XON-9-L1-KIT-001
XON-9-L1-KIT-001
    DIGIINTERNATIONAL
    - HXG3000 收发器; LoRa®(LoRaWAN™) 900MHz 评估板
XON-9-L1-KIT-001 数据手册
PRELIMINARY DATASHEET 30 DAY FREE CLOUD TRIAL Manage this device with X-ON cloud IoT platform DIGI LORAWAN STARTER KIT A complete, end-to-end device, gateway and cloud kit to accelerate development of your IoT solution The Digi LoRaWAN™ starter kit provides a complete device, gateway and cloud IoT platform for developing end-toend LoRaWAN solutions. The Digi LoRaWAN kit includes a multi-sensor device, a multi-channel gateway and X-ON™ cloud IoT free trial. The X-ON cloud demonstrates automated provisioning for devices and gateways. The Digi LoRaWAN starter kit provides a cloud application using the X-ON industrial IoT platform, a highly-scalable microservices platform for large-scale LoRaWAN solutions. Each gateway supports 1.5 million messages per day delivered to the X-ON cloud. The included HXG3000 gateway offers high receive sensitivity and up to 27 dBm transmit power to deliver long-range, non-line-of-sight, two-way communications over LoRaWAN. The starter kit provides LoRaWAN Class A and Class C for both low-power battery and always-on real-time cloud-to-device control applications, respectively. The Digi LoRaWAN Client Shield (expansion board) supports rapid prototyping and development of LoRaWAN sensors on ST® Nucleo and Arduino® platforms. The client shield features the LoRaWAN module, addressing longrange, low-power, wide-area networks (LPWAN), with stackable Arduino connectors, digital input switch, RGB LED, u.FL connector, antenna and temperature sensor. An embedded AT command language and simplified Mbed C++ Embedded API support rapid integration. Your kit includes: 3 Digi 8-channel LoRaWAN HXG3000 Ethernet gateway 3 Client shield with LoRaWAN module, LED, digital input and temperature sensors 3 Digi X-ON cloud platform 30-day free trial account with scan-and-go mobile provisioning PART NUMBER DESCRIPTION XON-9-L1-KIT-001 Digi LoRaWAN starter kit with LoRaWAN gateway and client shield The module is certified with support for Class A, Class C and secure multicast. The client shield is compatible with select ST Nucleo and Arduino boards providing LoRaWAN client-side connectivity. The starter kit provides a complete framework for a fully functional LoRaWAN client device. With the full suite of Digi services and solutions, OEMs can streamline development and time-to-market with integrated performance and security features. DIGI.COM SPECIFICATIONS DIGI DigiLORAWAN XBee3®GATEWAY Cellular Smart Modem, LTE CAT 1 FEATURES GATEWAY Modular gateway available for different LoRaWAN™ channel plans, supporting multiple frequency bands CAPACITY Up to 1.5 million messages per day EDGE COMPUTING Enable local data and applications to be deployed on the gateway supported with X-ON.Edge SENSE AND CONTROL Complex sense and control functions can be operated independently of cloud connectivity for high reliability and low latency ANTENNA 1.7 dBi omnidirectional antenna POWER AC or PoE power supply for alternative installation options CONNECTIVITY Ethernet and LTE backhaul models available, installed with single cable and auto-connect to the X-ON™ cloud platform PROVISIONING Simple provisioning with mobile scanning app ENCLOSURE Indoor enclosure for wall or table mount CERTIFICATION FCC and IC certified LORAWAN RADIO REGIONAL BANDS US900 TX POWER / RX SENSITIVITY +27 dBm; -138 dBm CHANNELS 8 Rx; 1 Tx ANTENNA +1.7 dBm (SMA type) INTERFACES ETHERNET BACKHAUL 10/100 RJ-45 CELLULAR BACKHAUL Cat M1 (LTE version only) POWER 5 VDC; 5.5 mm LTE SIM Micro SIM CONSOLE PORT Micro USB; 115200 baud SOFTWARE AND MANAGEMENT SYSTEM CLI and API management; auto-discovery over IP TOOLS Access control lists, system monitor, logging, radio configuration, remote software upgrade NETWORKING IPv4, SSH, AES 256-bit, DHCP, TFTP, firewall and ACL PHYSICAL DIMENSIONS (L x W x H) 14.61 cm x 14.61 cm x 3.17 cm (5.75 in x 5.75 in x 1.25 in); antenna length: 