CLIFF
DUALSLIM USB3.0 B-A METAL FRAME
FEEDTHROUGH CONNECTOR
Can be front or rear mounted in the panel
VARIANTS
Part No.
CP30706NM
DUALSLIM USB3.0 B-A Nickel frame, CSK holes
CP30706NMB
DUALSLIM USB3.0 B-A Black metal frame, CSK holes
CP30706NM3
DUALSLIM USB3.0 B-A Nickel frame, M3 holes
CP30706NMB3
DUALSLIM USB3.0 B-A Black metal frame, M3 holes
CP30706NM440
DUALSLIM USB3.0 B-A Nickel frame, #4-40 holes
CP30706NMB440 DUALSLIM USB3.0 B-A Black metal frame, #4-40 holes
CP30706NMX1
DUALSLIM USB3.0 B-A Nickel frame, Ø3.2 PLAIN holes
CP30706NMBX1 DUALSLIM USB3.0 B-A Black metal frame, Ø3.2 PLAIN holes
Feedthrough Features
Material:
Fits standard rectangular cutout.
1. Insert: ABS UL94 HB
Front or rear mounting through the panel.
2. Frame: Diecast, Nickel or Black plated
Various hole mounting options.
3. Shell: Nickel plated steel
No soldering or punch termination. Use standard cable for
4. Contacts: Gold Plated
each connector style.
Notes:
Low rear profile.
1. Voltage rating: 30V ac
2. Current rating: 1.8 A max
General:
3. Contact resistance: 50mΩ max
Please note: Functionality is affected by cable quality, length and
4. Insulation resistance: 20MΩ min
cable wiring configuration.
5. Dielectric withstanding voltage: 500V AC
6. Operating Temperature: -20°C to 50°C
© CLIFF 02/2021 ISS.1
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP30706NM440”相匹配的价格&库存,您可以联系我们找货
