P37-15
P37-15
    DABURNELECTRONICS
    DIP5 模块
    封闭式 AC DC 转换器 2 输出 15V -15V 500mA,500mA 105 ~ 125 VAC 输入
P37-15 数据手册
P POLYTRON DEVICES, Inc. LINEAR ENCAPSULATED POWER MODULES REGULATED 5Vdc-250Vdc P.C. CARD OR CHASSIS MOUNTING Specifications FEATURES • UL, CUL & CE Approved (All Models) • Regulation Line & Load 0.2% to 0.02% • P.C. Card/Chassis Mounting • High Isolation Voltage Available • Short Circuit Protection 115 Vac, 50 to 400 Hz @ 25°C INPUT Voltage Range................................................105-125 Vac, 50-60 Hz ...........................................................400Hz available For Worldwide Input Voltage Options, see Options Available chart on pg. 4 OUTPUT Voltage Accuracy @ FL for Singles, ................................ .......±1.0% Line Regulation: Single Output.....................................±0.2% Load Regulation: Single Output.....................................±0.2% Temperature Coefficient .............................................±0.02%/°C typ. GENERAL Isolation Resistance...........................................................50MOhms Protection.......................................................Short Circuit Protection ENVIRONMENTAL Operating Temperature Range........................................-25 to +71°C ........................-40 to +85°C Optional Storage Temperature Range...........................................-25 to +85°C Cooling................................................................Free Air Convection PHYSICAL Dimensions..................................................See Chart and Diagrams • Single, Dual & Triple Outputs 1. Case style ending with letter “T”(Chassis mounted units with terminal barrier strip) are designated by the suffix “T” . Case styles A,B,C,D,G and E (PC card mounting) do not require suffixing. 2. Most competitors pinouts available--contact factory. 3. For 400HZ, use suffix “04” after model number. 4. For wide operating temperature range, use “W” suffix after model number. • Finger Safe Terminal Available T FAS P3, P5 Series 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 83 Y VER I L DE Linear Encapsulated Power Modules 5Vdc-250Vdc output Linear Encapsulated Power Modules (Continued) Selection Guide Output (Vdc) 5 9 10 SINGLE OUTPUT VOLTAGE 12 15 18 24 48 50 75 100 Output Current (mA) Regulation Line Load Ripple & Noise (mV rms) Case Model Number Slow Blow (A) 200 500 500 1000 1000 1000 2000 3000 2000 0.20% 0.20% 0.02% 0.20% 0.02% 0.02% 0.02% 0.02% 0.02% 0.20% 0.20% 0.05% 0.20% 0.05% 0.05% 0.10% 0.15% 0.10% 1.0 0.5 0.5 1.0 1.0 0.5 1.0 1.0 0.5 G, 1GT A, 1AT A, 1AT B, 1BT B, 1BT C, 1CT C, 1CT D, 1DT D, 1DT P34-5SM P37 P37-1 P38 P38-1 P38/1.56 P39 P39-3 P39-9ST 1/32 1/16 1/16 1/8 1/8 1/8 1/4 3/8 1/2 120 150 250 500 1000 1500 100 120 200 500 1000 80 120 200 300 500 800 50 50 100 50 100 200 300 500 800 1000 50 100 200 50 100 200 300 35 70 150 200 25 50 100 150 0.10% 0.10% 0.10% 