12.06 cm (4.75 in) SPECIFICATIONS DIGI SHIELD DigiLORAWAN XBee3®CLIENT Cellular Smart Modem, LTE CAT 1 FEATURES SENSOR Low-power thermistor temperature sensor SWITCH Digital input slide switch LEDS Digitally controlled RGB LED REGULATOR / CONVERTER On-board 3.3 V; on-board logic converter to support both 5 V and 3.3 V I/O JUMPERS Use any MCU pins to communicate with the client ANTENNA U.FL connector (antenna included in the kit) API Arm® Mbed™ Embedded API (https://os.mbed.com) ARDUINO / NUCLEO Arduino® stackable connectors and ST® Nucleo compatible HARDWARE AND INTERFACES POWER Ultra-low power consumption with auto-hibernate LORA / LORAWAN Semtech® LoRa® and LoRaWAN™ FREQUENCY RANGE 902 MHz to 928 MHz (900) SUPPORT LoRaWAN Class A, Class C and secure multicast OUTPUT POWER 14 dBm to 20 dBm VOLTAGE RANGE 2.0 V to 3.6 V TEMPERATURE RANGE -40º C to 85º C (-40º F to 185º F) COMMUNICATION USART communication interface SYSTEM REQUIREMENTS AND DEVELOPMENT TOOLCHAINS OPERATING SYSTEM Windows® OS (10), Linux® 64-bit or macOS® USB Type-A to Mini-B cable DEVELOPMENT Arm Mbed online 877-912-3444 I 952-912-3444 DIGI.COM DIGI X-ON CLOUD CAPABILITIES – Enables you to configure, monitor and diagnose your mission-critical devices or gateways from the X-ON web and mobile interface – Automates deployment of devices and gateways with provisioning app – The Stream feature provides inter-cloud API for real-time two-way device data between multiple cloud platforms – Data templates include Transform functions for simplified integration of device data to multiple cloud platforms – Provides a multi-tenant hierarchy of accounts for OEMs, resellers and end users for managing complex business structures with role-based access controls – Users can create comprehensive IoT applications by utilizing the X-ON platform AppEngine – Provides advanced scheduling for events or timers for proactive maintenance, automated business operations and process control – Enables real-time alerts and notifications with email, SMS or API – Provides on-demand or scheduled reporting with business insights, network health or custom reports Digi X-ON™ is a complete device-to-cloud platform for connected IoT devices. The platform provides a data-ready device solution – Enables logging and tracing of real-time data messages for interactive operations and troubleshooting with devices and gateways from development through to operation. X-ON contains an integrated LoRaWAN™ network server and join server to support devices and gateways that use the LoRaWAN wireless connectivity standard. X-ON with LoRaWAN provides cloudenabled secure, long-range and low-power wireless connectivity for self-built or commercial off-the-shelf LoRaWAN devices. – Lets you integrate data through open APIs to develop more complex applications with third-party utilities INFRASTRUCTURE – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater with N+1 high-availability microservices The X-ON platform is designed to collect and analyze data directly from devices and manage the wireless network base stations that provide campus, city or nationwide coverage. X-ON and LoRaWAN support many different applications and use cases such as connected cities, smart utility, industrial IoT and smart agriculture. – Open APIs available to support application development – Auto-scale elastic capacity 2M devices/min, 20k gateways/min, 6k users/min SECURITY – TLS PKI security across all applications – Member of the Center for Internet Security® (CIS®) Learn more at www.digi.com/lorawan – AES encryption for LoRaWAN FOR MORE INFORMATION PLEASE VISIT DIGI.COM The information provided in this document is preliminary and may be subject to change without notice. DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. 877-912-3444 I 952-912-3444 © 1996-2021 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004474 A4/621 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
XON-9-L1-KIT-001 价格&库存
很抱歉,暂时无法提供与“XON-9-L1-KIT-001”相匹配的价格&库存,您可以联系我们找货
