CLIFF
DUALSLIM CAT5e RJ45 SHIELDED METAL
FRAME FEEDTHROUGH CONNECTOR
Can be front or rear mounted in the panel
VARIANTS
Part No.
CP30720SM
DUALSLIM Cat5e RJ45 Shielded Nickel frame, CSK holes
CP30720SMB
DUALSLIM Cat5e RJ45 Shielded Black metal frame, CSK holes
CP30720SM3
DUALSLIM Cat5e RJ45 Shielded Nickel frame, M3 holes
CP30720SMB3
DUALSLIM Cat5e RJ45 Shielded Black metal frame, M3 holes
CP30720SM440
DUALSLIM Cat5e RJ45 Shielded Nickel frame, #4-40 holes
CP30720SMB440 DUALSLIM Cat5e RJ45 Shielded Black metal frame, #4-40 holes
CP30720SMX1
DUALSLIM Cat5e RJ45 Shielded Nickel frame, Ø3.2 PLAIN holes
CP30720SMBX1 DUALSLIM Cat5e RJ45 Shielded Black metal frame, Ø3.2 PLAIN holes
Feedthrough Features
Material:
Fits standard rectangular cutout.
1. RJ45 In-Line Coupler: ABS UL94-V0 Fully Shielded
Front or rear mounting through the panel.
2. RJ45 In-Line Coupler Contact:
Various hole mounting options.
Phosphor Bronze, 3-50 micro inches
No soldering or punch termination. Use standard cable for
gold plating over nickel plate.
each connector style.
3. PCB: FR4
Low rear profile.
4. Frame: Diecast, Nickel or Black plated
Performance:
General:
1. T568A & T568B wiring.
Please note: Functionality is affected by cable quality, length
2. Meet ISO/IEC 11801 and EN50173
and cable wiring configuration.
3. Meet ANSI/TIA/EIA 568B.2
4. Rating 125VAC RMS 1.5A
5. Operating Temperatures: Min -10°C Max +70°C
© CLIFF 04/2022 ISS.2
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP30720SM”相匹配的价格&库存,您可以联系我们找货
