VM801B50A-PL
VM801B50A-PL
    BRIDGETEK
    BOARD EVAL FT801 5.0 LCD PRL BZL
VM801B50A-PL 数据手册
VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 FTDI Chip VM801B Datasheet Embedded Video Engine Basic module General Purpose Multi Media Controller The VM801B is a development module for FTDI’s FT801, which is used to develop and demonstrate the functionality of the FT801 Embedded Video Engine, EVE. This module behaves as an SPI slave, and requires a SPI Master for proper microcontroller interfacing and system integration. VM801B modules support 2 different LCD panel size options and are designed for industrial or commercial environments with precision fitted bezels in either black (-BK) or pearl (-PL).  VM801B43A-xx is the 4.3” LCD  VM801B50A-xx is the 5.0” LCD The VM801B utilises the FTDI FT801 Embedded Video Engine, EVE. Graphic, audio and touch features of the FT801 chip can be accessed with the VM801B. For a full list of the FT801’s features please see the FT801 datasheet. The VM801B has the following features:  Ready to use LCD module.  Integrated with capacitive multi-touch screen LCD panel  Firmware compatible with VM800B module in default single touch mode.  On board LCD backlight LED Driver  On board audio power amplifier and micro speaker  Flexible power supply. Powering the VM801B using either from a 2.1mm power jack , SPI master connector or via USB Micro-B port  5 V tolerant buffers when used with a 5V SPI Master.  (Optional) 3.3 V I2C interface, 100 KHz max.  Precision fitted bezel in black(-BK) or pearl (PL) Use of FTDI devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless FTDI from any and all damages, claims, suits or expense resulting from such use. VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 1 Ordering Information Note that the kits below require a 5V/1A power supply. It is NOT provided in the development kit, but is offered as an optional accessory with the following part types: Part No. Description VM801B43A-BK VM801B module, supports 3.3/5V MCU Adapter Board, 4.3” 480x272 resolution TFT LCD display panel preinstalled, black bezel VM801B50A-BK VM801B module, supports 3.3/5V MCU Adapter Board, 5” 480x272 resolution TFT LCD display panel preinstalled, black bezel VM801B43A-PL VM801B module, supports 3.3/5V MCU Adapter Board, 4.3” 480x272 resolution TFT LCD display panel preinstalled, pearl bezel VM801B50A-PL VM801B module, supports 3.3/5V MCU Adapter Board, 5” 480x272 resolution TFT LCD display panel preinstalled, pearl bezel VA-PSU-UK1 Accessory - UK Model 5V/1A USB Power Supply (Mfr # JX-B0520C-1-B) VA-PSU-US1 Accessory - US Model 5V/1A USB Power Supply (Mfr # JX-B0520B-1-B) VA-PSU-EU1 Accessory - EU Model 5V/1A USB Power Supply (Mfr # JX-B0520A-1-B) VA800A-SPI Accessory - High Speed Micro USB to SPI adapter for BASIC boards based on FT232H MPSSE design VA-FC-1M-BKW Accessory - Flat USB A to Micro B Cable 1M- Black and White VA-FC-1M-BLW Accessory - Flat USB A to Micro B Cable 1M- Blue and White Table 1-1 – Ordering information 2 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Table of Contents 1 Ordering Information ..................................................................... 2 2 Hardware Description ..................................................................... 4 2.1 VM801B module ............................................................................................ 4 2.2 Physical Descriptions .................................................................................... 5 2.2.1 2.3 Dimensions ............................................................................................. 5 VM801B Connectors ...................................................................................... 6 3 Board Schematics ........................................................................... 9 4 Hardware Setup Guide .................................................................. 12 5 6 4.1 Power Configuration ................................................................................... 12 4.2 MPSSE Setup ............................................................................................... 12 4.3 Arduino® Setup........................................................................................... 14 Assembling the Bezel and Panel Mounting ................................... 15 5.1 4.3” Dimensions .......................................................................................... 16 5.2 5.0” Dimensions .......................................................................................... 17 Specifications ............................................................................... 18 6.1 7 Optical Specification ................................................................................... 18 Contact Information ..................................................................... 20 Appendix A - References ....................................................................................... 23 Appendix B - List of Figures and Tables ................................................................. 24 Appendix C – Revision History ............................................................................... 