BT600I-21
BT600I-21
    FANSTEL
    SMD44模块
    RX TXRX MOD BLUETOOTH CHIP SMD
BT600I-21 数据手册
Bluetooth Low Energy(BLE) Module BT600 Series BLE Single Mode Module BT600 Series Ver  1.22,  Oct.  2017 Specifications: ➢ Processor: Nordic nRF51822 ➢ Bluetooth: Bluetooth Low Energy ➢ Frequency: 2 . 4 0 2 ~ 2 . 4 8 0 GHz ➢ Receiver Sensitivity: -91 dBm(typical) ➢ Transmit Power 0 dBm +/- 1dB ➢ Interface UART ➢ Protocol AT C o m m a n d s ➢ Applications iOS and Android apps are available ➢ Operation voltage 1 . 8 V- 3 . 6 V ➢ Line of Sight Range 20m (60 feet) to 50m (150 feet) ➢ Encryption 128 bit using CCM encryption ➢ Dimensions 20mmX12mmX2mm ➢ Operation -25°C to +75°C ➢ Storage -40°C to +85°C Applications ➢ Smart appliances ➢ Wearable device ➢ Medical devices ➢ Health management devices ➢ Computer peripherals ➢ Other Bluetooth applications Model Summaries module SoC Flash/RAM Bluetooth range BT Antenna BT600I nRF51822 QFAB 128KB/16KB 30 meters chip BT600I-21 nRF51822 QFAA 256KB/16KB 30 meters chip BT600I-23 nRF51822 QFAC 256KB/32KB 30 meters chip BT600E nRF51822 128KB/16KB 50 meters external FCC ID Canada IC ID X8WBT600E 4100A-BT600E X8WBT600E 4100A-BT600E X8WBT600E 4100A-BT600E X8WBT600E Japan Europe 201-163100 Approved 201-163100 Approved 201-163100 Approved Australia Approved Approved Approved !1 Bluetooth Low Energy(BLE) Module BT600 Series Ver  1.22,  Oct.  2017 Table Of Contents 1. Introduction .................................................................................................................................................3 1.1. Standalone Mode .......................................................................................................................................3 2. Product Overview ........................................................................................................................................4 2.1. Nordic nRF51822 Block Diagram...............................................................................................................4 2.2. Photos 5 2.3. Mechanical Drawings .................................................................................................................................5 2.3.1. Physical Dimensions ...........................................................................................................................5 2.4. Pin Assignments of BT600 .........................................................................................................................6 2.5. Pin Functions .............................................................................................................................................7 3. Operation Parameters .................................................................................................................................9 4. AT Commands ............................................................................................................................................9 4.1. Brief description of AT commands ..............................................................................................................9 4.2. Command mode .......................................................................................................................................10 4.3. Data Mode................................................................................................................................................12 5. Reference Applications .............................................................................................................................12 5.1. Suggestion for Battery Power Application ................................................................................................12 6. BT600 Evaluation Board ...........................................................................................................................13 6.1. Communicating with a PC ........................................................................................................................13 6.2. Communicating with a Host Processor ....................................................................................................13 6.3. Evaluation Board Schematics ..................................................................................................................14 7. Miscellaneous ...........................................................................................................................................15 8. Contact Us ................................................................................................................................................15 !2 Bluetooth Low Energy(BLE) Module BT600 Series 1. Introduction Ver  1.22,  Oct.  2017 BT600 series Bluetooth single mode module uses Nordic nRF51822 Bluetooth Low Energy (BLE) chip. Three antenna options are offered: • BT600I with a chip antenna on module, line of sight range is 30 meters or 90 feet. • BT600E, an external antenna is required. Line of sight range is 50 meters or 150 feet when used with recommended antenna. • EV-BT600. Development board for BT600 modules. A PC or a host processor can communicate with BT600 through an UART port. All IO pins are available at connectors. A host processor can set BT600 to command and data mode by setting an I/O pin to high and low, respectively. When using with a PC, a jumper is used to set the BT600 IO pin. When in data mode, the host processor communicates with a smartphone, a computer, or other electronic equipment through this BT module. 1.1. Standalone Mode BT600 can operate in standalone mode – without a host processor. A 32 bit ARM Cortex™ M0 processor with 128 KB of flash memories are built-in. Development tools are available from Nordic and other 3rd parties. BT600 dimensions and pin assignments are the same as some modules from other manufacturers. Programming tools are commercially available to reprogram module for standalone operation. !3 Bluetooth Low Energy(BLE) Module BT600 Series 2. Product Overview 2.1. Nordic nRF51822 Block Diagram Ver  1.22,  Oct.  2017 The following is a block diagram of Nordic nRF51822 Bluetooth Low Energy (BLE) IC. ! Figure 1 Block diagram of nRF51822 !4 Bluetooth Low Energy(BLE) Module BT600 Series 2.2. Photos Ver  1.22,  Oct.  2017 The followings are pictures of BT600 module with an EMI shield on and without EMI shield. ! Figure 2 BT600 with an EMI shield 2.3. Mechanical Drawings 2.3.1. Physical Dimensions ! Figure 3 BT600 mechanical drawings !5 Bluetooth Low Energy(BLE) Module BT600 Series 2.4. Pin Assignments of BT600 BT600 GND RF_ANT GND P21/UART_TX P22/UART_RX P23 P24 P25 GND P26/AIN0/XL2 P27/AIN1/XL1 P28 P29 P30 GND P00/AREF0 GND P20/NC P19 P18 P17 SWCLK/NC SWDIO/nRESET P16 P15 P14 P13 GND P12/SPI_CLK P11/SPI_MISO P10/SPI_MOSI P09/I2C_SCL 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 1 2 3 4 5 6 7 8 9 10 11 12 GND P01/AIN2 GND P02/AIN3 P03/AIN4 P04/AIN5 P05/AIN6 P06/AIN7/AREF1 P07 VCC GND P08/I2C_SDA 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 ! !6 Ver  1.22,  Oct.  2017 Bluetooth Low Energy(BLE) Module BT600 Series Ver  1.22,  Oct.  2017 2.5. Pin Functions Pin Pin name Descriptions Note 1 GND Ground 2 P01, AIN2 General purpose I/O pin, ADC/LPCOMP input 2 3 GND Ground 4 P02, AIN3 General purpose I/O pin, ADC/LPCOMP input 3 5 P03, AIN4 General purpose I/O pin, ADC/LPCOMP input 4 6 P04, AIN5 General purpose I/O pin, ADC/LPCOMP input 5 7 P05, AIN6 General purpose I/O pin, ADC/LPCOMP input 6 8 P06, AIN7, AREF1 General purpose I/O pin, ADC/LPCOMP input 7, ADC/LPCOMP reference input 1 9 P07 General purpose I/O pin 10 VCC DC power input, 1.8V to 3.6V 11 GND Ground 12 P08, I2C SDA General purpose I/O pin, I2C data pin 13 P09, I2CSCL General purpose I/O pin, I2C clock pin 14 P10, SPI MOSI General purpose I/O pin, SPI MOSI pin 15 P11, SPI MISO General purpose I/O pin, SPI MISO pin 16 P12, SPI CLK General purpose I/O