CP30720
CP30720
    CLIFF
    模块 连接器 至 Cat5e
CP30720 数据手册
CLIFF DUALSLIM CAT5e RJ45 FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30720 DUALSLIM Cat5e RJ45 Black plastic frame, CSK holes CP30720X DUALSLIM Cat5e RJ45 Black plastic frame, Ø2.5 PLAIN holes CP30720X1 DUALSLIM Cat5e RJ45 Black plastic frame, Ø3.2 PLAIN holes Feedthrough Features Material: — Fits standard rectangular cutout. 1. RJ45 In-Line Coupler: ABS UL94-V0 — Front or rear mounting through the panel. 2. RJ45 In-Line Coupler Contact: — Various hole mounting options. Phosphor Bronze, 3-50 micro inches — No soldering or punch termination. Use standard cable for each gold plating over nickel plate. connector style. 3. PCB: FR4 — Low rear profile. 4. Frame: Polyamide UL94-V2 Performance: General: 1. T568A & T568B wiring. Please note: Functionality is affected by cable quality, length and 2. Meet ISO/IEC 11801 and EN50173 cable wiring configuration. 3. Meet ANSI/TIA/EIA 568B.2 4. Rating 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +60°C © CLIFF 04/2022 ISS.2 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30720 价格&库存
很抱歉,暂时无法提供与“CP30720”相匹配的价格&库存,您可以联系我们找货