25 3 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 2 Hardware Description Please refer to section 2.3 for connector settings. Some VM801B jumpers must be set to work properly with your system. 2.1 VM801B module Figure 2-1 - VM801B module profile 4.3” display version Figure 2-2 - VM801B module profile 5” display version NOTE: Also available in pearl. The VM801B module is intended for direct use into existing applications that require a display. This module is suitable for interfacing with an external microcontroller that has a SPI Master or I2C Master channel. The VM801B module is available in multiple options: 4.3 or 5.0 inch display options. The main functions of the VM801B are as follows:  Micro USB connector  SPI/I2C connector  2-pin connector for power supply  3.3V regulator: Takes 5V input and outputs 3.3V for on-board circuits  LCD touch screen panel  5V tolerant buffers between the SPI master interface and the Slave interface of the FT801 4 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 o Clearance No.: FTDI#425 SPI timing requirements can be found in the FT801 datasheet. The on board level converter buffers introduce additional delay. The actual maximum SPI clock frequency depends on the host system timing and connection cable length to the VM801B PCB.  3 stage audio filter and power amplifier  8Ω speaker and Audio line out option  Precision fitted bezel 2.2 Physical Descriptions 2.2.1 Dimensions The VM801B module dimensions are illustrated in Figure 2-3. 106.70 5.05 68.60 34.30 72.40 3.80 3.80 Figure 2-4 - VM801B module PCB view, 4.3 and 5 inch display version All dimensions are in mm. 5 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 2.3 VM801B Connectors Connectors and jumpers are described in the following sections.  CN1- 2-pin power connector 2 pin connector for 5V/3.3V power input to the board. Alternative to Micro USB connector.  Pin No. Name Type Description 1 VCC P 5V or 3.3V DC power supply 2 GND Table 2-1 – CN1 Pinout P Ground CN2- Micro USB Receptacle This receptacle is strictly for 5V input to power the board. There is no USB Functionality Pin No. Name Type 1 VBUS P 2 NC NA No connection 3 NC NA No connection 4 NC NA No connection 5 GND Table 2-2 – CN2 Pinout  P Description 5V power supply Ground J2 - Selection between Lineout and loop back into the power amplifier. Selection between audio lineout and loop back into the power amplifier. Jumper position Description Short pin 1-2 Audio amp enabled (default) Short pin 2-3 Audio amp mute, Audio lineout on pin 1 Table 2-3 – J2 Pin Options  J5- SPI/I2C Interface This is the interface where the SPI/I2C control and data signals are routed to. There are also power and ground pins on this interface. Pin No. Name Type Description 1 SCLK I SPI/I2C Clock input 2 MOSI I Master Out Slave input 3 MISO/SDA O Master In Slave out/ I2C Data line 4 CS# I Chip select , active low 5 INT# O Interrupt output active low 6 PD# I Power down control input, active low 6 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Pin No. Name Type 7 5V P 5V power supply 8 3.3V P 3.3V power supply 9 GND P Ground GND P Ground 10 Table 2-4 – J5 Pinout  Clearance No.: FTDI#425 Description J7- CTP Interface This is the capacitive touch panel interface where the I2C control and data signals are routed to. There are also power and ground pins on this interface. Pin No. Name Type 1 3V3 P 2 GND P 3 SCL I 4 SDA IO I2C data input and output 5 INT# O Interrupt output WAKE I Wake input 6 Table 2-5 – J5 Pinout  Description 3.3V power supply Ground I2C clock input JP1- Audio Amplifier Power Select This jumper provides the option to select the power supply voltage for the on-board power amplifier. Jumper position Description Short pin 1-2 3.3V selected (default) Short pin 2-3 Table 2-6 – JP1 Pin options 5V selected Note: This needs to be configured before audio can be heard. Default is 3.3V. Select 5V to increase the maximum volume for the speaker.  JP2 – On board amplifier enable Solder connection not fitted by default.  JP3 - On board amplifier mute Solder connection not fitted by default. 7 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073  JP6 – Power Input select Jumper position Description Short pin 1-2 Board power from CN2(default) Short pin 2-3 Table 2-7 – JP6 jumper options  Clearance No.: FTDI#425 Board power from CN1 JP12, JP13, JP14 – Mode select Default mode is SPI. JP12-JP14 are no not populated by the factory. To select I2C, user should close both JP12-14. *Note: The JP12-14 must be both closed to avoid IO signal conflicting in I2C mode. 8 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 3 Board Schematics Figure 3-1 - VM801B43A/VM801B50A (4.3”/5.0” Version) 9 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Figure 3-2 – VM801B SPI Interface and IO 10 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Figure 3-3 – VM801B Audio 11 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 4 Hardware Setup Guide 4.1 Power Configuration There are 5 methods of powering the VM801B board. 