8A max
3.
Contact resistance: 50mΩ max
4.
Insulation resistance: 20MΩ min
5.
Dielectric withstanding voltage: 500V AC
6.
Operating Temperature: -20°C to 50°C
NO DEC. PLACE ±
1 DEC. PLACE ±
2 DEC. PLACE ±
HOLE Ø ±
ANGLES ±
3rd ANGLE PROJECTION:
DO NOT SCALE
DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK.
FINISH:
See Notes
See Notes
DRAWN:
T.J.O.
MATERIAL:
TITLE:
APPROVED: D.P.J.
TOLERANCE
Material:
1.
Insert: ABS UL94 HB
2.
FT Frame: Diecast, Nickel plated
3.
Inner Overmouldings: PE + PVC
4.
Shell: Nickel plated steel
5.
Contacts: Gold Plated
UNLESS
OTHERWISE STATED
DUAL SLIM METAL FT USB3 A-A
DRWG. No.
CP30705NM
FORM: A4DRWGH
很抱歉,暂时无法提供与“CP30705NM”相匹配的价格&库存,您可以联系我们找货
