TPG100
TPG100
    ATG
    CAULK GUN PNEUMATIC 10.5 OZ
TPG100 数据手册
Put the squeeze on caulking labor costs. Caulk Master® air power gets the job done five times faster than manual caulk guns. 99 Washington Street Melrose, MA 02176 Fax 781-665-0780 TestEquipmentDepot.com Caulk Master bead is smoother 3-foot air hose with 1/4" NPT fitting Unique twist lock bayonet barrel mount Air Powered Dispensing Guns Caulk Master® Air Powered Dispensing Guns Caulk Master has a dispensing gun to suit your application. The Caulk Master line of dispensing guns offers both do-it-yourselfers and professionals the most efficient, time saving way yet to apply sealant, caulk, and adhesives. Powered with a standard compressor or air tank, Caulk Master guns dramatically increase productivity, reducing a four hour job to 45 minutes! Test Equipment Depot - 800.517.8431 - 99 Washington Street Melrose, MA 02176 1/10th Gal.Tube 1 Quart Sausage/Chub 2.5 oz. Tube 6 oz. Tube 12 oz. Tube PG110 PG151 PG140 PG102 Standard Cartridge High Viscosity MultiCartridge Sausage Pack Aerospace Patented trigger mechanism makes it easy to vary the amount of material being dispensed and reduces operator fatigue. PG100 Standard Cartridge PG151 Multi-cartridge PG140 Sausage Pack The PG100 is the perfect choice for the serious do-ityourselfer or occasional use professional. Designed to apply low and medium viscosity materials, it uses standard 10.3 oz. cartridges. Lightweight, high-impact, non-corrosive Valox® construction. The PG151 is a 2-in-1 tool that uses both 10.3 and 30 ounce cartridges, making it suitable for any job, large or small. Both the standard sized and large 30 ounce cartridges load easily with Caulk Master's instant load twist lock bayonet barrel mount. The PG140 will accept any standard 10.3 oz. cartridge, but also has the capability to use sausage style caulk and adhesive packs. Like all other Caulk Master products, both the standard and sausage pack barrels feature instant load twist lock bayonet barrel mount for quick and easy reloading. Caulk Master provides a smooth, even flow of material for a superior bead in a fraction of the time needed by old manual methods. All Caulk Master dispensing guns come with a 3-foot air hose and standard 1/4" NPT fitting. Easily connects to a high-pressure regulator and air tank or compressor. Caulk Master bead Viscosity Low Medium High PG100 Typical caulk gun bead Application/User Do-It-Yourself Automotive Construction Maint./Repair Marine Aerospace Cartridge Capacity FAX 781.665.0780 - TestEquipmentDepot.com (purchase separately) 3-foot air hose with standard 1/4" NPT fitting Saving time and much more. Durable, non-corrosive Valox® construction (aluminum for PG110) Whether you're a do-it-yourselfer or a pro, Caulk Master can dramatically increase your productivity and make it easier for you to produce the perfect bead...all while reducing fatigue and the chance of injury. Caulk Master air powered dispensing guns give you a level of control simply unattainable with manual guns. The patented trigger mechanism gives you the exact amount of caulk, sealant, or adhesive you need, so you can dispense material at a smooth, steady pace. Even "weep" at the end of a run is a thing of the past...when you stop squeezing the trigger, the flow stops immediately. It's no wonder that demanding industries such as construction, automotive, marine, and aerospace are loyal users of Caulk Master products. PG100 Unique instant load twist lock bayonet barrel mount PG151 Cat. No. PG100 PG110 Patented trigger mechanism for exceptional dispensing control PG10260 PG102120 PG10225 Contents Valox Gun Body, 3-foot air hose with 1/4" NPT fitting, 10.3 oz. cartridge barrel 70 PSI max. PG110 Aluminum Gun Body, 3-foot air hose with 1/4” NPT fitting, 10.3 oz. aluminum PG140 Valox Gun Body, 3-foot air hose with 1/4” NPT fitting, 10.3 oz. and cartridge barrel, 100 PSI max. sausage cartridge barrels, 70 PSI max. PG151 Valox Gun Body, 3-foot air hose with 1/4” NPT fitting, 10.3 oz. and 30 oz. cartridge barrels, 70 PSI max. PG10260 Valox Gun Body, 3-foot air hose with 1/4” NPT fitting, 6 oz. metal PG102120 Valox Gun Body, 3-foot air hose with 1/4” NPT fitting, 12 oz. metal aerospace cartridge barrel, 70 PSI max. aerospace cartridge barrel, 70 PSI max. PG10225 Valox Gun Body, 3-foot air hose with 1/4” NPT fitting, 2.5 oz. metal aerospace cartridge barrel, 70 PSI max. PG140 Test Equipment Depot - 800.517.8431 - 99 Washington Street Melrose, MA 02176 FAX 781.665.0780 - TestEquipmentDepot.com Cooper Tools P.O. Box 728, Apex, NC 27502 • http://www.coopertools.com CT00-1929 AC/25M/PRINTED 6/00/USA COOPER NO. 55157 Copyright © 2000, Cooper Industries, Inc. 1. Twist barrel to unlock. Remove empty cartridge 2. Drop in new cartridge and twist barrel to lock 3. Get back to work. Its that simple!
TPG100 价格&库存
很抱歉,暂时无法提供与“TPG100”相匹配的价格&库存,您可以联系我们找货