0.02% 0.02% 0.02% 0.10% 0.02% 0.10% 0.02% 0.10% 0.10% 0.02% 0.10% 0.10% 0.02% 0.02% 0.10% 0.02% 0.02% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.20% 0.20% 0.20% 0.05% 0.05% 0.05% 0.20% 0.05% 0.05% 0.05% 0.10% 0.05% 0.05% 0.05% 0.10% 0.10% 0.10% 0.10% 0.05% 0.05% 0.05% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.05% 0.05% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 1.0 1.0 1.0 0.5 0.5 0.5 1.0 1.0 1.0 0.5 1.0 1.0 1.0 1.0 1.0 0.5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 2.0 2.0 2.0 2.0 3.0 2.0 2.0 2.0 3.0 2.0 2.0 3.0 3.0 E, 1ET A, 1AT B, 1BT C, 1CT D, 1DT D, 1DT E, 1ET A, 1AT B, 1BT C, 1CT D, 1DT E, 1ET A, 1AT B, 1BT C, 1CT C, 1CT D, 1DT E, 1ET A, 1AT B, 1BT E, 1ET A, 1AT B, 1BT C, 1CT D, 1DT H, 1HT H, 1HT B, 1BT B, 1BT C, 1CT B, 1BT B, 1BT C, 1CT D, 1DT B, 1BT B, 1BT C, 1CT D, 1DT B, 1BT B, 1BT C, 1CT D, 3DT P33-10SM P33-10S P34-10S P37-10S P38-10S P38-10SA P32-12SM P33-12S P34-12S P37-12S P38-12S P33-15SM P33-12S P34-15S P35-15S P37-15S P38-15S P32-18SM P32-18S P33-18S P32-24SM P33-24S P34-24S P35-24S P37-24S P38-24S P39-24S P32-48S P33-48S P34-48S P32-50S P33-50S P34-50S P35-50S P32-75S P33-75S P34-75S P35-75S P32-100S P33-100S P34-100S P35-100S 1/32 1/16 1/16 1/8 3/8 1/4 1/32 1/16 1/16 1/5 3/10 1/32 1/16 1/10 1/8 1/5 3/10 1/32 1/32 1/16 1/32 1/16 1/8 1/5 1/4 3/8 1/2 1/16 1/8 1/4 1/16 1/8 1/4 3/8 1/10 1/5 3/10 3/8 1/16 1/8 1/4 3/8 1. Case style ending with letter “T”(Chassis mounted units with terminal barrier strip) are designated by the suffix “T” . Case styles A,B,C,D,G and E (PC card mounting) do not require suffixing. 2. Most competitors pinouts available--contact factory. 3. For 400HZ, use suffix “04” after model number. 4. For wide operating temperature range, use “W” suffix after model number. P POLYTRON DEVICES 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 84 Linear Encapsulated Power Modules 5Vdc-250Vdc output Linear Encapsulated Power Modules (Continued) Selection Guide Output (Vdc) SINGLE OUTPUT 150 180 200 250 ±5 ±8 ±10 DUAL OUTPUTS ±12 ±15 ±18 TRIPLE VOLTAGE ±24 5/±12 5/±15 Output Current (mA) Regulation Line Load Rippl e & Noise (mV r ms) Case Model Number Slow Blow (A) 17 35 70 100 15 30 55 80 12 25 50 75 10 20 40 60 0.05% 0.05% 0.05% 0.20% 0.05% 0.05% 0.05% 0.10% 0.05% 0.05% 0.05% 0.10% 0.05% 0.05% 0.05% 0.10% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 0.20% 2.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 A,1AT B,1BT C,1CT D,1DT B, 1BT B, 1BT C, 1CT D, 1DT B, 1BT B, 1BT C, 1CT D, 1DT B, 1BT B, 1BT C, 1CT D, 1DT P32-150S P33-150S P34-150S P35-150S P32-180S P33-180S P34-180S P35-180S P32-200S P33-200S P34-200S P35-200S P32-250S P33-250S P34-250S P35-250S 1/16 2/10 1/4 3/8 1/16 1/5 1/4 3/8 1/16 1/8 1/4 3/8 1/16 1/8 1/4 3/8 ±50 ±100 ±200 ±300 ±500 ±1000 ±500 ±100 ±25 ±25 ±50 ±100 ±200 ±300 ±500 ±800 ±25 ±25 ±25 ±50 ±50 ±100 ±100 ±200 ±200 ±350 ±350 ±500 ±800 ±50 ±100 ±50 ±100 ±200 0.02% 0.10% 0.10% 