Flick Zero – 3D Tracking & Gesture
pHAT for Raspberry Pi Zero
SKU: PIS-0552
Swipe, tap or flick your wrist to control your Raspberry Pi with the Flick pHAT.
Flick Zero is a 3D tracking and gesture pHAT that lets you control the Raspberry Pi Zero mini
computer as if by magic! Draw a circle, swipe your hand – Flick will track it.
Description
Flick Zero is a 3D tracking and gesture pHAT that lets you control the Raspberry Pi Zeromini
computer as if by magic! Flick uses technology that enables the PCB to detect your gestures from up
to 15cm away in 3D space. Draw a circle, swipe your hand – Flick will track it.
Integrate Flick into your Raspberry Pi project to give you multiple ways of controlling it. Using the
near field gesture technology, you’re able to hide your project behind non-conductive material
(wood/acrylic) and still use Flick (please note however that mounting it in this way may reduce the
sensor range).
Plug and play functionality allows you to get up and running within minutes. Use our software
libraries (complete with one line installer) to fully explore what you can do with Flick. Control your
computer, TV, music system and more all with a Flick of the wrist!
Features
Fully compatible with Pi Zero & Pi Zero W
Also works with Raspberry Pi A+, B+, 2B, 3B and all other Raspberry Pis with 40 GPIO pins (or
compatible boards).
3D tracking
Gesture sensing up to 15cm
Touch and Tap sensing
Communicates with the Raspberry Pi via I2C
Full software libraries (fully open-source code)
One line installer
No soldering required
Dimensions: 6.5cm x 3cm x 0.6cm
Fully CE and FCC tested and approved
Kit Contents
1 Flick Zero
8 Plastic bolts
4 Plastic spacers
3 Stickers
2 Info card
Technical Details
Chip: MGC3130 3D Tracking and Gesture Controller
Detection range: 0 to 15 cm in ideal circumstances
Temperature Range: -20Ԩ to +85Ԩ
Position Rate: 200 positions/sec
Spatial Resolution: up to 150 dpi
Proximity and Touch Sensing
Flick Large has a red/green dual colour LED that can be driven using pins LED1 and LED2
Flick Large has level shifting on board so can work with any microcontroller with either 5V or 3V3
power and data signals
Compatible with the Hillstar Development Kit over USB on PC in order to use with a computer or to
program new firmware onto the board.
Available gestures: Swipe (east to west, west to east, north to south, south to north), tap and double
tap (center, east, west, north, south), airwheel (clockwise, anti-clockwise) and touch (center, east,
west, north, south)
Works even through the Flick Large case
No detection blind spots
Low–power design
Software and Setup Guide
Software for the Flick boards is available here on GitHub
Follow this guide to set up your Flick Zero board and case
Additional information
WEIGHT
0.05 kg
DIMENSIONS
13 x 7.5 x 2.5 cm
Official Raspberry Pi Power Supply - 2.5A International Power Supply Unit
WEIGHT
0.195 kg
DIMENSIONS
10.5 x 8.5 x 6 cm
COLOUR
White, Black
Flick Zero Case
WEIGHT
0.065 kg
DIMENSIONS
3.4 x 7.2 x 2.7 cm
SELECT
No Watch Strap, Black Watch Strap, White Watch Strap
https://www.pi‐supply.com/product/flick‐zero‐3d‐tracking‐gesture‐phat‐pi‐zero/ 1‐29‐18
很抱歉,暂时无法提供与“PIS-0552”相匹配的价格&库存,您可以联系我们找货
