SEN0042
SEN0042
    DFROBOT
    GRAVITY:DIGITAL INFRARED DISTANC
SEN0042 数据手册
    DFRobot Infrared sensor breakout (SKU:SEN0042) Contents  1 Introduction 1.1 Applications 1.2 Specification 1.3 Connection Diagram 1.4 Sample Code Introduction DFRobot Infrared sensor breakout (SKU:SEN0042) This is an edge detection sensor from DFRobot. It will help your robot detect the edge of a precipice, preventing it from falling off a table or down the stairs to it's certain demise! This IR distance sensor is connected to an arduino digital pin. Applications Edge detection sensor Intelligent Mobile Robotics Platforms Home Cleaning Robots Specification Supply Voltage: 2.7~6.2v Current: < 10mA Range distance: 1~10cm Interface:1 digital pin Signal Voltage: Vcc-0.6v(High) 0.6v(Low) Size: 35x10x15mm Weight: < 5g Connection Diagram Infrared Sensor Connection Diagram Sample Code void setup(){ Serial.begin(57600); } void loop(){ Serial.print("Digital Signal:"); Serial.println(digitalRead(3),BIN); delay(50); } Powered By DFRobot © 2008-2016
SEN0042 价格&库存
很抱歉,暂时无法提供与“SEN0042”相匹配的价格&库存,您可以联系我们找货
SEN0042
    • 1+67.01165