pin, SPI clock pin 17 GND Ground 18 P13 General purpose I/O pin 19 P14 General purpose I/O pin 20 P15 General purpose I/O pin 21 P16 General purpose I/O pin 22 SWDIO System reset (active low). Also hardware debug and flash programming I/O. 23 SWCLK Hardware debug and flash programming I/O. 24 P17 General purpose I/O pin 25 P18 General purpose I/O pin 26 P19 General purpose I/O pin 27 P20 General purpose I/O pin 28 GND Ground 29 GND Ground 30 RF ANT Connection to external antenna 31 GND Ground 32 P21, UART TX General purpose I/O pin, UART TX pin !7 Bluetooth Low Energy(BLE) Module BT600 Series 33 P22, UART RX General purpose I/O pin, UART RX pin 34 P23, Mode General purpose I/O pin, 1=command; 0=data 35 P24 General purpose I/O pin, 36 P25 General purpose I/O pin 37 GND Ground 38 P26, AIN0, XL2 General purpose I/O pin, ADC/LPCOMP input 0, Connection for 32.768 kHz crystal 39 P27, AIN1, XL1 General purpose I/O pin, ADC/LPCOMP input 1, Connection for 32.768 kHz crystal 40 P28 General purpose I/O pin 41 P29 General purpose I/O pin 42 P30 General purpose I/O pin 43 GND Ground 44 P00, AREF0 General purpose I/O pin, ADC/LPCOMP reference input 0 1.  Connect  P23  to  high  for  command  mode  and  to  low  for  data  mode. !8 1 Ver  1.22,  Oct.  2017 Bluetooth Low Energy(BLE) Module BT600 Series 3. Operation Parameters Wireless Host Interfaces Features Specifications Bluetooth V4.0 -Single Mode Frequency 2.402 - 2.480 GHz Max. Transmit Power -0.12 dBm Receiver Sensitivity -91 dBm, typical Whisper Mode Down to -55 dBm, transmit Link Budget 95 dB @ 1Mbps Raw Data Rate 1 Mbps over the air Total 28 lines, multi function UART TX, RX Ver  1.22,  Oct.  2017 Default, 9600, N, 8, 1. Baud rate from1200 to 921600bit GPIO Up to 28 lines SPI 3 lines I2C 2 lines ADC 6 lines Control Protocol Encription AT Command Sets AES Advanced Encryption Standard Supply voltage 128 bit using CCM encription 1.8V - 3.6V Power Consumption current Dimensions /尺⼨寸 27mmX13mmX2mm Environmental Operating -25°C to +75°C Storage -40°C to +85°C BT600P PCB trace antenna Line-of-sight range, 20 meters or 60 feet. BT600I Internal antenna Line-of-sight range, 30 meters or 90 feet. BT600E External antenna Line-of-sight range, 50 meters or 150 feet. Idle: 3.5 uA 4. AT Commands 4.1. Brief description of AT commands • Each command line consists of a prefix, a body and a terminator. • All command lines begin with the prefix AT (ASCII 065, 084) or at (ASCII 097, 116). • The body is a string of characters in the ASCII range 032-255. Control characters other than (carriage return; ASCII 013) and (back space; ASCII 008) in a command line are ignored. • The terminator is . !9 Bluetooth Low Energy(BLE) Module BT600 Series Ver  1.22,  Oct.  2017 • There is no distinction between upper-case and lower-case characters. A command line can have a maximum length of 80 characters. It is automatically discarded if the input is longer. Corrections are made • AT command is case-insensitive, following /r/n for end code. • The default baud rate is 9600 one stop bit and no parity 4.2. Command mode When P23 (pin 34 of BT600) is pulled high, it is set to AT command mode. In AT command mode, the host processor communicates with the processor on BT600. Command Response Parameter example AT OK or FAIL none AT+RESET OK or FAIL none +VERSION: Software version number AT+VERSION?/r/n Device name AT+NAME?/r/n AT+VERSION? AT+NAME? OK +NAME: OK AT/r/n OK/r/n AT+RESET/r/n OK/r/n +VERSION140804 OK/ r/n +NAME:EZPro OK/r/n AT+NAME=Fanstel/r/n AT+NAME= Device name OK or FAIL Or AT_Name=”Fanstel”/r/n OK/r/n AT+UART? +UART:,, OK Baud rate, AT+UART?/r/n Stop bit, +UART:115200,1,0 Parity OK/r/n AT+UART=115200/r/n +UART:115200,1,0 OK/r/n 1200 2400 4800 9600 default AT+UART= +UART: Baud rate !10 19200 Bluetooth Low Energy(BLE) Module BT600 Series Ver  1.22,  Oct.  2017 38400 57600 115200 230400 460800 921600 1000000 AT+ADDR? +ADDR: OK Device MAC address AT+REGISTER OK or FAIL none AT+QUITREGISTER OK or FAIL none AT+RX? AT+ADDR?