0.02% 0.02% 0.01% 0.10% 0.02% 0.10% 0.02% 0.02% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.20% 0.02% 0.20% 0.02% 0.20% 0.02% 0.20% 0.02% 0.20% 0.02% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.02% 0.10% 0.10% 0.05% 0.05% 0.10% 0.10% 0.05% 0.10% 0.05% 0.05% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.20% 0.02% 0.20% 0.02% 0.20% 0.02% 0.20% 0.05% 0.20% 0.05% 0.10% 0.10% 0.10% 0.10% 0.10% 0.20% 0.20% 1.0 1.0 1.0 0.5 0.5 1.0 2.0 2.0 2.0 5.0 5.0 1.0 1.0 1.0 1.0 1.0 2.0 1.0 0.5 1.0 0.5 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 A, 2AT A, 2AT B, 2BT C, 2CT C, 2CT D, 2DT D, 2DT A, 2AT G, 1GT A, 2AT A, 2AT A, 2AT B, 2BT C, 2CT D, 2DT D, 2DT G, 1GT A, 2AT A, 2AT A, 2AT A, 2AT A, 2AT A, 2AT B, 2BT B, 2BT C, 2CT C, 2CT D, 2DT D, 2DT A, 2AT B, 2BT B, 2BT B, 2BT C, 2CT P32-5 P33-5 P34-5 P35-5 P37-5 P38-5 P37-8 P33-10 P31-12M P31-12 P32-12 P33-12 P34-12 P35-12 P37-12 P38-12 P31-M P31 P31-1 P32 P32-1 P33 P33-1 P34 P34-1 P35 P35-1 P37-15 P38-15 P32-18 P33-18 P32-24 P33-24 P34-24 1/32 1/32 1/16 1/10 1/8 1/4 1/5 1/16 1/32 1/32 1/32 1/16 1/8 1/5 3/10 2/5 1/32 1/32 1/32 1/16 1/16 1/10 1/10 1/5 1/5 1/4 1/4 3/8 1/2 1/16 1/10 1/16 1/8 1/4 250/±60 250/±120 300/±180 500/±120 1000/±150 250/±50 250/±100 300/±150 500/±100 1000/±150 0.02% 0.02% 0.02% 0.02% 0.02% 0.02% 0.02% 0.02% 0.02% 0.02% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 0.10% 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 C, 3CT C, 3CT C, 3CT C, 3CT D,3DT C, 3CT C, 3CT C, 3CT C, 3CT D, 3DT P51-12 P52-12 P53-12L P53-12 P53-1280 P51-15 P52-15 P53-15L P53-15 P53-1580 1/10 1/10 1/5 1/5 1/4 1/10 1/10 1/5 1/5 1/4 1. Case style ending with letter “T”(Chassis mounted units with terminal barrier strip) are designated by the suffix “T” . Case styles A,B,C,D,G and E (PC card mounting) do not require suffixing. 2. Most competitors pinouts available--contact factory. 3. For 400HZ, use suffix “04” after model number. 4. For wide operating temperature range, use “W” suffix after model number. P POLYTRON DEVICES 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 85 Linear Encapsulated Power Modules 5Vdc-250Vdc output P3, P5 SERIES Mechanical Specification I/O Connections OPTIONS AVAILABLE 220Vac 230Vac 240Vac 100Vac Pin SINGLE DUAL TRIPLE 1 -Vdc* -Vdc* Com (5) 2 No Pin No Pin +5Vdc 3 Com* Com* -12 / -15 4 No Pin No Pin CMN (12/15) 5 +Vdc +Vdc +12 / +15 * -Vdc Internally connected to COM for single output units. SUFFIX X XA XE Q AX 115/220 Alternate Pin-Out 22 Chassis mounting with terminal barrier strip (case styles ending with letter ("T") T Finger Safe Chassis Mount Terminal Barrier Strip Wide Oper. Temp. Range 400Hz NOTE Extra pin required-see pg.90 for detailed drawing FST W 04 2 Most competitors pinouts available--contact factory. CASE A, B, C, D CASE E 2 D 2.0 (51.0) 1.56 1.25 (39.6) 0.875 (31.8) (22.2) C B A 0.25 REF 20 MIN (6.35) AC L 0.75 1.1 (27.9) 2 1.0 (25.4) AC 0.15 ((3.81) REF 1 0.75 (19.1) C 