1) USB Power(5V) - Connect USB power through micro-USB cable to CN2 2) DC IN(5V) - Connect 5V to CN1 3) DC IN(3.3V) - Connect 3.3V to CN1 and short J5 pin 7 and 8 4) J5 Power(5V) - Connect 5V to J5 pin 7 5) *J5 Power(3.3V) - Connect 3.3V to J5 pin 7 and 8 *Warning: Applying 5 V accidently in this mode may cause permanent damage to the VM801B module. The following table summarise how to power the VM801B board using the various methods. Power Method CN2 CN1 J5 Pin 7 J5 Pin 8 JP6 USB Power 5V N/C N/C N/C Short pin 1-2 DC IN(5V) N/C 5V N/C N/C Short pin 2-3 DC IN(3.3V) N/C 3.3V J5 Power(5V) N/C N/C J5 Power (3.3V) N/C N/C SHORT 5V Short pin 2-3 N/C 3.3V Any Position Any Position Table 4-1 - Board power configuration 4.2 MPSSE Setup To provide a quick start with the VM801B development board, Windows based sample projects including source code are provided. An overview of the process is provided in the following paragraphs with more details in AN_245_VM800CB_SampleAPP_PC_Introduction MPSSE is a “multi purpose synchronous serial engine” interface available in some FTDI devices (e.g. FT2232D, FT232H, FT2232H, FT4232H, FT4222H and the modules built based on these silicon chips). This engine allows users to bridge from a USB port on a PC to an I2C or SPI interface. Sample code is available for driving the FT801 over this interface with a FT232H device. VA800A-SPI is a MPSSE module accessory which can connect to the VM801B modules directly. Detailed information on the VA800A-SPI can be found at: http://www.ftdichip.com/Products/modules/VA800A-SPI.html FTDI also provide a multipurpose MPSSE cable assembly C232HM-EDHSL-0(5V) or C232HM-DDHSL0(3.3V) for rapid setup. More information on the cable may be found at: http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_C232HM_MPSSE_CABLE.pdf. In this section it is assumed the VA800A-SPI is used. VA800A-SPI supplies 5 V for VM801B modules. If the VM801B is connected to an SPI interface with a 3.3 V power supply, refer to table 5-1 for the board power configuration. Note, improper power supply and/or IO voltage connection may damage the VM801B module. 12 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Figure 4-1 – VM801B connects to PC through VA800A-SPI accessory. Hardware Setup  Connect the VA800A-SPI to the VM801B module in the correct orientation (with J5-pin1 of the VM801B board connected to CN1-pin1 of VA800A-SPI board).  Connect a USB cable (suggest FTDI accessory VA-FC-1M-BKW or VA-FC-1M-BLW) from the VA800A-SPI to the PC USB host port or self-powered hub port.  The VA800A-SPI will supply power to the VM801B after the MPSSE driver is properly loaded and the USB host completes USB device configuration. NOTE: If using the C232HM-EDHSL-0(5V) MPSSE cable then the connection is as: J5 Pin number J5 Signal MPSSE pin number MPSSE Signal MPSSE Cable Lead Colour 1 SCK 2 SK ORANGE 2 MOSI 3 DO YELLOW 3 MISO/SDA 4 DI GREEN 4 CS# 5 CS BROWN 5 INT# 7 GPIOL1 PURPLE 6 PD# 9 GPIOL3 BLUE 7 5V 1 VCC RED 8 3.3V - - - 9 GND 10 GND Black 10 GND Table 4-2 – MPSSE cable (C232HM-EDHSL-0) connection - Software Setup  The following software setup steps apply to both the VA800A-SPI and MPSSE cable assembly.  Download the MPSSE software. MPSSE cable and driver information can be found at http://www.ftdichip.com/Products/Cables/USBMPSSE.htm.  Launch the demo application based on MPSSE from the PC 13 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 4.3 Arduino® Setup Sample code and demo applications are provided to users who want to connect the VM801B to a MCU. FTDI provides sample source code, sample application notes and a ready to run demo based on the Arduino® platform. Detailed information can be found at: http://www.ftdichip.com/Products/Modules/VM801B.html 14 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 5 Assembling the Bezel and Panel Mounting Figure 5-1 - VM801B Panel Mount (Front view) Figure 5-2 - VM801B Panel Mount (Rear view) 15 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 5.1 4.3” Dimensions Figure 5-3 - VM801B 4.3” panel mount dimensions 16 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 5.2 5.0” Dimensions Figure 5-4 - VM801B 5.0” panel mount dimensions 17 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 6 Specifications 6.1 Optical Specification Table 6-1 - 4.3” TFT Optical Specification 18 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Table 6-2 - 5” TFT Optical Specification 19 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 7 Contact Information Head Office – Glasgow, UK Branch Office – Tigard, Oregon, USA Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 7130 SW Fir Loop Tigard, OR 97223 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-Mail (Sales) E-Mail (Support) E-Mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Taipei, Taiwan Branch Office – Shanghai, China 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8797 1330 Fax: +886 (0) 2 8751 9737 Room 1103, No. 666 West Huaihai Road, Changning District, Shanghai, 200052 China Tel: +86 (0)21 6235 1596 Fax: +86 (0)21 6235 1595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com Distributor and Sales Representatives Please visit the Sales Network page of the FTDI Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Future Technology Devices International Ltd (FTDI) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested FTDI devices and other materials) is provided for reference only. While FTDI has taken care to assure it is accurate, this information is subject to customer confirmation, and FTDI