/r/n +ADDR:abb5:cd: 604ace OK/r/n AT+REGISTER/r/n OK/r/n AT+QUITREGISTER/r/n OK/r/n +Name: AT+RX?/r/n +UART: +NAME:EZPro/r/n none +ADDR: +UART:115200,1,1/r/n +ADDR: abb5:cd: 604ace/r/n AT+DEFAULT OK or FAIL none AT+DEFAULT/r/n OK/r/n AT+RFPW?/r/n +RFPW:-4 OK/r/n 0:+4 AT_RFPW? +RFPW:parm +4~-8 1:+0 default 2:-4 3:-8 AT+RFPW= 1/r/n OK/r/n 0:+4 AT_RFPW= OK or FAIL +4~-8 1:+0 2:-4 3:-8 !11 Bluetooth Low Energy(BLE) Module BT600 Series AT +PIO= OK or FAIL AT+PIS= OK or FAIL Ver  1.22,  Oct.  2017 P00-P05 AT+PIO=05, 0\r\n 1=High , 0=low OK/r/n P00-P05 AT+PIS=05, 1\r\n 1=output, 0=input OK/r/n 4.3. Data Mode When P23 (pin 34 of BT600) is pulled low, it is set to data mode. In data model, BT600 provides transparent data transfer between the host processor and a remote device, for example, a smartphone. 5. Reference Applications 5.1. Suggestion for Battery Power Application Standby current consumption is important for battery-powered product. We suggest adding a 32.768 kHz crystal and 2 capacitors as in the following figure. The 16MHz or 32MHz main clock won’t be active at idle state to save power. ! !12 Bluetooth Low Energy(BLE) Module BT600 Series 6. BT600 Evaluation Board Ver  1.22,  Oct.  2017 6.1. Communicating with a PC A quick and easy way to evaluate BT600 is to use a PC as the host processor. Connect the development board DVB-BT600 to a PC with an USB cable. Then, • Remove jumper JP1, BT600 is set to command mode. PC will communicate with BT600. • Install jumper JP1, BT600 is set to data mode. PC will communicate with a remote device through BT600 Bluetooth wireless connection. Docklight is a testing, analysis and simulation tool for serial communication protocols (RS232, RS485/422 and others). It allows you to monitor the communication between two serial devices or to test the serial communication of a single device. Docklight significantly increases productivity in a broad range of industries, including automation and control, communications, automotive, equipment manufacturers, and embedded / consumer products. Docklight is easy to use and runs on almost any standard PC using Windows 8, Windows 7, Windows Vista or Windows XP operating system. Docklight software can be downloaded from the following: http://www.docklight.de/download_en.htm 6.2. Communicating with a Host Processor All IO pins of nRF51822 are available at connectors CON1, CON2, CON3, and CON4. To communicate with a host processor, you need to connect: • RX pin of host processor to P21, TX pin of BT600 UART. • TX pin of host processor to P22, RX pin of BT600 UART. • An IO pin to P23 of BT600, set high for command mode and set low for data mode. • Ground. !13 Bluetooth Low Energy(BLE) Module BT600 Series 6.3. Evaluation Board Schematics ! !14 Ver  1.22,  Oct.  2017 Bluetooth Low Energy(BLE) Module BT600 Series 7. Miscellaneous Ver  1.22,  Oct.  2017 • DON’T USE A MODULE WITH INTERNAL ANTENNA INSIDE A METAL CASE. • USE A MODULE WITH EXTERNAL ANTENNA INSIDE A METAL CASE. ANTENNA MUST BE OUTSIDE OF A METAL CASE. • FOR PCB LAYOUT: • o AVOID RUNNING ANY SIGNAL LINE BELOW MODULE WHENEVER POSSIBLE, o NO GROUND PLANE BELOW ANTENNA, o IF POSSIBLE, CUT-OFF THE PORTION OF MAIN BOARD PCB BELOW ANTENNA. CONNECT MODULE GROUND TO BATTERY GROUND. 8. Contact Us United States: Fanstel Corp. 7466 E. Monte Cristo Ave. Scottsdale AZ 85260 Tel. 1 480-948-4928 Fax. 1-480-948-5459 Email: info@fanstel.com Website: www.fanstel.com Taiwan: Fanstel Corp. 10F-10, 79 Xintai Wu Road Xizhu, New Taipei City, Taiwan 22101 泛世公司 臺灣省新北市汐止區新臺五路79號10樓之10, 22101 Tel. 886-2-2698-9328 Fax. 886-2-2698-4813 Email: info@fanstel.com Website: www.fanstel.com China: Fanstel Technologies Corp. 11 Jiale Street Ping-Dih, Long-Gang, Shen Zhen, GD 518117 泛世康科技(深圳)有限公司 廣東省深圳市龍崗區坪地鎮佳樂街11號 Tel. 86-755-8409-0928 Fax. 86-755-8409-0973 QQ. 3076221086 Email: info@fanstel.com Website: www.fanstel.com !15
BT600I-21 价格&库存
很抱歉,暂时无法提供与“BT600I-21”相匹配的价格&库存,您可以联系我们找货
