ve
tati
n
e
T
Electrical Double Layer Capacitor
DYNACAP DVS-series For Re-flow Soldering
ED-2203e-2
Features
● Size: Φ12.5×8.5 mm, compatible with surface mounting and low ESR.
Appearance sample
● High temperature tolerant (-25 to +85℃) and highly reliable.
● Unlike batteries, safe and high reliability without containing active and
hazardous substances.
● Unlike batteries, excellent charge and discharge characteristics with no
chemical reactions.
● Responds to temperature 260 ℃ during the reflow peek.
Applications
Memory backup for RTC and the others ,instantaneous power assist for batteries
Specifications
Reference,
DVS-3R6D○○○T□-R□□
Product Name
Max. operating voltage (V)
3.6V.DC
0.047F
Rated Capacitance (F)
0.1F
0.33F
0.22F
Internal resistance (Ω)
at 1 kHz
30Ω
Size ΦD× L (mm)
Φ12.5×8.5 mm
Category temperature range
-25~+85℃
○=Rated capacitance symbol
0.047F→473
0.1F →104
0.22F →224
0.33F →334
□=Additional symbol
3.1g
Weight (g)
Dimensions
(5.0)
(8.5)
(1.2)
6.0
4.0
(5.0)
13 ±0.2
12.5 ±0.5
(5.0)
0.3以下
3.2
6.0
13 ±0.2
0.4 ±0.2
単位: mm
Recommended land pattern size
NOTE: Design, Specification are subject to change without notice.
CO.,LTD.
http://www.elna.co.jp/
ELNA CO., LTD.
3-8-11 Shin-yokohama,kouhoku-ku,yokohama-city,kanagawa,222-0033 JAPAN
TEL. +81-45-470-7254 FAX. +81-45-470-7260
ve
tati
n
e
T
DYNACAP DVN series for Re-flow Soldering
ED-2203e‐2
260
230
150
120
リフロー時間
Re-flow time
プレヒート : 150℃以下・120秒以内
Preheating : 150℃ or less, within 120sec.
Peak temperature
on the surface of capacitor
ピーク温度
Peak temperature
ピーク温度 (℃)
表面温度 (℃)
Temperature on the surface of capacitor
Recommended re-flow conditions
260
250
240
230
40
50
60
リフロー時間 Re-flow time (sec.)
-Period of above 230℃-
時間 Time (sec.)
プレヒート:150℃以下・120秒以内
Pre heat : 150℃ or less , within 120sec.
Attention : リフローは上記範囲内で、可能な限り低温・短時間にて行ってください。
Recommmend reflow work at lower temperature in shorter time from the above conditon.
0.3V以上の電圧が保持された状態でのリフローはお避け下さい。
Do not reflow solder when cell voltage remains 0.3V and above.
ご注文の際は、納入仕様書等をご要求下さい。
Please refer to the specification sheet upon ordering.
CO.,LTD.
ELNA CO., LTD.
很抱歉,暂时无法提供与“RSCVS1043R6G08012T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+8.82880300+1.07000
- 600+8.78754600+1.06500
- 900+8.78735900+1.06498
- 1200+8.787151200+1.06496
- 1500+8.786961500+1.06493
- 国内价格 香港价格
- 300+7.97295300+0.96628
- 600+7.93569600+0.96176
- 900+7.93552900+0.96174
- 1200+7.935341200+0.96172
- 1500+7.935171500+0.96170