2.0 (51.0) 3 TWO MOUNTING (19.1) INSERTS #4-40 x 0.1 DEEP CASE G + 0.20 (5.10) MOUNTING #4-40 x 0.12 (3.0 DEEP) AC 2.25 (57.15) AC BOTTOM VIEW BOTTOM VIEW CASE H 2 1 2 AC 0.15 (38.1) 1.70 (43.2) 2.00 (51.0) 2.00 (51.0) 0.85 (21.6) 3 BOTTOM VIEW P34-5SM: 1 + 5VDC 2 and 3 COM P31-M + P31-12M: 1 - 15VDC 2 COM 3 + 15VDC Height: 2.0” P SIDE VIEW All Dimensions are in inches (mm) 0.85 (21.6) 1.65 (41.9) 0.40 (1.0) DIA PINS 5 0.15 (38.1) AC E 1.80 (45.70) 0.875 (22.2) G 0.20 (5.1) LG MIN 0.175 (44.5) 2.5 (63.5) 2.2 0.55 (55.9) (13.97) 4 3.2 (81.3) 3.5 (88.9) 0.40 (1.0) DIA PIN - 1.00 (25.4) 0.20 (5.10) MIN TRIM .040 (10.16)DIA PINS 0.15 (3.81)REF 0.15 REF 0.1 (2.54) 0.275 (7.1) 1.75 (44.5) 1.20 (30.5) 0.60 (15.2) 2 POLYTRON DEVICES 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 86 Linear Encapsulated Power Modules 5Vdc-250Vdc output Linear Encapsulated Power Modules (Continued) Power Supply Options CHASSIS MOUNTED UNITS 4.10 (104.1) 1CT 1BT BOTTOM VIEW AC 1DT 2.00 (50.8) 1.56 (39.11) 1.25 (31.75) 0.875 (19.05) 2.50 (63.5) 2.50 (63.5) TOP VIEW AC CMN V+ 1AT 1.35 (34.29) 2.00 (50.8) FOUR MOUNTING INSERTS #4-40 x 0.1 DEEP SINGLE OUTPUT MODELS 4.10 (104.1) AC 2DT 2.00 (50.8) 1.56 (39.11) 1.25 (31.75) 0.875 (19.05) 2CT 2BT 2.50 (63.5) 2.50 (63.5) TOP VIEW AC V- BOTTOM VIEW 1.68 (42.67) 2.00 (50.8) CMN 2AT FOUR MOUNTING INSERTS #4-40 x 0.1 DEEP V+ DUAL OUTPUT MODELS 4.10 (104.1) 2.50 (63.05) AC 3DT 2.00 (50.8) 3CT 1.56 (39.11) 3BT 2.50 (63.5) TOP VIEW AC VCMN BOTTOM VIEW 2.32 (58.93) 2.00 (50.8) V+ 5V CMN 1.25 (31.75) FOUR MOUNTING INSERTS #4-40 x 0.1 DEEP +5 TRIPLE OUTPUT MODELS Height: 2.0” SINGLE AND DUAL OUTPUT (CASE 1HT) All Dimensions are in inches (mm) P POLYTRON DEVICES 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 87 P 3, P 5 S E R IE S ALTERNATE PIN-OUT SINGLE & DUAL OUTPUT MODELS 2.50 (63.5) 1.10 (27.9) -OUT 0.60 0.50 0.50 0.60 (15.2) (12.7) (12.7) (15.2) 0.15 (3.80) - +OUT 0.15 (3.80) 1.60 (40.6) 1.0 (25.4) 3.50 (88.9) INSERTS 4.40 THREAD 0.12 (3.2) DEEP AC BOTTOM VIEW 0.88 (22.4) + COM COM +5V 5V 1.60 (40.6) 1.0 (25.4) 2.00 (50.8) 1.62 (41.1) 1.25 (31.8) Note: * No connection for single output units * To specify alternate pin-out use suffix "22" 2.50 (63.5) 1.10 (27.9) COM SIDE VIEW TRIPLE OUTPUT MODELS A B C 3.50 (88.9) INSERTS 4.40 THREAD 0.12 (3.2) DEEP 1.60 (40.6) AC AC 2.20 (55.9) BOTTOM VIEW 1.60 (40.6) D 0.04 (1.0) DIA. PINS AC 2.20 (55.9) 0.20 (5.10) MIN All Dimensions are in inches (mm) (C ontinued) POWER SUPPLY ACCESSORIES S OC K E TS PO 4.20 (106.68) 3.20 (81.28) A S UPPL B B S OC K E TS 4.20 (106.68) 3.20 (81.28) 0.25 (6.35) A B B 2.00(50.8) 2.64(67.06) B A A B . T eflon ins er ts A B A . 0. 141 hole for mounting unit 3.20 (81.28) A 3/32 B B 4.20 (106.68) N O T E 1: F or 2. 2" A C pin s pa c ing s pec ify S -5/22 A ll Dimens ions a r e in inc hes (mm) P OLYT R ON DE V IC E S 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 88 2.64(67.06) B B 4.20 (106.68) P 0.25 (6.35) A 1.10 B A . 