disclaims all liability for system designs and for any applications assistance provided by FTDI. Use of FTDI devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to defend, indemnify and hold harmless FTDI from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Future Technology Devices International Ltd, Unit 1, 2 Seaward Place, Centurion Business Park, Glasgow G41 1HH, United Kingdom. Scotland Registered Company Number: SC136640 20 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Appendix A - References FT801 datasheet: DS_FT801_Embedded_Video_Engine FT800 software programming guide: FT800 Series Programmer Guide FT800 sample application notes: AN_245_VM800CB_SampleAPP_PC_Introduction AN_246_VM800CB_SampleAPP_Arduino_Introduction C232HM-EDHSL-0 datasheet: http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_C232HM_MPSSE_CABLE.pdf D2xx Programmers Guide: http://www.ftdichip.com/Support/Documents/ProgramGuides/D2XX_Programmer's_Guide(FT_000071).p df AN_108: Command Processor for MPSSE and MCU Host Bus Emulation Modes http://www.ftdichip.com/Support/Documents/AppNotes/AN_108_Command_Processor_for_MPSSE_and_ MCU_Host_Bus_Emulation_Modes.pdf 23 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Appendix B - List of Figures and Tables List of Figures Figure 2-1 - VM801B module profile 4.3” display version ........................................................................... 4 Figure 2-2 - VM801B module profile 5” display version .............................................................................. 4 The VM801B module dimensions are illustrated in Figure 2-3. .................................................................. 5 Figure 2-4 - VM801B module PCB view, 4.3 and 5 inch display version .................................................... 5 Figure 3-1 - VM801B43A/VM801B50A (4.3”/5.0” Version)............................................................................ 9 Figure 3-2 – VM801B SPI Interface and IO .................................................................................................. 10 Figure 3-3 – VM801B Audio .......................................................................................................................... 11 Figure 4-1 – VM801B connects to PC through VA800A-SPI accessory. .................................................. 13 Figure 5-1 - VM801B Panel Mount (Front view) .......................................................................................... 15 Figure 5-2 - VM801B Panel Mount (Rear view) ........................................................................................... 15 Figure 5-3 - VM801B 4.3” panel mount dimensions ................................................................................... 16 Figure 5-4 - VM801B 5.0” panel mount dimensions ................................................................................... 17 List of Tables Table 1-1 – Ordering information ................................................................................................................... 2 Table 2-1 – CN1 Pinout .................................................................................................................................... 6 Table 2-2 – CN2 Pinout .................................................................................................................................... 6 Table 2-3 – J2 Pin Options .............................................................................................................................. 6 Table 2-4 – J5 Pinout ....................................................................................................................................... 7 Table 2-5 – J5 Pinout ....................................................................................................................................... 7 Table 2-6 – JP1 Pin options ............................................................................................................................ 7 Table 2-7 – JP6 jumper options ...................................................................................................................... 8 Table 4-1 - Board power configuration ........................................................................................................ 12 Table 4-2 – MPSSE cable (C232HM-EDHSL-0) connection........................................................................ 13 Table 6-1 - 4.3” TFT Optical Specification ................................................................................................... 18 Table 6-2 - 5” TFT Optical Specification ...................................................................................................... 19 24 Copyright © 2014 Future Technology Devices International Limited VM801B Datasheet Version.1.0 Document Reference No.: FT_001073 Clearance No.: FTDI#425 Appendix C – Revision History Document Title: DS_VM801B Document Reference No.: FT_001073 Clearance No.: FTDI#425 Product Page: www.ftdichip.com/Products/Modules/VM801B.html Document Feedback: Send Feedback Version 1.0 Initial Datasheet released 25/11/2014 25 Copyright © 2014 Future Technology Devices International Limited
VM801B50A-PL 价格&库存
很抱歉,暂时无法提供与“VM801B50A-PL”相匹配的价格&库存,您可以联系我们找货
