DFR0552
DFR0552
    DFROBOT
    MCP4725 数模转换器(DAC) 数据采集 Gravity 平台评估扩展板
DFR0552 数据手册
      Gravity: 12-Bit I2C DAC Module SKU: DFR0552     Introduction DFRobot Gravity 12-Bit I2C DAC is a small and easy-to-use 12-bit digital-to-analog converter with EEPROM. It can accurately convert the digital value to corresponding analog voltage signal, which is useful in may creative projects and automatic control systems. Although an analog voltage signal can be generated by PWM with traditional controllers such as Arduino and Raspberry Pi, such signal is ROUGH and NOT ACCURATE. To obtain a steady and nice analog voltage signal, the DAC is the best candidate. In addition to be applied in automatic control systems, the DAC module can be use to serve as a function generator to generate sine wave, triangular wave and even arbitrary waveform (we provide a library to generate low frequency sin and triangular wave with just a few parameters). The module employs a 12-bit DAC MCP4725. It requires no external reference voltage (DAC reference is driven from VCC directly), supports 3.3V~5V wide input voltage and has a I2C address selection switch (two address 0x60 and 0x61 are available, which support maximum two modules in cascade). The EEPROM can retain the DAC input while power-off and resume the DAC output upon power-on. Features      12-bit High Accuracy DAC On-Board EEPROM, Retain DAC Input While Power-Off Gravity I2C Interface, Plug and Play. XH2.54 4P Reserved for Expansion Wide Voltage Input, Compatible with 3.3V and 5V Controller Small Size and Easy to Install Applications    Sensor Calibration Automatic Control Systems Function Generator Specifications       Input Voltage (VCC): 3.3V~5.0V Output Voltage: 0 ~ VCC Resolution: 12-bit Working Current:
DFR0552 价格&库存
很抱歉,暂时无法提供与“DFR0552”相匹配的价格&库存,您可以联系我们找货