0. 141 hole for mounting unit 3.20 A (81.28) 0.16 (4.064) B A 1.10 (27.94) B Y 0.16 (4.064) 2.00 NOTE 1 (50.8) A WE R A B . T eflon ins er ts 3/32 A B P 3, P 5 S E R IE S Single and Dual Output Chassis Mount (Case A, B, C, D) 115/220Vac Input 1. Case Height dimensions can be: 1.25”, 1.56” or 2.0” depending on model 4.1(104.14) 2. For 220V Operation Jumper “f1” to S2” (1) 3. Apply 220V Excitation Across “S1” and “F2” 2.5(63.5) (3) TOP VIEW (4) Chassis Mounted Units 2.32(58.92) (2) 4. For 115V Operation Jumper “S1” to “S2” and “F1” to F2” 5. Apply 115V excitation across “S1” and “F1” (5) (6) (7) Terminal Single Voltage Dual V0 1 S1 S1 2 F1 F1 3 S2 S2 4 F2 F2 5 NC -V0 6 CMN CMN 7 +Vout +V0 Triple Output Chassis Mount 115/220Vac Input 1. Case Height dimensions can be: 1.56” or 2.0” depending on model -12/-15 S2 F1 12/15 CMN TOP VIEW +12/+15 Chassis Mounted Units 5 CMN S1 +5V 2. Wire primaries in parallel for 115Vin Series for 220Vin 2.5(63.5) F2 3. S = Start of Primary Winding 4. F = Finish of Primary Winding 5. For lower voltage operation wire AC Input in parallel and connect S1 and S2 and F1 and F2 together and excite across 6. For higher voltage operation put winding in series, wire F1 to S2 and excite S1 and F2 4.7(119.38) P P OLYT R ON DE V IC E S 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 89 P 3, P 5 S E R IE S Single and Dual Output PC Mount 115/220Vac Input 3.5(88.9) 1. Case height dimensions can be: 1.25”, 1.56” or 2.0” depending on model 1.6(40.64) 1.6(40.64) (4) Connections (2) 2.2(55.88) 1.0” 2.5(63.5) 1.1(27.94) (7) 1.1(27.94) (6) (5) (3) 1.0(25.4) PIN 1 Start Winding 1 PIN 2 Finish Winding 1 PIN 3 Finish Winding 2 PIN 4 Start Winding 2 PIN 5 +PIN 6 Common Out for Single V PIN 5 For Dual Vout -Vout PIN 6 For Dual Vout CMN PIN 7 For Single/ Dual +Vout (1) Triple Output PC Mount 115/220Vac Input 0.15 REF (TYP) 1. Case height: 2.0” 3.2(81.28) 2. Pin 5-15 VDC Output -12 or -15 (4) (5) (8)) (6) (1)) (7) 3.5(88.9) P 4. Pin 7+15 VDC Output +12 or +15 5. For 115V Input jumper 2 to 9 and 1 to 8 2.5(63.5) (9)) 4.40 x 0.10 DP MIN (2PLCS) 3. Pin 6±15 VDC Return CMN 12/15 1.6(40.64) (3) (2)) 0.60 (15.24) 0.55 (13.97) 1.1(27.94) 1.65(41.91) 2.2(55.88) 1.6(40.64) 6. For 220V Input jumper 8 to 9 Connections Pin 1 F/N Winding 2 Pin 2 Start Winding 1 Pin 3 5 VDC Return Pin 4 +5 VDC Output Pin 8 FIN Winding 1 Pin 9 Start Winding 2 P OLYT R ON DE V IC E S 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 90 P 3, P 5 S E R IE S B E N C H A DA P T E R Des igned for a ll S ingle a nd Dua l L inea r P ower S upplies in C a s es A , B , C , D. MO DE L M-5 (2. 0" A C P in S pa c ing) M-5/22(2. 2" A C P IN S P A C IN G ) P P OLYT R ON DE V IC E S 44 Richboynton Road, Dover, New Jersey 07801 U.S.A. • Tel: (973) 345-5885 • Fax: (973) 328-3130 sales@polytrondevices.com • www.polytrondevices.com 91
P37-15 价格&库存
很抱歉,暂时无法提供与“P37-15”相匹配的价格&库存,您可以联系我们找货
