CC5062
CC5062
    QUANTICCROVEN
    晶体
CC5062 数据手册
Quartz Crystal Specification Frequency 10.000000 MHz Cut SC-cut Vibration Mode 3 overtone Holder HC-43, 0.530” (13.46 mm) maximum height Calibration Tolerance ± 2 ppm at 85 ºC Load Capacitance 20 pF Frequency-Temperature Stability TOP from 80 to 90 ºC Motional Resistance Rs 100 ohms maximum Motional Capacitance C1 0.175 fF typical Shunt Capacitance C0 2.8 to 3.5 pF Quality Factor Q > 1,000,000 Drive Level < 100 u W Retrace < ± 0.01 ppm within 1 hr following 24 hrs off power Aging ≤ ± 0.05 ppm/year after 30 days Marking 1. Frequency 2. Date Code 3.Bar code Label with S/N – standard electrical data to be provided Environmental Shock: rd MIL-STD-202G, M213 Condition C - 100 g, 6 msec, ½ sine Vibration: MIL-STD-202G, M204 Condition C, 10 g peak, 55 to 2000 Hz, 1 sweep per axis Solderability, Seal and Workmanship per MIL-PRF-3098 RoHS Parts are RoHS compliant C 20-Aug-20 Add Date Code to Marking B 11-Mar-13 Revise C1/C0 values to std design 13003006 LM A 24-Jan-12 Remove Part Number Marking C. Visniar Revision Date Description Approved APPROVALS DATE ENG SALES D. Scepanovic 05-Feb-2010 CAGE CODE SIZE G. Johnston 05-Feb-2010 00809 A CV DWG. NO. CC5062 SHEET 1 0F 1 500 Beech Street, Whitby, Ontario, Canada, L1N 5S5 crovensales@crovencrystals.com Note: Specifications subject to change. Consult factory for latest revision. REV C
CC5062 价格&库存
很抱歉,暂时无法提供与“CC5062”相匹配的价格&库存,您可以联系我们找货
