XKB2-Z7T-ZM
XKB2-Z7T-ZM
    DIGIINTERNATIONAL
    MESH KIT ZIGBEE S2C PRO
XKB2-Z7T-ZM 数据手册
XBEE® ZIGBEE MESH KIT Provides a hands-on way to learn how to use XBee RF modules for device connectivity and mesh networking Digi’s XBee ZigBee Mesh Kit offers a great way to learn how to use XBee RF modules for device connectivity and ZigBeebased mesh networking. Starting with simple examples, we provide step-by-step guidance as you assemble the kit components to create reliable, low-power device communications and sensor networks. Mesh networking is a powerful way to route data. Range is extended by allowing data to hop from node to node, and reliability is increased by “self-healing,” the ability to create alternate paths when one node fails or a connection is lost. ZigBee is one of the most popular mesh networking protocols, specifically designed for low-data rate and lowpower applications. ZigBee is an open standard, enabling interoperability between different device manufacturers. This kit is designed for anyone interested in getting started in the world of ZigBee. Hardware and software engineers, corporate technologists, or educators and students can quickly learn more about ZigBee technology through handson examples in the kit, utilizing XBee ZigBee modules. XBee ZigBee Modules Included in the Kit XBee and XBee-PRO® ZigBee modules are ideal for applications in the energy and controls markets where time-to-market and reliability are critical. With Digi’s extensive and easy-to-use XBee API framework, customers can get their ZigBee product to market faster than any other module available in the www.digi.com The Kit Includes: 3 3 XBee Grove Development Board 3 3 XBee ZigBee Modules (TH and SMT) 3 3 Micro-USB Cables 3 2 XBee Stickers 3 Comprehensive Web and Video-Based Instruction NUMBER DESCRIPTION XKB2-Z7T-WZM XBee S2C ZigBee Mesh Kit, worldwide XKB2-Z7T-ZM XBee-PRO S2C ZigBee Mesh Kit ZKB2-Z7T-WTZM XBee S2D ZigBee Mesh Kit, worldwide industry. Features like binding and multicasting also allow for simple integration for Home Automation applications. Our modules are available in the popular XBee through-hole and surface mount form factors, providing customers the flexibility to substitute one XBee technology for another with minimal development time and risk. Using the long range XBee-PRO variant, customers can get up to two miles (3200 meters) LoS range. SPECIFICATIONS XBee® S2C ZigBee Standard | Programmable XBee-PRO® S2C ZigBee Standard | Programmable XBee® S2D ZigBee Thread Ready Standard PERFORMANCE TRANSCEIVER CHIPSET Silicon Labs EM357 SoC DATA RATE RF 250 Kbps, Serial up to 1 Mbps INDOOR/URBAN RANGE 200 ft (60 m) 300 ft (90 m) 200 ft (60 m) OUTDOOR/RF LINE-OF-SIGHT RANGE 4000 ft (1200 m) 2 miles (3200 m) 4000 ft (1200 m) TRANSMIT POWER 3.1 mW (+5 dBm) / 6.3 mW (+8 dBm) boost mode 63 mW (+18 dBm) 3.1 mW (+5 dBm) / 6.3 mW (+8 dBm) boost mode RECEIVER SENSITIVITY (1% PER) -100 dBm / -102 dBm boost mode -101 dBm -100 dBm / -102 dBm boost mode Silicon Labs EM3587 Soc FEATURES SERIAL DATA INTERFACE UART, SPI CONFIGURATION METHOD API or AT commands, local or over-the-air (OTA) FREQUENCY BAND ISM 2.4 GHz FORM FACTOR Through-Hole, Surface Mount INTERFERENCE IMMUNITY DSSS (Direct Sequence Spread Spectrum) ADC INPUTS (4) 10-bit ADC inputs DIGITAL I/O 15 ANTENNA OPTIONS Through-Hole: PCB Antenna, U.FL Connector, RPSMA Connector, or Integrated Wire SMT: RF Pad, PCB Antenna, or U.FL Connector OPERATING TEMPERATURE -40º C to +85º C DIMENSIONS (L X W X H) AND WEIGHT Through-Hole: 0.960 x 1.087 in (2.438 x 2.761 cm) SMT: 0.866 x 1.33 x 0.120 in (2.199 x 3.4 x 0.305 cm) Surface Mount Through-Hole: 0.960 x 1.297 in (2.438 x 3.294 cm) SMT: 0.866 x 1.33 x 0.120 in (2.199 x 3.4 x 0.305 cm) SMT: 0.866 x 1.33 x 0.120 in (2.199 x 3.4 x 0.305 cm) PROGRAMMABILITY MEMORY N/A 32 KB Flash / 2 KB RAM N/A 32 KB Flash / 2 KB RAM N/A CPU/CLOCK SPEED N/A HCS08 / up to 50.33 MHz N/A HCS08 / up to 50.33 MHz N/A NETWORKING AND SECURITY PROTOCOL ZigBee PRO 2007, HA-Ready with support for binding/multicasting ENCRYPTION 128-bit AES RELIABLE PACKET DELIVERY Retries/Acknowledgements IDS PAN ID and addresses, cluster IDs and endpoints (optional) CHANNELS 16 channels 15 channels 16 channels SUPPLY VOLTAGE 2.1 to 3.6V 2.7 to 3.6V 2.1 to 3.6V TRANSMIT CURRENT 33 mA @ 3.3 VDC / 45 mA boost mode 47 mA @ 3.3 VDC / 59 mA boost mode 120 mA @ 3.3 VDC 120 mA @ 3.3 VDC 33 mA @ 3.3 VDC / 45 mA boost mode RECEIVE CURRENT 28 mA @ 3.3 VDC / 31 mA boost mode 42 mA @ 3.3 VDC / 45 mA boost mode 31 mA @ 3.3 VDC 45 mA @ 3.3 VDC 28 mA @ 3.3 VDC / 31 mA boost mode POWER-DOWN CURRENT
XKB2-Z7T-ZM 价格&库存
很抱歉,暂时无法提供与“XKB2-Z7T-ZM”相匹配的价格&库存,您可以联系我们找货
